  1. Oct 3, 2020 at 12:54 PM
    Professional Hand Model
    Hand Protectors
    Rustoelum (Reformer and Finish) works well! Wire wheel and sand sponge helps with surface prep. Lots of Brakleen. Make sure you use high temp brake grease like Silglyde on your contact points.
  2. Oct 3, 2020 at 12:58 PM
    Hand Protectors
    bassman417 and Thrussn like this.
  3. Oct 3, 2020 at 1:01 PM
    Hand Protectors
    Moisture will be a huge issue unless you condition the box. Without conditioning, your engine will sweat/rust from the the inside out. :rofl:
    oscardog86 and FrenchToasty like this.
  4. Oct 3, 2020 at 1:14 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    It’s pretty simple. Just make sure to disconnect the fog lights before pulling the bumper off. Once you remove all the pins and screws, slides right off.
    ktundra[QUOTED] likes this.
  5. Oct 3, 2020 at 2:08 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
  6. Oct 3, 2020 at 2:11 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Put my new rear bumper on! I only had to cut 1 rusted mounting bolt too ! :rofl:
    bmf4069, ktundra, N84434 and 7 others like this.
  7. Oct 3, 2020 at 2:30 PM
    Outbound
    Aaron
    Northern Alberta
    LED bulbs installed in driver footwell, hvac controls, cargo lights, cab mounted brake light and reverse lights. Checked function and condition of spare tire. Found this. Fuck.
  8. Oct 3, 2020 at 2:36 PM
    Hand Protectors
    Glad you found it useful. Feel free to add any new info/tricks on that thread. This OBD reader seemingly has endless options.
    Voss and Thrussn[QUOTED] like this.
  9. Oct 3, 2020 at 3:01 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Empty can and some hose clamps will fix it right up. :rofl:
    two2cal, bmf4069, 270Fan and 7 others like this.
  10. Oct 3, 2020 at 3:07 PM
    Outbound
    Aaron
    Northern Alberta
    LOL. That it would. I'm a little salty about it because I put that muffler on less than 2 years ago.
  11. Oct 3, 2020 at 3:08 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Drink a beer. Cut off the ends and slice the can open length wise with a couple of hose clamps and git er done. 'Nuff said. Next question. LOL
  12. Oct 3, 2020 at 3:10 PM
    artsr2002
    'Yonder
    LMAO. Festerw beat me to it. :rofl:
    Darkness and Outbound like this.
  13. Oct 3, 2020 at 6:03 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Impressive, that backplate looks like it was factory new! Mine has deteriorated well beyond that point. :(
    On that note, I broke off another bolt, this time it's the one that holds the parking brake cable to the rear axle. I knew I should have just left it alone and just loosened up the parking brake bracket with PB to get it to swivel freely. Arrrrrgh!
  14. Oct 3, 2020 at 6:44 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    we use those all the time for construction storage. They work well and keep things dry. Can’t speak to the condensation piece though. People do full on tiny home conversions with these.
    NUDRAT and empty_lord[QUOTED] like this.
  15. Oct 3, 2020 at 6:54 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Outbound[QUOTED] likes this.
  16. Oct 3, 2020 at 6:58 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’m eyeballing a 53 footer since it’ll fit the Tacoma, Mercedes and my frame.
  17. Oct 3, 2020 at 7:52 PM
    Voss
    2003 AC TRD 4x4
    So cool! Man I can’t even describe how grateful I am for finding this site! So much cool stuff to learn here!
  18. Oct 3, 2020 at 8:05 PM
    Outbound
    Aaron
    Northern Alberta
    Night pics of the new LED installs. Don't have any of the reverse lights yet.
  19. Oct 3, 2020 at 8:19 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    This is the first time I've seen that white gasket. Gotta get one! I was wondering why there was this paper like stuff I was taking off with my steel rotary brush.
  20. Oct 3, 2020 at 8:41 PM
    artsr2002
    'Yonder
    Details details and links mang. That looks great. I installed LED bulbs in the map lights and dome lights but need to replace my cargo lights because the cheap bulbs I used flicker like crazy. Also I'm gonna add some under the door panels for puddle lights like you did. Thanks.
    ktundra and Outbound[QUOTED] like this.
  21. Oct 3, 2020 at 9:03 PM
    Outbound
    Aaron
    Northern Alberta
    Map, dome, door, 3 of the HVAC, cargo, cab mount brake light and reverse lights are all T10 wedge bulbs
    https://www.amazon.ca/gp/product/B071LHP5WP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    The other HVAC lights and the footwell lights are T5 bulbs
    https://www.amazon.ca/gp/product/B07LDBK34F/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  22. Oct 3, 2020 at 11:40 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    So this happened a little over an hour ago... I think my Tundra will come out okay with minor scrapes and bruises... my neighbors weren't so lucky. Hit and run only to wreck a second time and flee on foot.
  23. Oct 4, 2020 at 12:23 AM
    empty_lord
    05 rollover special
    well shit that sucks. im soo glad i dont have to park remotely close to the street anymore.
    and uh.. dont forget, i buy wreaks! (looks like your bed will get some fixen and it'll be all good though.)
    Drunk drive i assume?
    NUDRAT and Pucks18 like this.
  24. Oct 4, 2020 at 1:43 AM
    Thrussn
    Gabe
    NM
    That breaks my heart. I'm sorry to hear about that.
  25. Oct 4, 2020 at 5:49 AM
    Rex Kramer
    Georgia
    I feel for my neighbors losing both vehicles in a single event, but they are insured so it should work out for them. The sheriff has not picked up the driver yet, but they do have his car so it's just a matter of time. My neighbors will have their vehicles towed later today, and only then will I see the extent of the damage to my long bed.
    Update: The driver that did the damage had his boss drive him over here today so he could apologize and share his insurance information - my faith in humanity is somewhat restored.
    lamboboy732 likes this.
  26. Oct 4, 2020 at 6:00 AM
    Hand Protectors
    You’ll join me in the ‘Side Doink’ Club. :rofl:
  27. Oct 4, 2020 at 6:37 AM
    Hand Protectors
    Yeah. You can see in the one pick I still hadn’t cleaned of the mating plate off the paper residue. Sadly, the nice new paper OEM Gasket wasn’t reinstalled by the goofy mechanic at Toyota Stealer when I was having a rear axle debacle. I’ve got a few extras somewhere, but not sure where they are. I’ve loaded up the area with Silver Anti-Sieze.
    My fronts had a lot more paper and rust chunks stuck on the rotors. After cleaning them up, the front end steering felt better in terms of smoothness at speed. I had no idea until reading about little things like a small chunk of rust messing up balancing. Keeping that mating surface flat is key. I even wire wheeled the back of the wheel and inside the lug holes to remove cack.
    NUDRAT and ktundra[QUOTED] like this.
  28. Oct 4, 2020 at 9:28 AM
    Pucks18
    That is absolute bullshit that the toyota mechanic forgot the paper gasket
  29. Oct 4, 2020 at 9:30 AM
    empty_lord
    05 rollover special
    Ehhh. Good chance it was destroyed beyond use if gear oil got on it. My gaskets only last 2 drum removals. They’re pretty thin paper.
  30. Oct 4, 2020 at 9:35 AM
    Hand Protectors
    I think the point is the Toyota mechanic should have put new ones back on. I even requested them put back on during their 3rd repair attempt. Nope.
