  1. Sep 12, 2020 at 3:03 PM
    JessiJane06Tundra
    JessiJane06Tundra New Member
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Do you think mechanics still exist out there (particularly independent mobile mechanics) that will complete a repair and sabatoge another unrelated part of the vehicle so they will get called right back and make more money? Vote yes or no and settle a disagreement for me?
  2. Sep 12, 2020 at 3:35 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    There probably is, a lot of shitty people out there.
    The canisters are crazy expensive. I'd start with checking for cracked lines first.
    There are some cheap assemblies out there if you go that route save your old parts since not all of the aftermarket springs will fit every shock.
    GODZILLA and NUDRAT like this.
  3. Sep 12, 2020 at 3:55 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Water pump groove? The water pump doesn’t get any fipg, the inlet side the fipg goes in the groove per the FSM
    Most of the time it doesn’t go in the groove but the 4.7 is an exception for the. I let housing
  4. Sep 12, 2020 at 5:18 PM
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    I bought the truck with these tires, they're 305/70/r16 I think they are/were mud tires? I haven't checked specifics yet but it definitely has some kind of lift. Regular alignments keep it from rubbing the upper control arms. Buut.. my lower ball joints have broken 2 times and I had to completely overhaul upper lower ball joints inner and outer tie rods with oem parts and as soon as I can afford it I'm gonna take them down in size. It's not worth the time and money replacing parts. Plus the damage to my door and fender from when the ball joint snapped.
    Darkness and NUDRAT like this.
  5. Sep 12, 2020 at 7:14 PM
    270Fan
    270Fan New Member
    2004 Silver Tundra 4x4 DC
    After the damage from those busted ball joints you should probably just part that thing out. I'll PM you a list of parts I'm interested in. ;)
    bmf4069, Filthyphil and Darkness like this.
  6. Sep 12, 2020 at 7:39 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    Bilstein 5100 are recommended by many here. Re-use the stock springs. If you don't want to compress them, you can take your shock assemblies to a shop and they may swap the swings over for $50.
  7. Sep 12, 2020 at 7:53 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not exactly something I did, but something I picked up. I've been wanting a drop hitch to tow my bugs, this should do fine and the color is right.
    CodyP, Thrussn, bmf4069 and 10 others like this.
  8. Sep 12, 2020 at 8:02 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Is the gap so you can run a pintle hitch?
    Darkness[QUOTED] likes this.
  9. Sep 12, 2020 at 8:27 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Since I couldn't complete the brake line repairs, I moved on to the shocks. Managed to get this one done before sundown. 3 more to go.
    I escaped the spring compressor of death, this time around.
    Borrowed this tip from Timmy the Toolman. You take the truck's own jack, invert it and use it to press down on the entire arm assembly in order to get the shock assembly out. I only disassembled the tie rod and the sway bar.
    Looks like shoddy work was done on removing the dust cap.
    Bits of the brake dust shield just crumbled apart.
    More shoddy work left behind. No cotter pin on the tie rod! Good thing the rust kept it in place, lol.
  10. Sep 12, 2020 at 9:47 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No but good guess. Thats for recovery snatch strap activities.
    CodyP, bmf4069, KNABORES and 3 others like this.
  11. Sep 13, 2020 at 9:02 AM
    Better put a kryptonite double hardened finger print and retina scanner lock on that hitch. Too sexy for most to resist.
    Tundra2, NUDRAT and Darkness[QUOTED] like this.
  12. Sep 13, 2020 at 9:13 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
  13. Sep 13, 2020 at 9:36 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh yeah,, its only gonna be on when in use, otherwise it will be locked away.
  14. Sep 13, 2020 at 10:09 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Made the universe happy by washing the wife's car! All is good now...
    2016 Lexus NX 300H (Hybrid)
  15. Sep 13, 2020 at 10:29 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Finished installing the front Billys. Ended up with about 2" in additional height.
    I'm thinking this is going to make it even tougher to do the timing belt now. Maybe I'll build a 6" wooden platform for that.
    Used the truck's own jack as a compression tool to push up on the tie rod so I can torque the castle nut to spec. Otherwise, the ball joint was spinning with the nut.
    Used the truck's jack crank wand to rotate the bottom shock mount into position. It happened to be close enough in diameter to fit.IMG_5943.HEIC.jpg
  16. Sep 13, 2020 at 10:38 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Nice use of stock tools.
  17. Sep 13, 2020 at 1:04 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Prepped and painted that area under the battery and cleaned up the engine bay.
  18. Sep 13, 2020 at 3:07 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Had some fun pulling the old parts truck out of the woods.
    bmf4069, NUDRAT, Lil Steve and 3 others like this.
  19. Sep 13, 2020 at 4:05 PM
    FrenchToasty
    Mo
    Bone stock
    Did the pinche weld mod, turned out good enough for me. Small double ended “sheeter” was the winner of the day for most useful tool. I was doing the relief hole like @Darkness mentioned, but a full length bit and a drill don’t fit up in there very well. Bent it back with a crescent wrench and left the bolt for structural support. Then I painted it BLACK and used the heat gun to sorta mold the plastic back. I don’t rub on that lowest flare bolt anymore so that’s a win!
    Darkness, oscardog86, bmf4069 and 4 others like this.
  20. Sep 13, 2020 at 8:06 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    So my boss has these tires and with 38k on them he is really happy with them. I drove his rig and they are winning me over. Full set is $550 otd. I have 17x7 snowflake rims. Manufacturer suggests an 8.5 rim for the 285s. Should I go for the 265s? Or can it be done?
    https://thunderertireusa.com/thunderer-tires/truck-suv/ranger-atr/
    Darkness likes this.
  21. Sep 13, 2020 at 9:59 PM
    bokch0y
    bokch0y I'm a sucker for DirtySOHC's
    Finally had a few minutes to install the retro tri-color emblem, love this thing!!!
    Does anyone else have this? I've seen the white/gray/dark gray emblem on the Lexus' and also the yellow/orange/red one on an FJ around my area.
    Darkness, Thrussn and bmf4069 like this.
  22. Sep 13, 2020 at 10:29 PM
    artsr2002
    'Yonder
    I like the emblem but tell me more about your electric conversion and the charging plug sticking out the front. What's your electric only range? :D
    NUDRAT, Darkness, theblurry1 and 3 others like this.
  23. Sep 13, 2020 at 10:48 PM
    bokch0y
    Hahaha block heater cord, need to cram that back inside the bumper.
    Tundra2 likes this.
  24. Sep 14, 2020 at 2:27 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I like the emblem too. Can you tell me what paint/color you used on your grille?
  25. Sep 14, 2020 at 5:20 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Added at least 5Hp.
    bassman417, abcinv, bokch0y and 7 others like this.
  26. Sep 14, 2020 at 8:56 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    This video has really good info on diagnosing evap codes. https://www.youtube.com/watch?v=GAzOOWfje9o
    Also check the gas cap and the gas tank where the cap sits. Lots of times it's just a bad seal between the cap and the tank.
    For shocks, your best bet is to get 5100's and have a local shop assemble them for you. The best deal I've found for preassembled is the eibach at toytec
  27. Sep 14, 2020 at 9:11 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    That visor does look cool but what is the purpose of it? Looks like a hat lol
    lsaami[QUOTED] likes this.
  28. Sep 14, 2020 at 9:22 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    I'm getting an annoying squeak from my front driver's leaf shackle. I tried re-torquing bolts to 80 ft lbs but the top one keeps compressing and I feel I shouldn't tighten it further (other side's fine and not extremely tight). Weird that only one is done.
    Probably time to switch it out, so I just have the understandable plethora of questions... anyone ever replaced a shackle and what tutorial did you follow? Should I do both sides, and is there anything else I should tackle while under there? Any recommended brands? I also have SuperSprings, if that's relevant.
  29. Sep 14, 2020 at 9:28 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    More pics please, something is weird here.
    theblurry1[QUOTED] likes this.
  30. Sep 14, 2020 at 9:29 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I count 35 sticker horsepower there on top of the cap. You're not far from supercharger territory!
    Clean bay.
