  1. Sep 9, 2020 at 5:37 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Did it go out or are you just preventative maintenancing?
  2. Sep 9, 2020 at 5:41 PM
    Professional Hand Model
    Hand Protectors
    PM. From readings, many seem to fritz in the 200k mark. I’m at 171k with bigger tires the entire life so thats getting near the mark when you add up the extra %.
    I’ll pull the old one apart and measure the brush per the FSM and see if my radar is confirmed.
    bmf4069 and theblurry1[QUOTED] like this.
  3. Sep 9, 2020 at 6:47 PM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    I think this is the specific TSB that identifies the new tensioner and the associated a/c bracket: img - Toyota TSB EG026-06 page 1.jpg
  4. Sep 9, 2020 at 6:53 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    some feather dusting this evening... sorry, no before pics, but the battery was all crusty on top, terminals rusty and greasy.
  5. Sep 9, 2020 at 8:31 PM
    ktundra
    Lex
    NJ
    Bilstein 5100
    @Professional Hand Model
    I'd be willing to go half to split the cost of this goo...
  6. Sep 9, 2020 at 11:15 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Some battery terminal protection spray or dielectric grease will help keep the crusties away longer now that you've got them all cleaned up.
  7. Sep 10, 2020 at 3:22 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Installed a locking hitch pin. Went to put the key on my key ring, and saw this. I'll be damned. Lol
    NUDRAT, bmf4069, Lil Steve and 2 others like this.
  8. Sep 10, 2020 at 5:28 AM
    Hand Protectors
    Thank you. I’ve committed to the Aisin Gasket Maker that they recco. @w666 put up a link to the fleasbaay store for the same tube at around $30 free shipping. I figured just use the Aisin recco for $20.
    You’ve a great start on your Feather Dustings. Try buying some Ideal Goo. Not sure if you have a battery terminal brush so you could rough up the posts and the inside of the clamps before adding the goo. Coat those exposed wire tips as well. Works on all metal wire even though its made for Aluminum. High recco!
    bmf4069 and ktundra[QUOTED] like this.
  9. Sep 10, 2020 at 5:34 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    There’s a company that makes locks for all kinds of stuff for your vehicle, that uses your oem key!
    https://www.boltlock.com/
    NUDRAT and CodyP like this.
  10. Sep 10, 2020 at 5:46 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Thanks, I will check this out! I've already used a wire brush to clean up the terminals, so now it's just a matter of applying this stuff.
  11. Sep 10, 2020 at 5:51 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I use this stuff.
  12. Sep 10, 2020 at 5:52 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This is turning into the most expensive timing belt replacement of a 4.7L in history.
    :spending:
    abcinv, bmf4069, Casper421 and 4 others like this.
  13. Sep 10, 2020 at 5:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Wow!
    Thats really cool tech on their info page. May have to cough up some dough to eliminate a butt load of keys.
  14. Sep 10, 2020 at 6:04 AM
    Hand Protectors
    Thats good stuff too. I like the Bottled Goo because its cleaner/easier to use as a little goes a long way. No spray mess. I put a dab on and spread it around the terminals (using gloves). Use it on all other connections by just adding a dab and reconnecting. The little bottle will last a lifetime.
    Tundra2 likes this.
  15. Sep 10, 2020 at 7:47 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    It is pretty cool, but be wary. A few people reported that locks didn't work after 6 mos. and worse is when the cylinder for the tow pin comes off on its own.
  16. Sep 10, 2020 at 7:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    NG. Thats not a light chunk of change for a lock. :monocle:
  17. Sep 10, 2020 at 10:17 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
  18. Sep 10, 2020 at 10:39 AM
    Hand Protectors
    No. It will be a few weeks before I will look. I’ll let you know.
    Pucks18[QUOTED] likes this.
  19. Sep 10, 2020 at 1:49 PM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Swapped out the K&N I inherited from the PO for a paper filter and cleaned the MAF, TB, and AC condenser. Made a big difference. I must say it is such a pleasure working on this thing. So well built and designed. And so much room under the hood.
    6B2C0DAF-8870-477A-A4DD-AEC9C24C335D.jpg DCA2F503-E8F6-4A8D-9141-2BEC17849F09.jpg
    bmf4069, abcinv, oscardog86 and 2 others like this.
  20. Sep 10, 2020 at 1:57 PM
    Hand Protectors
    Is that coil picture up the blower hole? What did you use for cleaning agent?
    theblurry1 likes this.
  21. Sep 10, 2020 at 2:01 PM
    912
    2005 DC 4x4
    It’s behind the glove box, after removing a sensor of some kind. I sprayed it with coil cleaner from Lowe’s that said it was safe for autos. I let it dissolve and emulsify all the nasty stuff and then ran the ac for 30 min. It’s colder now and smells like a new truck!
    Edited to add the most important fluids involved in Tundra maintenance today:
    06yotamike, artsr2002, CodyP and 11 others like this.
  22. Sep 10, 2020 at 8:55 PM
    270Fan
    270Fan New Member
    2004 Silver Tundra 4x4 DC
    This is strong, I was going to get new parts but it's over 400 bucks. I wasn't sure about plasti-dipping but this is definitely a great stopgap.
    ktundra and bassman417[QUOTED] like this.
  23. Sep 10, 2020 at 9:00 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Go for it.like $6 a can and a few hours make a huge difference. i was suprised at how good it came out but probably will redo it at some point as it is not perfect cause i did not remove some of the leftover original plastic.
    how bad is your trim or whatever? got pics?
  24. Sep 10, 2020 at 9:12 PM
    270Fan
    270Fan New Member
  25. Sep 10, 2020 at 10:44 PM
    bassman417
    Paul
    Las Vegas
    @270Fan
    that looks scary familiar man. is your driver side worse than the P side? mine was for some reason. that side actually is intact. I figured that the prior owner parked it with sun blazing on that side.
    anyhow, I failed to remove all the leftover plastic before spraying and regret it, but it still looks almost new. I would suggest a thourough prep and you will be amazed at the results. i had a slight issue when pulling the tape after letting it set according to directions. It peeled a little in a few spots. i started using a razor to slightly score where i got resistance.
    show us the after pics whenever you get there....
    https://www.amazon.com/dp/B0006SU3QW/ref=cm_sw_r_cp_apa_i_72WwFb5ED28Q4
    270Fan likes this.
  26. Sep 10, 2020 at 10:50 PM
    270Fan
    270Fan New Member
    Yeah, I'll probably take mine off the truck and completely strip them before I dip them. The truck was parked in Bakersfield where it gets really hot. My driver side is also worse, I think it was the way it was parked.
  27. Sep 10, 2020 at 11:14 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yep, the DC trim piece was for the driver door was like $130 but it was well worth it. My other doors were fine.
  28. Sep 11, 2020 at 8:30 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    I second that. A little bit of dremelling where the plastic wouldn't come off, some sanding/prep work, and a few light coats of spray paint got mine looking amazing. Takes the exterior look to the next level.
    Golly. I guess I just have more time than money. :p
    shifty`, bmf4069 and CodyP[QUOTED] like this.
  29. Sep 11, 2020 at 8:53 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Well mine was missing the outside top seal so it worried me with water getting down into the door and ruining the regulator.
    NUDRAT and theblurry1[QUOTED] like this.
  30. Sep 11, 2020 at 2:20 PM
    bassman417
    Paul
    Las Vegas
    how difficult is it to remove them without damaging them? didnt realize that was possible.
