  1. Sep 28, 2020 at 10:14 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My 285 K02's only weigh 51lbs. :notsure:
  2. Sep 28, 2020 at 10:58 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Interesting...my 275/70 17 KO2's are 55 1/2lbs
  3. Sep 28, 2020 at 11:00 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did you go with E load range? I went with C since I don't do any towing and wanted to save a few lbs. Or it could just be that Tire Rack has the wrong weight on their website for mine.
    EDIT-Well, now I'm seeing 58lbs on their website.
  4. Sep 28, 2020 at 11:11 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    E range tires
  5. Sep 28, 2020 at 1:54 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    what tire?
  6. Sep 28, 2020 at 2:08 PM
    empty_lord
    05 rollover special
    Cooper st max. Website said like 60 or something but when I weighed them they were like 72 lbs
  7. Sep 28, 2020 at 2:44 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    whoa.
    Gonna be getting on the scale with my one of my Patagonias tonight.
    NUDRAT likes this.
  8. Sep 28, 2020 at 4:46 PM
    Professional Hand Model
    Hand Protectors
    Another long day under the hood. Basically at radiator/hoses put back and fan/clutch install.
    Torn down the old Alternator. Tow Package Spec says less than 3/16” is NG. My radar was right on this.
    bmf4069, Darkness, NUDRAT and 4 others like this.
  9. Sep 28, 2020 at 4:49 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Any tips on removing the bumper cover?
  10. Sep 28, 2020 at 4:49 PM
    Outbound
    Aaron
    Northern Alberta
    Damn, I literally just ordered some this morning. LOL. Thanks though!
    I ordered these ones.
    https://www.amazon.ca/AUXITO-Chipse...1&keywords=t10+led+bulb&qid=1601338597&sr=8-5
    and these ones since I read I also need T5 bulbs
    https://www.amazon.ca/WLJH-Automoti...lja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1
    I got 'er done today. I wouldn't say the terminal was cheap though. $45. :annoyed:
  11. Sep 28, 2020 at 4:54 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    A little feather dusting on Sunday
    Wiped down the underbelly of the hood, too.
    Voss, Jaykidd2518, artsr2002 and 9 others like this.
  12. Sep 28, 2020 at 4:55 PM
    Hand Protectors
    Old Fan bracket was shot and grindy. Probably the early morning cold start up noise in the winter. I’ll know more about the fan clutch tomorrow when I put my hands on the new one.
    So far I’ve only been missing one bolt (not accomodated for) and thats because the new Accessory Belt Tensioner only has 3 fastener points instead of 4. Was wondering if I missed installing the spare somewhere and its because of the new tensioner not requiring it. This new tensioner has MEGA Tension compared to old one.
    bmf4069, bassman417 and ktundra like this.
  13. Sep 28, 2020 at 4:58 PM
    Hand Protectors
  14. Sep 28, 2020 at 5:04 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Nice teardown! Who is Momba? Your impact wrench?
    Also, any recco on your gear puller and crank holder tools?
  15. Sep 28, 2020 at 5:10 PM
    Hand Protectors
    Yep. Momba is Impacto Supremo ala Milwaukee 1/2”. I’ll post up pics and reccos of the tools when I’m not worn out from 10 hour days on the truck. :rofl: Sitting at 20 hours labor right now with 4 more to go. Both garages quoted me 2 days and the would be doing half of the detailed stuff I’m doing.
    bmf4069, Darkness, MS22 and 2 others like this.
  16. Sep 28, 2020 at 5:51 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Whelp, longest oil change of my life, first time on the Tundra. I thought I had overfilled at first, so I then gently drained some. Come around to realize that I just didn't let the oil settle enough on the dipstick. Past vehicles would settle in a minute and I am finding that I need to wait at least 5. So I ended up draining and then having to refill. Quite difficult to read the oil on the dipstick but I consider how clear the oil is a good sign of the engine design. Next time will be quicker.
  17. Sep 28, 2020 at 6:02 PM
    shifty` Inside his chest they found ten thousand pencils
    Damn G, what'd you use?
    bmf4069 likes this.
  18. Sep 28, 2020 at 6:33 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    @Shifty The color temp is a bit off in the 2nd pic. Much more blue, so perhaps it appears to be more dramatically clean?
    Anyhoo, I just used a damp microfiber towel and a bucket of soapy water to rinse often.
    Tip is to wipe the lightest dirt off first, and work your way to the most grime. The towel is so laden with grease after wiping down the hood, I’ll prob have to dump the towel.
    Darkness and shifty` like this.
  19. Sep 28, 2020 at 6:37 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Boy, and i felt bad for my wife being in labor for several hours. Yeesh, 24 hrs+
  20. Sep 28, 2020 at 7:03 PM
    lc69hunter
    lc69hunter New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    Replaced rear springs (OEM spec), hanger bushings and an Add-a leaf from Toytec. Got 1 7/8 inch lift out of it.
  21. Sep 29, 2020 at 8:49 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    as a follow up to the tire weight conversation yesterday, I weighed my Patagonia and it was 61lbs.
  22. Sep 29, 2020 at 2:25 PM
    Hand Protectors
    Finished the TB Job. Having never done this before, I was apprehensive to do the first key turn. Like magic she started like nothing happened. Didn’t even miss a beat! Took her on a couple shake down drives and everything works. Every button and light and A/C works. 4WD works. Every bolt and nut was accounted and put back. No extra parts except for the one Bolt not needed on the New Style Tensioner for Accessory Belt.
    In total, I have about 30 hours invested into this project.
    1) Timing Belt
    2) Water Pump and Toyota 1282B Sealer
    3) New Alternator (checked brushes and they were about to fail).
    4) New Fan Clutch
    5) New Style Tensioner and Heavy Duty Gates Accessory Belt.
    6) New Radiator
    7) All New OEM Coolant Hoses and Spring Clips
    8) Added a Redundant Ground from Alternator to Battery Negative Post. Conductive Grease at Alternator to Engine Mountings.
    9) Painted Skid Plate.
    10) New Oil Dip Stick at Oil Pan O-Ring and FIPG’d the top grommet.
    11) Added Bottom Rad Fan Cover missing piece.
    12) Prestone Flushed/Cleaned the Cooling System prior to work. 3 Flushes.
    13) Added Foam Seal Strips at Top and Bottom of Radiator entry to facilitate better flow and eliminate hot blow back from engine being recirculated into the radiator area.
    14) New Cam and Crank Seal(s).
    15) Cleaned Throttle Body.
    16) New OEM Neg Post Cap.
    17) New Fan Bracket
    She sounds really nice. Not sure if its a combination of things, but the Engine really pulls air now from the front grille. I‘ll post up some pics of the Foam Sealer Trick that definitely makes a difference later tomorrow. A small thing that really helps!
    912, MS22, shifty` and 15 others like this.
  23. Sep 29, 2020 at 2:48 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Professional Hand Model nice work. What tool did you use to hold the fan clutch when tightening those bolts? The ones they rent at advance don't work.
    Did you buy one of these?
  24. Sep 29, 2020 at 2:57 PM
    Hand Protectors
    I did not use a special tool there. I did the double wrench trick. Hold one and loosen. When you get to the last nut, put the one back on backwards and wedge a screw driver in there between the nut flange and fan shaft flute. I also wedged a rubber handle up between the pulleys for that little something extra. The put back is easier than the take off.
    Had to get creative on a lot of stuff on this job. Glad to have the Crank Nut, Pulley Removal and Cam Holder Tools. Money well spent ($100ish in total). Otherwise, I’d be still out there working on her. :annoyed:
    Thrussn, bmf4069, bassman417 and 3 others like this.
  25. Sep 29, 2020 at 4:39 PM
    empty_lord
    05 rollover special
    I have one complaint to voice about your install.
    The gates belt is installed backwards to my liking.
    overall, great job!
  26. Sep 29, 2020 at 4:52 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    He likes to read it from the drivers seat :D
  27. Sep 29, 2020 at 4:54 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Nice job! Hopefully you will post all the part numbers in your revival thread!
    #13 made me laugh but I get it.
    And if it sounds different or sounds like it pulls more air, it’s because it is. That missing fan shroud was supposed to be there for a reason. The fan needs to be able to creat a pressure differential from infront to behind, it can’t(Efficiently) if that missing shroud let’s all the air out the bottom, the mojo that mechanic left you with........
    Let me know how long that gates belt stays green
  28. Sep 29, 2020 at 5:27 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Lol, it would almost seem logical that the logo/name on the belt would be facing you, once you open the hood and look at it.
  29. Sep 29, 2020 at 5:28 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Congrats, buddy! Awesome work.
    Now you have only 8 more TB jobs before you reach your road to 1 million miles.
  30. Sep 29, 2020 at 7:04 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wanna hear the count of how many missing parts and 10mm bolts you noticed :D
    Voss, ktundra and artsr2002 like this.
