  1. Aug 11, 2020 at 8:18 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I’m gonna have to do a better check but I’m pretty sure there isn’t a way in. There are a few quarter / halfdollar size slots but further away from that area... that would be ideal. To sneak in a nut and somehow get it threaded
  2. Aug 11, 2020 at 8:28 AM
    Professional Hand Model
    Hand Protectors
    Not sexy stuff like double rez shocks or beefy leaf packs.
    Tested the T-5 prongs (reverse attempted also) and no light. Decided to button her up before mangling something not worth the risk. Might need one of your magic bulbs from the collection. :D
    A side success, to offset bulb failure, is that the drivers side switch for the pass side window is not sticky anymore. The clean up and electric grease helped.
    Moved the engine ground up to the manifold. Was doing some reading on shared grounds this morning and it made me move it from that located OEM spot from the other day where the main harness has a small ground wire lug.
  3. Aug 11, 2020 at 8:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A bummer for sure. I'll get to work on that spare switch for you when I get some free-time.
    Do you want white, or blue to match your dash?
  4. Aug 11, 2020 at 8:32 AM
    Hand Protectors
    Disassembled an old ignition coil for investigative purposes.
    Thrussn and Tundra2 like this.
  5. Aug 11, 2020 at 8:36 AM
    Hand Protectors
    No worries on this unless its shipping only. :D White please if thats the case.
  6. Aug 11, 2020 at 8:48 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    How about we "trade" the switches so the LED wealth can be spread to the next guy, or gal who wants one?
    Once I get yours done I'll send it to you, and eat the shipping cost to you if you agree to send me your old switch so I can do the same with the next switch? You eat the shipping cost to me. This helps the community.
  7. Aug 11, 2020 at 9:08 AM
    Hand Protectors
    Good idea, but I’ll pass not because I don’t want to help. I appreciate the offer and will stay the course with what I have. I’m tired of all this electrical work. :rofl:
    Maybe someone else will take you up? I hope!
  8. Aug 11, 2020 at 9:11 AM
    fighthedude
    fighthedude New Member
    If i run 285/70 17 on a stock double cab 4x4 for a week or so will it be an issue?
  9. Aug 11, 2020 at 9:14 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It would only be this piece, but ya know cleaned, greased, assembled, and whatever color led I have available soldered in.
    3 philips screws, one connector and you're done. PNP OEM.
    :fingerscrossed:
    Time for bed. Up in 3 hours.
  10. Aug 11, 2020 at 9:16 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Darkness
  11. Aug 11, 2020 at 10:00 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I had the same thing happen on my drivers side front, I was able to get my hand in there to hold the nut while I tightened it until it would hold enough to crank it down. I didn't have to do that on the rear so don't know how hard that one is.
    Darkness and Rheywood456[QUOTED] like this.
  12. Aug 11, 2020 at 10:27 AM
    rock climber
    You're going to get some serious rubbing especially on the mudflaps; mostly when the suspension compresses. If you can wait for the lift I would.
    fighthedude[QUOTED] likes this.
  13. Aug 11, 2020 at 10:30 AM
    fighthedude
    Copy. I was looking at that. I gotta drive it to shop about 80 miles away. I removed mud flaps yesterday because i felt that would be an issue.
  14. Aug 11, 2020 at 10:36 AM
    rock climber
    If it's just a drive to the shop, you should be fine. It's only plastic you'll be rubbing on (assuming proper wheel offset)
  15. Aug 11, 2020 at 11:24 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Oh really. Thats good news. I may have to recruit my wife's small hands to fit in there. First Ill have to find the hole you used. haha. But great news, thank you for the response! Hopefully ill have time sometime this week to make it happen.
    Darkness likes this.
  16. Aug 11, 2020 at 11:28 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Depends how much turning you'll do :D
    Depends on the tire and wheel combo as well. Probably won't be doing any u turns and be real careful going up driveways.
    Better to wait if possible, I wouldn't have concerns about the tires "finding" areas to trim, but the hard body areas cutting into your tires.
  17. Aug 11, 2020 at 1:23 PM
    fighthedude
    Copy. I am running stock rims that came on the 2006 sr5. If when driving from tire store to house i notice it rubbing ill just tow it to shop. Drive is 95% freeway north to south.
  18. Aug 11, 2020 at 1:27 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    On stock rims you might rub upper arms on tires even with lift. Most of the stock rims have aggressive backspacing, more than 4.5" worth. I have seen a few guys get away with it but a lot of guys don't. Depends on the tire because some sidewalls will buldge more than others on a rim that skinny.
    A set of 1.25" hub centric wheel spacers will solve that.
  19. Aug 11, 2020 at 1:34 PM
    fighthedude
    Copy. Ill order a set of those. I was wondering if i would. When i looked under the truck the other day it was looking like they would fit but not by much. Was gonna try and get away without them. Any recommendations.... i assume set for front and rear tires.
  20. Aug 11, 2020 at 2:46 PM
    Hand Protectors
    Put about 250 miles on the truck today driving on an Isthmus and back. Smoooovvvv driving. Sad to see many of the smaller country business shut down and closed forever since the coronavirus.
    Came back into 3” of rain on the way home. Put her in 4HI like @Pucks18 suggested and she did do better with the ponding! Never had her in 4HI at 55mph.
    Pucks18, bmf4069 and Tundra2 like this.
  21. Aug 11, 2020 at 2:53 PM
    rock climber
    Spidertrax are great options and highly recommended. Bora are also good. http://www.spidertrax.com/Toyota-Hub-Centric-Spacer-Black?sc=2&category=9983
  22. Aug 11, 2020 at 3:20 PM
    Feels like every wheel is glued to the pavement. Also eats gas. But feels good.
  23. Aug 11, 2020 at 7:17 PM
    cartroub
    cartroub New Member
    Laramie, WY
    06 Tundra DC Limited
    Got tires mounted on the new rims. Pretty excited to get these on the truck next week when it gets a new suspension!
  24. Aug 11, 2020 at 7:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    God I love those wheels.
    NUDRAT likes this.
  25. Aug 11, 2020 at 7:28 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Great wheel and a great color. Good call going with gunmetal.
    Tundra2 likes this.
  26. Aug 12, 2020 at 6:28 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Nice. Dude idk but as soon as i hit over 55mph in for high my steering wheels gets a vibration and it just doesnt feel right in 4hi. I'm hoping thats not indicating a problem with my 4wd but thats only when going above 55
  27. Aug 12, 2020 at 7:52 AM
    rock climber
    Wow that looks amazing!
  28. Aug 12, 2020 at 8:10 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    What a beautiful contrast of colors! Thanks for not choosing black. :thumbsup:
  29. Aug 12, 2020 at 9:16 AM
    cartroub
    cartroub New Member
    Laramie, WY
    I never thought I'd do something like this but I'm thinking about "greying out" the emblem to match the wheels. I know most people black it out but I think that might look real good.
    Darkness, bmf4069, Brown Bear and 2 others like this.
  30. Aug 12, 2020 at 10:24 AM
    Hand Protectors
    Will look nice! I’ve thought of doing the same if my body color wasn’t a close match to the wheels. Yours being blue will be sweet!
