  1. Oct 19, 2020 at 9:48 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    you're on 265/75s correct?
    FirstGenVol likes this.
  2. Oct 19, 2020 at 10:03 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yes. I will be going to 255/80r17s though. Probably a bit of a hit there but debating 4.10s or 4.30s.
    lsaami[QUOTED] and speedtre like this.
  3. Oct 19, 2020 at 10:07 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Just a question, I have the V6 manual trans version of this truck and it comes with 4.10 gears stock. Id like to go to 33 inch tires down the road and from what ive read, it could make my truck more sluggish. Should i regear to 4.56 gears ya think?
    By the way, Im thinking of getting 255 85 16 tires.
  4. Oct 19, 2020 at 10:12 AM
    empty_lord
    05 rollover special
    It will help restore some acceleration if you do.
  5. Oct 19, 2020 at 10:14 AM
    oscardog86
    Southern California
    Sorry another follow up question. Ya think I should buy the 33's and try them and see if its worth regearing, or would you regear knowing you were going to 33s beforehand?
  6. Oct 19, 2020 at 10:23 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I went with 255/80R17s expecting to want to regear...but after going up in size (and weight) with the tire, the gearing is not that big a deal. I have a much more powerful motor than you, but you do not have a slushbox, so I would try the tires first and see what you think. A front and rear re-gear is not cheap...you are looking at $2-3K depending on what part of the country you are in.
    oscardog86[QUOTED] likes this.
  7. Oct 19, 2020 at 10:25 AM
    empty_lord
    05 rollover special
    Try tires first. No point in doing gears and being unhappy with the results. Only reason I’ll eventually regear with the bigger tires is just to keep it happy towing, but even then I might not if I feel it’s still adequate (plus I’ll be adding power with headers before a regear, probably be more noticeable than regear)
  8. Oct 19, 2020 at 10:47 AM
    empty_lord
    05 rollover special
    I have a set of 4.30 gears from a different Toyota (forgot what it was from) whole rear diff was replaced due to bearing noise, the ring and pinion were fine. So those gears are going into my spare 8.4” diff and getting an trd lsd or trutrac. Down the line of course.
  9. Oct 19, 2020 at 12:23 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Man, I was thinking of regearing to 4.88s. this thing is a dog with the bigger tires. You'd be surprised.
  10. Oct 19, 2020 at 12:28 PM
    empty_lord
    05 rollover special
    lol I’ve got the VVTI and it makes quite the difference. Broader torque curve is noticeable. My 265/75r16s weigh around 80lbs a wheel. So weight is way up from stock.
    Rex Kramer and lsaami[QUOTED] like this.
  11. Oct 19, 2020 at 12:33 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    So wheel weights are pretty similar to what I have then, it just comes down to my bigger diameter, and non-vvti and 4 speed auto. I'd love to see a dyne chart of a VVTI 4.7 vs a non-VVTI.
    Cane Skretteburg likes this.
  12. Oct 19, 2020 at 1:00 PM
    gcholmes1
    gcholmes1 New Member
    2006 Tundra SR5
    I like! what brand are these wheels? Id love to see a pic when you get em on the truck!!
  13. Oct 19, 2020 at 1:01 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Anyone know why LED bulbs all have big heat sinks are some even have fans? LEDs take less to run, run cooler to the touch yet need more heat dissipation.....makes no sense to me though I’m sure there’s an obvious reason.
    Was just one of those things that made me go, ‘hmm’ today
    bassman417 likes this.
  14. Oct 19, 2020 at 1:25 PM
    Professional Hand Model
    Hand Protectors
    Ppp
    I’d get the Toyota TRD pads if I did it all over again. They come with the nice shim/silencer that are rubber backed. I bought the shim/silencers for some other pads (already previously acquired) and should have just bought the whole package with TRD Pads included in retrospect.
    Currently on PowerStop Tow/Haul Ceramics with Toyota Shims. Pretty good.
  15. Oct 19, 2020 at 3:03 PM
    empty_lord
    05 rollover special
    Leds generate heat in the circuitry not at the light source. They can generate a fair amount of heat and if they get hot
    Enough they’ll get dim
    CodyP[QUOTED] and Rex Kramer like this.
  16. Oct 19, 2020 at 4:58 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    They are FN countersteer type x is the name i think. Have the tires in my garage, and ganna mount them this week. Have to test fit at home as Im not 100% the tires will fit.
  17. Oct 19, 2020 at 5:22 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Got the old trans pan removed. I now know what ATF tastes like. Not bad, almost medicinal. I didn't find any metal shavings on the magnets! The only thing on there is that gray sludge you find on the differential magnet.
    I got the filter swapped out but I ran out of daylight before I could install the new pan. I'll tackle that tomorrow. In total I had over 8 quarts of fluid come out.
  18. Oct 19, 2020 at 5:35 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Looks like cherry flavored cough medicine.
    Darkness and Cane Skretteburg like this.
  19. Oct 19, 2020 at 6:18 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    It looks like this last weekend was the time for the first gens to go towing!
    I hauled a bunch of stuff about 200 miles away to prep for moving at the end of the year. The truck did great! Would you believe this yellow thing weighs over 2500 lbs empty? I think I hauled about 4000lbs of stuff on the way down.
    On the way back, I met up with a couple friends and went camping for three nights. I didn't want to drive back for the trailer, so I took it off-roading with me :rofl:
    After all was said and done, I traveled about 500 miles, averaged 12.5 mpg on the drive down (highway), and 13 on the way back (off-roading & camping).
    According to my obd2 reader (courtesy of PHM), the trans didn't get over 160° on the way down and 165 on the way back.
    Overall, I am impressed and proud of the ol girl and the trip was pretty fun!
  20. Oct 19, 2020 at 8:29 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Nice little present for yourself. :)
    Happy birthday! :bananadance:
    Kongap[QUOTED] likes this.
  21. Oct 20, 2020 at 5:09 AM
    Hand Protectors
    They are Mark Sumitomo Pads. Not TRD as I had wrongly mentioned yesterday. There are two styles of Sumitomo.
  22. Oct 20, 2020 at 5:52 AM
    empty_lord
    05 rollover special
    Gears don’t make more power, they just change out the drivetrain gets the available power down, when you change tire size you effectively change the final drive ratio. If you go to High if a gear, it will accelerate faster, but you’ll be doing 3,500 rpm at 60mph and lower your top speed
  23. Oct 20, 2020 at 9:51 AM
    Hand Protectors
    Based on your conditions, I’d keep the original gearing. Better gas mileage with the original gears at highway speeds. I’m on 285/75/r16 (32.8).
    I do a mix of city and highway with tow/haul on original gears.
    I’d *possibly* do new 4.56 gears if the truck was just rear wheel drive or possibly not. If most driving is highway I don’t think its worth it for me as both axles would need re-gearing with 4wd.
    ktundra and FrenchToasty like this.
  24. Oct 20, 2020 at 10:20 AM
    empty_lord
    05 rollover special
    4.30 interests me just because I already have a perfectly fine front diff with 4.30s... rare bird, but they exist
  25. Oct 20, 2020 at 10:24 AM
    Hand Protectors
    I’d be just as interested as you with access to choice low price used Toyota donor parts and a lift and all the proper tools to do the job in half the time. :D
  26. Oct 20, 2020 at 10:47 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My truck has the limited slip differential, but 260,000 miles on it. Do I need gear oil with the LSD additive or is it safe to say the clutches have completely worn out by now and and it's not really a limited slip anymore?
  27. Oct 20, 2020 at 11:19 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Here this will keep you busy for a week or two.... :thumbsup:
    http://www.grimmjeeper.com/gears.html
  28. Oct 20, 2020 at 11:23 AM
    Hand Protectors
    Use Lucas 80w-90 with LS already in it. Its dino oil. Good to use recycled animals and leaves for the environment.
    https://lucasoil.com/products/gear-oil/gear-oil/heavy-duty-80w-90-gear-oil
    ktundra, FirstGenVol and oscardog86 like this.
  29. Oct 20, 2020 at 11:32 AM
    Hand Protectors
    More power to you if you have the $$$ and skills.
    Most of my philosophy is based on keeping the truck OEM optimized utilizing timely/orderly preventative maintenance techniques. I’ll spend money on her for an upgrade that is proven and cost effective. Most of my non-OEM stuff is very low cost/free tinkering.
  30. Oct 20, 2020 at 11:42 AM
    speedtre
    speedtre New Member
    Inland Northwest
    You don't need to know all that info to figure out gearing for daily driving...
