  1. Jul 19, 2020 at 11:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Neat.
  2. Jul 19, 2020 at 11:42 AM
    Professional Hand Model
    Hand Protectors
    Fabbed up some Redundant Grounds out of some scrap Copper laying around in the name of Wurrld Peas. Discovered the Grounding Bracket behind the pass side valve cover was a little loose. I tightened the wire clamp bolt last year, but didn’t realize there was a bracket which it was attached. Removed the bracket and cleaned up the contacts as they had some corrosion. Lots of work for such a little job due to access tightness between firewall and engine. The Grounding Wire Fab was easy.
    hammeron, bmf4069 and Tundra2 like this.
  3. Jul 19, 2020 at 11:51 AM
    Hand Protectors
  4. Jul 19, 2020 at 12:00 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    @Tundra2 You guys do realize that unless you are getting a bigger filter with the same bypass valve pressure you could potentially starve your engine of oil when cold and or operating temp????????
    Bigger isn’t always better
    oscardog86 and NUDRAT like this.
  5. Jul 19, 2020 at 12:03 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Also, while at work today I tried to add the hellwig helper leaf spring...my u-bolt nuts are too tight and I have no PB blaster here...guess I’ll have to replace at home instead. I DID however buy a new driver ‘racing seat’. Hugs nicely AND has TWO cup holders to boot!
  6. Jul 19, 2020 at 12:06 PM
    Hand Protectors
    YZZD-3 OEM spec’d.
    oscardog86 likes this.
  7. Jul 19, 2020 at 12:08 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yep, that's all I use...cheap and available in OEM Toyota packaging at my local walmart...which is crazy that they carry an OEM part.
  8. Jul 19, 2020 at 12:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Went to denso site, and found part number for my oil filter per them. Denso# 150-2010.
    There is no scale for reference, but it appears to be a "mid-size" oil filter. Larger than the Fram PH3614, and smaller than the Fram PH3600.
    No local wully wurl action for me. Nearest store that has them is about 1.5 hours from here.
    They are now in the parts list I've slowly been generating.
    While I was on the denso site I recon'd the plug wire part # to replace my dura-last "oh shit, i have a bad plug wire in the middle of the week" repair from 2-ish years ago.
    Edit: will go OEM on the plug wires. My plug wire clippy things for wire routing don't want to clip anymore. OEM part number comes with clippies. Toyota# 19037-62010
    Also, the coil packs. I'm sure after 315k that mine are probably worse off than @Professional Hand Model's were per his build page.
  9. Jul 19, 2020 at 1:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I approve of the clean look of your solder job.
  10. Jul 19, 2020 at 1:04 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Does anyone know what this piece is or who makes it?
    It came from my left bed tie-down spot near the tailgate (had to remove for assist strut). Wondered if it was worth selling.
  11. Jul 19, 2020 at 1:06 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The bigger issue here is he’s running a fram. On my 3.4 I ran a yzzd3 (sane as the 4.7 filter)
  12. Jul 19, 2020 at 1:07 PM
    empty_lord
    05 rollover special
    It’s the bracket for a bed extender
  13. Jul 19, 2020 at 1:27 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yes, Fram are junk as much as K&N air filters are bad for your engine
    artsr2002 likes this.
  14. Jul 19, 2020 at 1:38 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's absolutely brutal here. Been working outside in the 100 degree heat for 5 hours.
    -applied a few more coats of primer to the sliders.
    -cleaned frame in preparation.
    -cleaned out AC drain nipple.
    -loosened pivot bolt on the UCA's and got in as much grease as I could. Bounced the front in a few times.
    -discovered a lot of the bolts on the new bumper had loosened. Tightened them back down.
    -drank a pool's worth of water.
    I'm shirtless and commando and I'm still too hot. I'm really hoping the squeaking stops.
    Darkness, bmf4069, Tundra2 and 2 others like this.
  15. Jul 19, 2020 at 1:59 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    That's it, thanks! Appreciate your knowledge.
    empty_lord[QUOTED] likes this.
  16. Jul 19, 2020 at 3:48 PM
    Casper421
    In the woods
    06 DC
    Took her to a lake.
  17. Jul 19, 2020 at 4:04 PM
    Hand Protectors
    Thank you. I got lucky. I feel I’m getting better MPG now, too. :D
  18. Jul 19, 2020 at 4:13 PM
    Hand Protectors
    For an extra $2 a filter you can get these from Big Gurrl. Works out to $5ish each if you buy a 5 pack.
    Check your Manual for the V6 filter as I’m not familiar with that Spec. Toy makes a YZZD-1 that is smaller. Both fit my truck, but the 3 is the Spec.
    oscardog86 and FrenchToasty like this.
  19. Jul 19, 2020 at 4:38 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    What have I done...
    bmf4069, Tundra2, oscardog86 and 4 others like this.
  20. Jul 19, 2020 at 5:13 PM
    Blasphemy!
    Pretty sure the head unit will always say have "JBL" logo screened into it. You may or may not see it on the amp and OEM speaker grilles, I didn't start seeing JBL logos on the speaker grilles until Gen2 or later (not necessarily on the Tundra though, I recall seeing it on Highlanders though). It may also show up in the Toyota specifications site, which lists all paid factory and port options added to your truck with other details, just punch in your VIN#: https://www.toyota.com/owners/my-vehicle/vehicle-specification
    Yep. My OEM alternator croaked in a wild array of sparks, a few flickers of flame, and lots of smoke last October. Luckily it didn't take anything with it. Hopefully the Denso reman replacement lasts that long.
    Looks awesome!
    robabeatle[QUOTED] likes this.
  21. Jul 19, 2020 at 5:15 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    For sure. My 01 camry xle has jbl on the speakers themselves but maybe the tundras didnt start till gen 2
    shifty`[QUOTED] likes this.
  22. Jul 19, 2020 at 5:18 PM
    Thanks to @Roman for getting my order processed to fill some odds & ends on the truck, I unpacked got most of what I need to fully upgrade to wood today. I think all I have left at this point is the dash bits and I'm there. I was super stoked the cupholder came as the full assembly with new foams! I just replaced my front foams a few months back.
    Hop to get this in over the next day or three.
    Roman, Bulldog_tundra, Dog and 2 others like this.
  23. Jul 19, 2020 at 5:25 PM
    Pucks18
    Oh, u have a v6 tundra? Didnt know that! Nice though i hear those are equally as reliable
  24. Jul 19, 2020 at 5:31 PM
    Hand Protectors
    Ordered up some Engine Bay Tape to finish off the wiring work done in there. I’ll redo some of the other areas I’ve taped with the Super 33 over the last 2 years.
    bmf4069 and theblurry1 like this.
  25. Jul 19, 2020 at 6:20 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    That will take you all of 10 minutes to install - 15 if you clean up all the gunkies underneath before reinstalling...
  26. Jul 19, 2020 at 6:21 PM
    Dog
    Dog sit!
    Nice lake, looks great. But definitely no Professional Foot Model jobs in your future...:rofl:
  27. Jul 19, 2020 at 6:34 PM
    Cupholder will take all of 30 seconds to install, I'm tempted to go do it now but pics suck at night :D
    Trouble is work and two kids eat about 16-18 hours a day, so I often need to scrape together minutes to work on bikes and the truck.
    FrenchToasty likes this.
  28. Jul 19, 2020 at 6:43 PM
    Hand Protectors
    bmf4069, CodyP and FrenchToasty like this.
  29. Jul 19, 2020 at 6:52 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    What filter brand is not junk in your opinion?
    Pucks18 and NUDRAT like this.
  30. Jul 19, 2020 at 8:38 PM
    Casper421
    In the woods
    06 DC
    Thanks? :crazy:
