  1. Dec 9, 2018 at 7:04 AM
    #2341
    Professional Hand Model
    Hand Protectors
    I’m wondering if he is talking about the fog lamp on/off switch and the instrument light dimming dial located to the left of the steering wheel under the driver side vent. Our earlier models have them.
    Yesterday, I noticed my fog button is dim and the instrument dial knob doesn’t have any light to let you know where it is at night. Obviously, I know where it is by feel but its nice to have it lit.
  2. Dec 9, 2018 at 7:08 AM
    #2342
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    My fogs are controlled on the light stalk. The dash I have a button to turn on the rear defrost, a toggle switch to slide my rear window open and closed and the dash dimmer
  3. Dec 9, 2018 at 9:10 AM
    #2343
    Hand Protectors
    Repaired the handle cover I cracked yesterday (when dismantling the door cover) due to the brittle cold temps. Reminded me of the cold a few years back and how I cracked my front signal casings when installing the front headlights.
    Used two part flexible epoxy. Touched up sanded with emory cloth.
    Darkness and because_wumbo-truck like this.
  4. Dec 9, 2018 at 9:49 AM
    #2344
    because_wumbo-truck
    Jon
    Houston, Texas
    Looks fine to me.
  5. Dec 9, 2018 at 10:00 AM
    #2345
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Both of mine split just like that. The cup for the screw is so weak.
  6. Dec 9, 2018 at 10:28 AM
    #2346
    Hand Protectors
    It cracked above the lock where you are suppose to pry the clip over where it snaps in place. Everything was brittle yesterday.
  7. Dec 9, 2018 at 12:23 PM
    #2347
    Sain6815
    Sain6815 New Member
    2005 Tundra DC Limited 4wd
    Is this the short ground wire that’s right beside the nagative battery post going to the driver fender?
    If so, mine is totally disconnected. What issues would this create?
  8. Dec 9, 2018 at 12:35 PM
    #2348
    Hand Protectors
    Yes. The short stubby wire connected to the negative. It should be connected onto the frame with a 10mm screw through an eyelet connector.
    Improper grounding may result in poor electrical reponse at devices. For instance, my stereo reset after the disconnect even though the battery cables were still connected.
    Another instance (in the past) was one door switch was not working due to the screws not properly tightened onto the frame. You seeing any problems with yours missing? If not thats great.
    Sain6815[QUOTED] likes this.
  9. Dec 9, 2018 at 12:37 PM
    #2349
    Sain6815
    Sain6815 New Member
    That’s kinda what i was thinking. Currently my power door locks aren’t working or my drivers power window and door controls for all windows.
    I just purchased this truck so I’m working out the gremlins.
    What’s interesting is that every other door can control its window. But all the driver controls are out.
    because_wumbo-truck and potoghi like this.
  10. Dec 9, 2018 at 12:38 PM
    #2350
    Hand Protectors
    Try reconnecting that wire. It may solve some issues.
  11. Dec 9, 2018 at 1:38 PM
    #2351
    Casper421
    In the woods
    06 DC
    Wired up and tested the new D2S’s. Now just need to wait for the correct shrouds and extensions to arrive.
  12. Dec 9, 2018 at 1:42 PM
    #2352
    Hand Protectors
    What is the final look of these you are trying to achieve?
  13. Dec 9, 2018 at 1:56 PM
    #2353
    Casper421
    In the woods
    06 DC
    They’re not for looks but light output. The stock reflector housing is horrific! There are shrouds that surround the reflector to block excess light which I am waiting for to finish the project.
    Darkness likes this.
  14. Dec 9, 2018 at 3:27 PM
    #2354
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Excited to see you tackling that @Casper421
    I got a pair of channel locks out and thought I would need some Heman mega strength to get my old bump stops off, turned out they came off with one hand. Left handed even, I love California.
    Little side by side with the superbumps from Wheelers
    The bolt is a bit shorter than the factory bump stop but it will be fine.
    After considering front or rear, I went with the front option. I did this because I figured if these create any twisting action by stopping one side of the arm first, I can minimize the leverage by going closer to the shock. Maybe?
    I might be riding right on these, imagine a parallel line from control arm slot to control arm slot. When I held an arm to it there may just be a gap, I'll find out this week.
    I have read that they squish an amazing amount, some report that they allow more up travel than the OEM ones, which I find hard to believe. I'm planning to test that myself soon and if the OEM one no longer makes impact, and if I like the ride, I may get another set for the rear bump stop to even out the twist.
  15. Dec 9, 2018 at 3:51 PM
    #2355
    because_wumbo-truck
    Jon
    Houston, Texas
    I want some. Will be awaiting your review.
  16. Dec 9, 2018 at 4:13 PM
    #2356
    Casper421
    In the woods
    06 DC
    It’s not as difficult of a job as I anticipated. The hardest and most time consuming part was removing all the sealant. I’m excited to have headlights that will actually work well. I’ve been relying on the new BD fogs these past mornings.
    I have a set of Superbumps coming with the front co’s. Keep us posted on mounting them on the front.
    Rheywood456 and Darkness[QUOTED] like this.
  17. Dec 9, 2018 at 6:41 PM
    #2357
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hardest part for me was getting a weekend with the wife out of town. I couldn't stick car parts in the oven with her home.
    :pout::rant:
  18. Dec 10, 2018 at 5:22 AM
    #2358
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That's when you buy them a day at the spa then do this:
  19. Dec 10, 2018 at 6:48 AM
    #2359
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I remember seeing that and thinking that guy isn't scared? :bowdown:
  20. Dec 10, 2018 at 8:06 AM
    #2360
    because_wumbo-truck
    Jon
    Houston, Texas
    Single life
  21. Dec 10, 2018 at 12:06 PM
    #2361
    msfitnetz
    msfitnetz 2003 TUNDRA SR5 AC 4x4 Salsa Rde
    VA
    2003 Tundra SR5 AC 4X4
  22. Dec 10, 2018 at 2:04 PM
    #2362
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    The superbumps are nice, I have them on my double cab. It softened out the front end a little. They didn't allow more up travel on my 4runner, more of helped slow the up travel so I didn't just bang my shit haha
  23. Dec 10, 2018 at 2:14 PM
    #2363
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    Can't wait to fit these new bad boys on
    hammeron, Brown Bear, BestGen and 7 others like this.
  24. Dec 10, 2018 at 2:39 PM
    #2364
    billyemerson
    billyemerson New Member
    Bill
    2002 tan Tundra w/access cab
    Replaced the stock steel wheels and caps on my 2002 with a Sequoia aluminum set from a wrecking yard, added step rails.
  25. Dec 10, 2018 at 3:07 PM
    #2365
    Hand Protectors
    Yesterday, I removed the green rubbers on the main lighting bulbs (5) behind the instrument panel. Color went from light white with slight green to a much brighter orange/peach. Made the switch today to Cool Blue Sylvania LED. No sanding or painting of dash surface was performed like others have done. This is just light bulb replace. See pictures below.
    ***Note: Colors are much more vibrant/intense in person than in pics.
    OEM HALOGEN (without green rubbers)
    Below:
    NEW LED SYLVANIA BLUE 168 Bulbs (white spot near the 80mph is from a white T-5 LED bulb as I did not have any blue. This is on order and is the last bulb to finish the project).
    In person this new bulb set up looks ROYAL BLUE with pure evenness and continuity. For some reason the pics makes it looks washed out and uneven. The bulb behind 80mph is a pure white LED T-5. A blue one is on order as these are not found in auto stores. Give you an idea of going either way. The blue looks so cool and is much easier on the eyes in person. Looks like butt in the pics though.
  26. Dec 10, 2018 at 3:14 PM
    #2366
    Hand Protectors
    Finished the last door on the sound damping/enhancing project. Installed butyl rubber with foil tape and some foam rubber on strategic areas in/on door cavity. Conclusion: The average OEM sound system sounds WAY better. All doors in total took about 4.5 hours. Backs are easiest. Fronts a little more technical.
    Door closed on this project.
    bmf4069, Darkness and potoghi like this.
  27. Dec 10, 2018 at 3:25 PM
    #2367
    Hand Protectors
    Had some extra 168 LED bulbs and replaced both rear license lights.
    Cracked all the nuts on the propeller shaft and carrier bearing in prep for the bearing swap tomorrow. Been PB Blasting everything for a few weeks now so the job would be easier. Decided to NOT replace u-joints unless I see/feel something wrong tomorrow when its dropped.
    Picked up a Duralast 150lb torque wrench from Autozone for $20 on sale. Normal price $30. Scored?
  28. Dec 10, 2018 at 3:49 PM
    #2368
    piscespokerbrat
    piscespokerbrat New Member
    Jeremy
    Portland, OR
    2005 Tundra Access Cab 4.7 4x4
    None yet - plan backup camera, led lighting, head unit, box organizer, and canopy or tonneau if one can be found local affordable.
    Got the efans installed on 12/1.. So far, I haven't seen any gains, and I'm not sure why. I do love the fact of how quit the engine is at start up. The load does dim the lights, so I'll be installing a capacitor at some point in the future.
  29. Dec 10, 2018 at 3:51 PM
    #2369
    Swalters
    Sam
    Arizona
    Damn you guys are productive. I took my dog to work today :rolleyes:
  30. Dec 10, 2018 at 3:58 PM
    #2370
    Hand Protectors
    What are efans?
