  1. Oct 5, 2020 at 10:59 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The other one goes between the axle and oil deflector on the backside of the axle. That’s the one for oil slinging and it works if you catch it quick enough
  2. Oct 5, 2020 at 12:03 PM
    Professional Hand Model
    Hand Protectors
    Sounds like a lot of work. :rofl:
    Now that I know the ABS Sensor can be popped off easily for inspection of oil down in the hole this is my preferred method for early detection. Seems like the oil really needs to build up in there before seeping out based on my other axle which I detected early leaking. That seal was the second one and lasted about 7-8 years. I’ll check these Sensor Holes every tire rotation.
    ktundra likes this.
  3. Oct 5, 2020 at 7:05 PM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Finally taking shape... ooooo doggy :thumbsup:
  4. Oct 5, 2020 at 7:12 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Brace those wings by the tires good!
  5. Oct 5, 2020 at 7:21 PM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Don’t have a good picture, but they’re supported. If you zoom in you can barely see them here
  6. Oct 6, 2020 at 5:36 AM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I masked around them. I do about a 1 inch border around the emblems and then I just peel the part that is on the paint away from the emblems. I bet there's a few good youtube videos out there.
    Lil Steve likes this.
  7. Oct 6, 2020 at 5:39 AM
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    Swapped out my front Boss coils for 700lb ultimates. My passenger side Boss coil was weeping ever so slightly and I'm beyond picky. Wanted a coil that was rebuild able just in case this happened again.
    Anyone want a Boss front coil kit that weeps a drop of oil every now and then?
  8. Oct 6, 2020 at 5:42 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I'm interested. PM me your price and I'll see if I can make it happen without getting kicked out of the house.
  9. Oct 6, 2020 at 7:47 AM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
  10. Oct 6, 2020 at 10:14 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  11. Oct 6, 2020 at 10:35 AM
    912
    2005 DC 4x4
    I would check the wiring from the MAF and see if there is any take-off or splicing or extra harness on there. There are a few kits but I think they all use the MAF.
    CodyP[QUOTED] likes this.
  12. Oct 6, 2020 at 1:05 PM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    Finally got around to fixing the broken tailgate latch handle.
    Easy peasy. Though the picture shows how bad I need to do some scratch repair....
    Then got started on cap window fix. I use the tractor to pull the cap on and off as appropriate. The tractor's braking system relies on dropping the 3pt implement in a timely fashion. If you are following, you wont be surprised to hear that I smashed the cap window out with the tractor weight bracket...IMG_20201005_091841714.jpg ARE says it's 450 to replace the entire window assembly. I picked up some dark tinted plexi for much less. Today I cut to shape and cleaned the surface up. Will post again when complete.
    You guys love stepsides and filthy wheels right?
    Filthyphil, Darkness, NUDRAT and 5 others like this.
  13. Oct 6, 2020 at 3:51 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Removing the paper gasket remnants from inside the brake drum. I didn't realize how well it was hidden under a layer of rust. More wire wheeling work to be done.
    While trying to figure out why the parking brake was not working right, I ended up shearing the bolt to this bracket. It is supposed to allow the entire bracket to swivel, but it was frozen.
    Thanks to @Roman, we tracked down the part number for it, along with the bushings.
  14. Oct 6, 2020 at 4:14 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Something here seems fishy. I’ve read about counterfeit stuff off of Amazon. Any chance someone remembers what kind of box their plugs came in? The black box was a 6 pack and the blue were singles.
  15. Oct 6, 2020 at 4:19 PM
    FrenchToasty
    Mo
    Bone stock
    I might be the first to say it, but, stepsides don’t look bad with a cap on top! It really cleans up the weirdness of the rear end.
  16. Oct 6, 2020 at 4:21 PM
    Hand Protectors
    The cap makes them sharp looking. You aren’t the first to say this, as I was the first. You are second, though. :D
    I like them without the caps, but the cap really sets them off nicely.
  17. Oct 6, 2020 at 4:23 PM
    Hand Protectors
    Looks like you have Japanese and USA made plugs. Which store did you purchase these?
  18. Oct 6, 2020 at 4:23 PM
    Gmillz85
    greg
    She's a Pro
    Stepsides are sweet. Don't be afraid to be different
    Arringtonpalmer likes this.
  19. Oct 6, 2020 at 4:24 PM
    FrenchToasty
    Mo
    Bone stock
    Haha
    Not sure if that’s imperial jade or not, but that green color is somewhat rare on 4runners, so I’ve always been attracted to anything that color.........lamp post, camping cup; you name it!
  20. Oct 6, 2020 at 4:33 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  21. Oct 6, 2020 at 5:02 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
  22. Oct 6, 2020 at 5:36 PM
    hammeron
    hammeron New Member
    2002 Tundra v8 Blue 2wd
    Famous Cowl Leaky Grommet Repair: Well just did not want to endure another Season of the
    wet carpet, under the blower. Hardest part, is removing the wiper arms, they are just stubborn but
    if you work them back and forth gently, they relent and come off.
    Many thanks to PHM and everyone else, who, over the years have taken good pics and explained exactly
    what we need to do.
    no pics, because we all know by now what this is all about.
  23. Oct 6, 2020 at 5:36 PM
    empty_lord
    05 rollover special
    I need to do mine as preventative maintenance.. no leaks yet
    shifty` likes this.
  24. Oct 6, 2020 at 5:47 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
  25. Oct 6, 2020 at 5:49 PM
    shifty` Inside his chest they found ten thousand pencils
    Don't forget to apply anti-seize to the post before reinstall. Should save you the rock-a-bye headaches next time.
    Ditto. I'm working up a small parts list of preventative stuff. I should've bought these when I bought replacement torx-head screws for the cowl assembly (mine are oddly rusted).
  26. Oct 6, 2020 at 5:56 PM
    FrenchToasty
    Mo
    Bone stock
    Damnit it just had my wipers off when I installed ditch light brackets. I almost liked how the truck looked with no wipers, but if I left them off, it woulda rained that day.....
  27. Oct 6, 2020 at 5:57 PM
    Hand Protectors
    Post up a pick of the store you purchased these. Screen grab your receipt and post that please. Thank you.
    FrenchToasty likes this.
  28. Oct 6, 2020 at 5:59 PM
    Hand Protectors
    Yeah. Don’t forget to grease up those arms/pivots inside the cowl. Gotta go Gorilla Arm Technique on it.
    hammeron and FrenchToasty like this.
  29. Oct 6, 2020 at 6:00 PM
    Hand Protectors
    Birds love windshields with no wipers. :rofl:
  30. Oct 6, 2020 at 6:02 PM
    FrenchToasty
    Mo
    Bone stock
    Little known fact, Tucson has no birds due to the hi heat warnings they announce on the radio waves, they hear that and keep on flappin!
