  1. Aug 2, 2020 at 10:47 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Tried to install the 07-13 tundra steering wheel in my truck only to realize that I will need an airbag, and back cover as well...I’m such a tard sometimes. Guess it’s off to the junkyard soon.
    edit:
    The controls are different so I’m sure the plug will be different too! :( this is gonna be more trouble than it’s worth
    bmf4069 likes this.
  2. Aug 2, 2020 at 11:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the airbag should be plug and play. the wheel controls will be a different plug, but you can put the pins into a correct plug easily. ultimately i wish to do the 07-13 tundra wheel swap
  3. Aug 3, 2020 at 4:10 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So how was it? How many hours? Mines just sitting waiting for cooler weather.
    Tundra2 likes this.
  4. Aug 3, 2020 at 7:28 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    The cover for the airbag is different
  5. Aug 3, 2020 at 7:59 AM
    empty_lord
    05 rollover special
    Cover is. The connectors are the same. You need the airbag assembly
  6. Aug 3, 2020 at 8:05 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Ok so I’ve gotta buy a new airbag, and steering wheel controls.
  7. Aug 3, 2020 at 9:54 AM
    empty_lord
    05 rollover special
    Yes and you will probably have to unpin the wheel controls connector and unpin your original connector. Then put the new steering control pins in the older connector (you will need wiring diagrams!)
  8. Aug 3, 2020 at 1:58 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I thought you liked the 4runner wheel better? This is still on my to do list, should I change plans and go with the newer Tundra wheel?
  9. Aug 3, 2020 at 2:04 PM
    rock climber
    Are you bypassing the JBL amp and going straight to the speakers from the headunit?
    I haven't done mine yet, just been researching so take this with a grain of salt. I think the small harness you showed is for the steering wheel controls, pin 6 is ground, pin 7 connects to light green/red, pin 8 connects to brown/white with yellow stripe.
    On the main harness, pin 1 is 12v, 2 is illumination, 12 is accessory and 20 is ground.
    I found a thread with the is document from Crutchfield that's really helpful.
  10. Aug 3, 2020 at 3:29 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    It took me a while. Probably 10 hours spread over two days. It honestly wouldn't have been that hard if I knew what I was doing up front.
    bmf4069[QUOTED] likes this.
  11. Aug 3, 2020 at 4:05 PM
    empty_lord
    05 rollover special
    Wheel design fits the 1st gen better from a 2nd gen style doesn’t stick out design wise
  12. Aug 3, 2020 at 4:30 PM
    Outbound
    Aaron
    Northern Alberta
    Gave the ol' girl a wash today. Nothing too crazy, since it'll probably rain again in a day or two. I did notice that my paint job on the grille and that strip below the grille has started chipping and chrome is showing. I need to find a more permanent solution.
  13. Aug 4, 2020 at 2:44 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Added sticker I made at work. Just because.
    :p
    oscardog86, NUDRAT and bmf4069 like this.
  14. Aug 4, 2020 at 3:40 AM
    brobert225
    brobert225 Firm grasp of the obvious
    What kind of lights did you use? Great idea.
  15. Aug 4, 2020 at 3:42 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Led strip lights.
    The write up is here. I haven't added in all materials I used as this job isn't quite done yet.
    NUDRAT likes this.
  16. Aug 4, 2020 at 10:01 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    anyone know home many amps are supplied to the stock radio?
  17. Aug 4, 2020 at 10:14 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Should just be one, right?
    FrenchToasty likes this.
  18. Aug 4, 2020 at 10:15 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    amps as in unit of power measurement, not amps as in amplifiers.
  19. Aug 4, 2020 at 10:18 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    :facepalm:
    My bad. I was wondering why you worded it like that.
    Darkness likes this.
  20. Aug 4, 2020 at 10:27 AM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    Raptor with etching primer
    :duel:
    Darkness and Outbound[QUOTED] like this.
  21. Aug 4, 2020 at 11:20 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Agreed. I think red and white is the worst as far as holding up. Dark green ones are holding up very well too, mine is and so is my neighbors
  22. Aug 4, 2020 at 11:33 AM
    Red metallics and green metallics are the ones I see most often with clearcoat peel here in the southeast. Usually starting above the windshield first, then the hood, then the bolt-on fender flares. The more horizontal the panel is, the more I see clearcoat peeling.
    White holds up great, but it's a different type of paint than the metallics (single stage vs multi-stage). Because solid colors have no clearcoat like the metallics do, owners must seal and wax the paint regularly or the paint chalks. Once it gets chalky, it only takes a quick polish to get it gleaming again.
    Decent sample of single-stage correction in in my signature. Black suffers from same, and I think there's also a single-stage grey used between 00-06.
  23. Aug 4, 2020 at 12:11 PM
    Outbound
    Aaron
    Northern Alberta
    Does it come in gloss so it will somewhat match the paint?
  24. Aug 4, 2020 at 12:30 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    BMF is still probably pretty close to accurate lol
  25. Aug 4, 2020 at 1:23 PM
    Spobrien84
    Spobrien84 New Member
    2006 Tundra limited
    HELP I keep hearing a loud clunking noise when I come to a complete stop from 45mph and above. It clucks right after stopping from the front end and its pretty loud. was wondering if anyone had this issue thank you for your time its a 06 4x4 double cab
  26. Aug 4, 2020 at 1:25 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Gotta be a function of the volume knob.
    Changed the rear dif and transfer case fluids today. The rear dif fluid looked like dirty water but the transfer case looked fine. When I got up to put away the creeper after the transfer case was torqued up, I heard a "ting." Looked down and saw a washer on the ground. Oh no. Luckily it was for the fill plug and not the drain plug!
    Also made a small adjustment on the front/rear brake bias. Didn't notice a difference on a quick drive.
  27. Aug 4, 2020 at 1:30 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Check out your front end/suspension components with emphasis on the lower ball joints.
  28. Aug 4, 2020 at 1:38 PM
    LCZJTRD
    LCZJTRD New Member
    2020 super white Tundra TRD
    Did the I’m behind you amber lights... Pic from last night
  29. Aug 4, 2020 at 1:57 PM
    robabeatle
    AZ
    Now wait, did I wander into the wrong room...
    :D
  30. Aug 4, 2020 at 2:09 PM
    LCZJTRD
    LCZJTRD New Member
    Lol! I did!!!! Hahahaha!
    Darkness, bmf4069 and robabeatle like this.
