  1. Aug 4, 2020 at 11:42 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Finally left discount tire with everything working correctly. They ended up replacing all of the TPMS sensors. I can only assume they installed used ones last time as they were all dead (only 2 yrs old) and were unable to be scanned, the pre-pubescent ‘tech’ said.
    I still can’t believe that he tried to get me to leave with a blinking TPMS dash light saying that his Toyota does the same thing!
    Not sure I have much faith in shops these days. I just need to buy a shop,
    4-point lift, alignment machine, tire mounter/balancer...that should cover most work
    oscardog86, NUDRAT, speedtre and 2 others like this.
  2. Aug 5, 2020 at 3:45 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I didnt notice until you pointed them out. But yeah, get on that. : )
  3. Aug 5, 2020 at 5:55 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Actually, Only 270 crank stock.
    How many miles on that engine? that's pretty impressive without a supercharger.
    Thrussn[QUOTED] likes this.
  4. Aug 5, 2020 at 6:06 AM
    Would love to hear an update on the performance of your new front locker. Clamshell = lunchbox locker? I've been hesitant to lock the front because I hear some complain that it clicks around corners even when not in 4WD. I didn't think this would be the case, but would love to hear your experience. Truck looks great BTW.
  5. Aug 5, 2020 at 6:06 AM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    You can clear coat with 2k if you want however if you spray it fine enough (higher psi) I have been able to achieve a nice eggshell sheen. Like 65 to 75 psi wet on the last coat. You have to play with it but it's a game changer. I backed up into a hitch the other day and it didn't even scratch just dented my bumper :dancingbacon:
    Outbound[QUOTED] likes this.
  6. Aug 5, 2020 at 6:08 AM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    Check sway bar end links and grease your slide shaft in the back real good. Search forum for procedure
    Spobrien84[QUOTED] likes this.
  7. Aug 5, 2020 at 8:37 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    10-15 if it’s an internal amp in the radio. That’s going off other radios of the same vintage
  8. Aug 5, 2020 at 8:39 AM
    empty_lord
    05 rollover special
    The button is used to reset the lights on pressure. So tired inflated to 30psi, the light will come on at 25 if you press and hold that button. It’s a reset that sets the light on to w/e is about 5 psi less than you have in your tires.
  9. Aug 5, 2020 at 9:06 AM
    robabeatle
    AZ
    Little hint as to what I did this morning: (ignore the grill!)
    NUDRAT, Lil Steve, bmf4069 and 2 others like this.
  10. Aug 5, 2020 at 10:07 AM
    Dammit man, re-aim those things already! (j/k)
    robabeatle[QUOTED] likes this.
  11. Aug 5, 2020 at 10:12 AM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    That's true. It's interesting how the 05 makes 282 at the crank and the next year with the exact same engine makes 271. I remember reading about all the controversy.
    I just rolled over 109k miles.
  12. Aug 5, 2020 at 10:24 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    What's up with that grill?
  13. Aug 5, 2020 at 10:38 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I guess I know what I’m doing tonight...
    Darkness and bmf4069 like this.
  14. Aug 5, 2020 at 11:21 AM
    It'd be fun if pushing the big EXTRA BASS button made four 15s fold up where the rear seat once was.
    bmf4069 and lsaami[QUOTED] like this.
  15. Aug 5, 2020 at 11:53 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    The display looks to be easy on my aging eyes, please share your thoughts about your new HU once you get some time with it.
    lsaami[QUOTED] likes this.
  16. Aug 5, 2020 at 12:30 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Will do!
    I chose this one because it has a built-in 45wx4 RMS amp. Will bump a lot harder than most stock or aftermarket head units.
    Darkness and Lil Steve[QUOTED] like this.
  17. Aug 5, 2020 at 12:38 PM
    robabeatle
    AZ
    I fubarred it with a dual action polisher.
    bmf4069[QUOTED] likes this.
  18. Aug 5, 2020 at 12:55 PM
    Daaaaaaamn, I thought that was just electrical tape and you were dicking around with how a blacked out grill and bumper would look.
  19. Aug 5, 2020 at 12:58 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    My drive home was about 35-40 mins and didn't hear any clicking. It should only make that noise if in 4x4 and I think on the pavement which is why I went with it over an e-locker or air locker. It's considerably cheaper and won't be needed unless I'm already offroading.
    speedtre likes this.
  20. Aug 5, 2020 at 1:45 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Did you ever do the diff drop? Recommended?
  21. Aug 5, 2020 at 1:49 PM
    robabeatle
    AZ
    Nope, but it is an easy fix and I may just take off the plastidip and leave it.
  22. Aug 5, 2020 at 2:18 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I was looking for a truck for my nephew and I found this for a price I couldn't pass up
    So I bought it and sold my 2001 access cab to my nephew.
    Also, bought that sequoia in the background for $750, needs some serious love, but I have 4 kids and we do a lot of roadtrips, so it will be a much better family car.
  23. Aug 5, 2020 at 2:52 PM
    Professional Hand Model
    Hand Protectors
    Whats up with that grille? :D
    @bmf4069 did you see his grille?
  24. Aug 5, 2020 at 3:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Looks to be in great shape. Always loved that color too
    oscardog86 and Dog like this.
  25. Aug 5, 2020 at 3:26 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Congrats. I love that color.
    Darkness and Dog like this.
  26. Aug 5, 2020 at 3:51 PM
    robabeatle
    AZ
    bmf4069, Darkness, CodyP and 2 others like this.
  27. Aug 5, 2020 at 4:35 PM
    Hand Protectors
    Changed the oil and filter today after about 3500 miles use. All went well. Nice having a used oil drop centre down the street.
    Still have enough oil for 2 more changes from that bulk purchase made 2 years ago. Thought I was smart in stocking up with 50 quarts at the time. Just checked Wallace Wurrlld and Mobil 1 is cheap still. Shoulda held off in retrospect. :annoyed::rofl:
    Gives me the reason to change early and often. :yes:
    FrenchToasty likes this.
  28. Aug 5, 2020 at 6:01 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Nice color!
  29. Aug 5, 2020 at 7:36 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Boom! Deck installed! Crutchfield is awesome. I soldered and heatshrinked all my connections. It feels so good when you do a wiring harness right.
    Filthyphil, speedtre, bmf4069 and 4 others like this.
  30. Aug 5, 2020 at 7:43 PM
    Lil Steve
    Gilbert, AZ
    Rampage7 and lsaami[QUOTED] like this.
