  1. Oct 20, 2020 at 11:53 AM
    speedtre
    speedtre New Member
    Inland Northwest
  2. Oct 20, 2020 at 12:08 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    speedtre[QUOTED] likes this.
  3. Oct 20, 2020 at 12:15 PM
    speedtre
    speedtre New Member
    Inland Northwest
  4. Oct 20, 2020 at 12:37 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Finally got the new trans pan installed. Praying to god that I put the FIPG on right and it doesn't leak. My bead didn't look nearly as pretty as the write up. I'll post a picture of the old transmission filter if anyone cares but there isn't really much to see. I couldn't find any metal shavings in it either. I'm really not convinced there is a good reason to ever drop the pan unless you have to because you're an idiot like me. :anonymous:
    bmf4069, FrenchToasty, NUDRAT and 7 others like this.
  5. Oct 20, 2020 at 12:51 PM
    Professional Hand Model
    Hand Protectors
    Did you snug those Valve Body Bolts?
  6. Oct 20, 2020 at 12:54 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes sir. Only 2 were ever so slightly loose. It's really kind of neat to see that area. I don't understand how those wires and plugs can be submerged in 150-200 degree fluid for 18 years but they looked new. Aisin must build a damn good transmission.
  7. Oct 20, 2020 at 2:05 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's too painful to relive. :facepalm:
    I FUBAR'd the drain plug on the original pan.
    bmf4069, Darkness, ktundra and 2 others like this.
  8. Oct 21, 2020 at 10:50 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Replaced the MAF sensor. Honestly don’t know if the old one is original and/or even bad but figured it’s cheap preventative maintenance.
    Bought on Amazon but it doesn’t have anything scratched off of it and looks identical.
    NUDRAT and hammeron like this.
  9. Oct 21, 2020 at 11:03 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Can I lift the back end of an 06 DC 1" with stock shocks, or do I need new rear shocks? I'm pretty sure the leaf springs are original and have some sag so part of me thinks with 1" I may just be getting it a little over stock anyway.
    Eventually I'll get new leafs, this is just to get rid of the bro squat for now.
  10. Oct 21, 2020 at 12:30 PM
    Hand Protectors
    The early gens MAF look different. You could put a Multimeter on the old one and test for spec as well as with the new one.
  11. Oct 21, 2020 at 12:48 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    From what others have reported, Bilstein 5100 shocks will add about 1in to the height.
    empty_lord likes this.
  12. Oct 21, 2020 at 1:22 PM
    Hand Protectors
    1) Installed new Bosch Wipers.
    2) Discovered that my Katana Bulbs do have micro fans! Thats the little whirring sound I thought was the alternator. I swear they said fanless when I bought them. :rofl:They are quiet and small fans (more so than the priors) and because I didn’t realize it assumed wrongly.
    Katana does make a new fan less bulb.
  13. Oct 21, 2020 at 1:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm unsure if anyone here has tried the fanless units...
    When I return to Toy headlight housings, I guess I'll be the lab rat :rofl:
    Edit: Above pics are links
  14. Oct 21, 2020 at 2:14 PM
    Kenai4x4
    Kenai4x4 New Member
    Varies
    04 Tundra DC
    Toytec 3" Coilovers Alcan custom 4" lift via 8-leaf 1,000lb rear springs Light Racing UCAs FN Five Star wheels Falken Wildpeak AT3W 285/75r16 Stubbs Welding rock sliders Leer 180 shell JBA LT headers Custom dual-2.5-into-single-3 with Pacesetter Cats, Borla Pro-XS, and bedside fender exit Volant CAI
    Full exhaust complete:
    JBA Longtubes into 2.5” pipes
    Pacesetter hi-flo cats
    Merge into a single 3”
    Borla Pro-XS muffler (40359)
    Vibrant Ultra-Quiet resonator (1142)
    Bedside exit w/4” double-wall tip (still mulling over bezel options that don’t involve a bolt-on or billet look)
    Gotta order some O2 sensor cable extensions and downstream simulators from URD and I’m set.
    On a related note, I’m selling a used Borla Cat-Back exhaust for 04-06 Tundra Double Cab (14852)
    7D59A79D-FA03-4036-9854-AFF9B2787813.jpg 17AA68FA-557F-440F-BBAF-E2DA2B5121E5.jpg BD3A7D84-88C3-4245-BD48-D6B32020104D.jpg 95D0D484-8964-4F38-9E56-ACF212AE17E0.jpg
  15. Oct 21, 2020 at 2:26 PM
    rock climber
    I thought you had HID retrofits?
    Tundra2[QUOTED] and FrenchToasty like this.
  16. Oct 21, 2020 at 2:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I do, and I won't.
    NUDRAT and FrenchToasty like this.
  17. Oct 21, 2020 at 2:44 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Hell yes! How does it sound? I want long tubes someday.
  18. Oct 21, 2020 at 3:42 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Changed out 3 out of 4 door check mechanisms. The doors were flopping around and didn't want to stay in place when opened. $tealer wanted $95 each, so off to auction world I went.
    This was the last of the 3 doors. I bought some used Sequoia rears from ePray and sure enough, the lengths of the arms are not compatible. Not a worry, they can be disassembled. I swapped out the wrong arm with the original one from mine.
    I discovered that these things are interchangeable (right or left side). Based on the markings on a single arm, one side is RR, and the other is RL (rear right, rear left). You just flip it over to use it on the other side of the car!
    Had to take the speakers out to pull the mechanism out. It was a good thing, since the screws holding in the speaker were loose on all 4 doors. Tightened them back down good. No more speaker rattling.
    Used some blue painters tape to block the hole underneath those screws. I managed to drop one nut, and was lucky enough to fish it out. That's not going to happen a 2nd time!
  19. Oct 21, 2020 at 5:35 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Ready to slip and slide! Thanks to @skywalker474 for holding onto the sliders for me and a few buddies who transported it from San Diego to southern Arizona. Fit and finish is top knotch, a lot of thought went into the mounting points and bolt washers, i was kinda impressed! They are heavy@ 70# each......
    chrisb, KNABORES, hammeron and 11 others like this.
  20. Oct 21, 2020 at 6:13 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I really need to get a set.... maybe when I get this camry sold I’ll order some.
  21. Oct 21, 2020 at 7:42 PM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    Also when I was looking it seemed impossible to find gear oil that didn't have the LSD additive already in it. Check the labels at your auto parts store. In fine print it very well may say "includes limted slip additive" or whatever. The Mobil 1 and Valvoline synthetics do/did at least.
  22. Oct 21, 2020 at 11:29 PM
    Kenai4x4
    Kenai4x4 New Member
    Varies
    04 Tundra DC
    It’s got a lot more volume than the previous Borla touring cat-back I had on there. While I got the more throaty sound I was hoping for, it has a fair amount of drone on the freeway. The merge to a single 3” was a gamble for me, hoped the resonator would cure most rasp/drone concerns—not so. Deep and throaty in the city, but I’ll sound dampen the floor and see how how I feel about the drone after that.
    Huge difference in low-end torque. Achieving that was the main goal before I weigh her down with bumpers in the spring.
  23. Oct 21, 2020 at 11:35 PM
    Kenai4x4
    Kenai4x4 New Member
    Varies
    04 Tundra DC
    I’ll get some posted shortly!
  24. Oct 21, 2020 at 11:48 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Nice. I gotta get my rear drivers side door replaced. The door will shut itself on the slightest of incline. The others are still fine.
    ktundra[QUOTED] likes this.
  25. Oct 22, 2020 at 12:03 AM
    empty_lord
    05 rollover special
    So, recommend the long tubes? I’m pretty set on them.. it’s just being ok with the price (unless I do the air pump disable on my 05, they’re like 1200).
    ktundra, Cane Skretteburg and Thrussn like this.
  26. Oct 22, 2020 at 11:11 AM
    Not gonna lie, if a matching one in white popped up for my AC under $300-400, I'd jump on it. It'd probably spend most of its life off the truck, but having it for various reasons would be awesome.
    Kongap and FrenchToasty[QUOTED] like this.
  27. Oct 22, 2020 at 1:10 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    C5ABA6EC-B9BD-4837-AF46-70B377D12FD1.jpg looks sweet thought Anyone have to cut this little piece to fit 33s? Seems its the only thing that hits. But i also havent drove it yet
    Edit: Im hitting the flares not the bumper actually
    chrisb and Darkness like this.
  28. Oct 22, 2020 at 1:21 PM
    jImmegart
    Jonah
    California
    my bumper does seem to be sagging alittle also. Any fixes?
    chrisb, ktundra and Darkness like this.
  29. Oct 22, 2020 at 2:13 PM
    empty_lord
    05 rollover special
    H
    how much lift? Probably needs to trim.
  30. Oct 22, 2020 at 2:16 PM
    jImmegart
    Jonah
    California
    Not sure the lift because I used DC 4x4 struts up front but it gave me around an inch. Im at 21.5
    Professional hand models height i think, But these tires are alittle more nobby
    Darkness likes this.
