  1. Jun 29, 2020 at 5:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    He's gonna tell you to check his build page, and may even post a link. Lol
  2. Jun 29, 2020 at 5:15 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Already checked, there's not one. Unless you're saying you know him so well, he'll post one there; in which case you might be right.
  3. Jun 29, 2020 at 5:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Naw, I don't know the mysterious Hand model.
    Just idolize him. :oops:
    I could have sworn there was a night time pic of it on his build page.
  4. Jun 29, 2020 at 5:18 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Since all my front suspension work is done (for a long time, I hope), including the diff drop I did last night, I finally got the skid plate back on. I know it's a hassle to remove and most say they don't need it, but I like having the extra protection down there.
    Didn't realize the plastic side guards wouldn't go back on after the lower bumper trim delete...
    So, achieved with removable zip ties, I present my jankest mod yet:
    MS22, abcinv, bmf4069 and 3 others like this.
  5. Jun 29, 2020 at 5:18 PM
    Professional Hand Model
    Hand Protectors
    MS22, Lil Steve, abcinv and 4 others like this.
  6. Jun 29, 2020 at 5:21 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    You're the best. I need those courtesy lights in my life even though they're not a necessity. I wonder if I could find some to match all my interior LEDs from SuperBrightLEDs.com, they're more of a greenish white.
  7. Jun 29, 2020 at 5:27 PM
    Hand Protectors
    Give it a check. These were recco’d by @Festerw on Big Gurrl. They said white in the description, but have a little blue in them in person. They are cheap and easy to install and well worth it. The light hits right were you want it when opening the door. Another member did theirs and used longer strips for more light. You could even do the back doors if you wanted. In total, it was about $10 for the strips and another $10 for T-Clamp Crimp Fittings (large multi-size box). Took about 3 hours total.
    theblurry1[QUOTED] likes this.
  8. Jun 29, 2020 at 5:36 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Mine has some zip tie engineering too. Mostly from a hidden ditch breaking all the plastic doodles out.
    Functionally the same and you can't see it until you're underneath so who cares?
    MS22, bmf4069, Tundra2 and 1 other person like this.
  9. Jun 29, 2020 at 5:39 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'd look for a local A/C place. They'll be able to test everything out for you before spend the loot on unnecessary parts.
    NUDRAT, FrenchToasty, Tundra2 and 2 others like this.
  10. Jun 29, 2020 at 6:25 PM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Disclaimer: I’ll gladly admit I know nothing beyond basic maintenance on cars and can only fix issues once I research what parts are called and reading threads.
    What is this and is it normal? Looks like a leak. I don’t like leaks. This is also why I avoid crawling under my vehicles and start poking around bc my OCD takes over and now I have to fix said “leak”.
    theblurry1 and Tundra2 like this.
  11. Jun 29, 2020 at 6:30 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Looks like I’d consider that a seep, from the transmission output seal
    speedtre likes this.
  12. Jun 29, 2020 at 6:31 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    First time posting here. All of you are a wealth of information and I'm glad I found the site! I replaced my drive belt, tensioner assembly, and idler pulley today...it was a bear to get the tensioner assembly on. I have a Haynes manual and they skipped the part where you have to take off timing belt cover, alternator, and PS pump off to get the damn thing out lol I budgeted for about 2 hours of wrenching and had to call off plans to extend to 4 hours. Anyways it's done and I'm happy I got a new belt on, it was weather cracked badly and had pebbles imbedded in it. Also tensioner bearing was badly worn. Thanks Haynes lol
    MS22, speedtre, bmf4069 and 7 others like this.
  13. Jun 29, 2020 at 6:53 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    Wonder if this could be related to the annoying pop I’m hearing when I punch it from a stop.
    Already have it going in for new U-joints and the carrier bearing later this week.
    Tundra2 likes this.
  14. Jun 29, 2020 at 8:13 PM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    Brute force fab?
  15. Jun 30, 2020 at 3:26 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Si!
  16. Jun 30, 2020 at 4:45 AM
    Hand Protectors
    Darkness likes this.
  17. Jun 30, 2020 at 5:00 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    And no pics of the trucks together? I call shenanigans.
    Welcome! Feel free to poke around and ask any questions you may have!
  18. Jun 30, 2020 at 5:01 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Also, welcome to the devil's page. :devil:
  19. Jun 30, 2020 at 5:50 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I listened to this in my Tundra this AM and this seemed appropriate to post it here....
    Lil Steve, NUDRAT, jImmegart and 5 others like this.
  20. Jun 30, 2020 at 7:31 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
  21. Jun 30, 2020 at 12:47 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    trying to find out if i am missing a bolt on the tail of my trans (02 2wd)
    found late last night when under it, just looked again after getting home from work
    clearly a threaded hole about 1/2" deep
    does not look like it would do anything to me
    have a buddy at a yota shop looking into it on tech info system
  22. Jun 30, 2020 at 1:19 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I haven't looked to see the replies you've received yet, but I had this happen to myself when I was trying to charge my system to make it colder. The compressor actually would turn itself off when there's too much pressure. I would assume it's a safety thing. I ended up using my friends vacuum and ac charging system to fix what I messed up in the first place.
    If you aren't worried about the environment, I'd recommend relieving quite a bit of pressure from the system and seeing if the compressor fires up again.
  23. Jun 30, 2020 at 2:32 PM
    Hand Protectors
    Corrected the Angle of the Dangle on my wiper nozzles specifically the passenger side. Driver side has always been in perfect symmetry. The passenger side was shooting high and to the Starboard side Captain. Used a thin shim made from a thick plastic clear bottle. Cut it into a small sliver and put a bias on the tip so as it would slip under the base. Turns out this is how you remove the nozzle because the tab released when doing so. :D
    Anyhow, ended up working a small sliver under and cocking it to the center. Everything is nicely lined up. Might use some Gorilla Glue Double Sided Tape from the underside hood holes to keep things locked in place for the long term vibrations.
    I did use a specialize fine pointed file to experiment with boring the nozzle holes just slightly larger. Mostly I was just cleaning the brass tip of the hole. I’m thinking of cutting a horizontal slot across the brass pin holes to mod these into a wider spray action. :yes:
    theblurry1 likes this.
  24. Jun 30, 2020 at 3:44 PM
    Hand Protectors
    3 of 4 holes I was able to file horizontal slots and adjust the sprays a little more course mist versus direct pin jet nozzle stream. The 4th Hole the file tip snapped BUT due to the shape of the specialized file tip it makes for an awesome fine mist that I wish I could replicate on the other 3! :rofl:
    bmf4069, shifty` and Thrussn like this.
  25. Jun 30, 2020 at 3:49 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I could be incorrect and often am but I think the sprayer nozzles are able to be moved. Like stick a small needle/drill bit in there and aim them.
    MS22 and FrenchToasty like this.
  26. Jun 30, 2020 at 3:56 PM
    Jstarr
    Jstarr New Member
    Jonathan Starr
    2000 silver 1st Gen Tundra, 2017 Tacoma TRD OR, 2020 4Runner TRD ORP, 1994 Jeep Wrangler
    Replaced the OEM rear shocks with new Bilstein 5100s. Pulled the front coilovers and dropped them off, along with replacement front Bilstein 4600 shocks, at my helpful truck repair guy to switch out the springs for me. 20 years and 115,000 rough miles on the old Bilsteins, it was overdue and I cannot complain. Also added refrigerant to the AC, and it is cooling again!
    Darkness, bmf4069 and theblurry1 like this.
  27. Jun 30, 2020 at 5:33 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    Well, it’s not for the audiophiles, but it gets me the Bluetooths and a microphone to talk to the old lady on the road. Speakers even sound better to boot. $75 well spent, I think at least.
    It does annoy me bc I don’t like anything but a stock “look”, but I squinted real hard and the glass and green text matches the clock - I found a way to justify it.
    MS22, Darkness, bmf4069 and 2 others like this.
  28. Jun 30, 2020 at 7:52 PM
    Thrussn
    Gabe
    NM
    Decided to wax the ol girl since it's been a couple months. She's slippery, shiny, and faster now of course.
    I've been seriously thinking about a 4wd swap and a guy parting out an 05 double cab told me he would give me the axles, diff, trans, transfer case, ECU, and the center panel with the 4wd buttons for $500. I feel like the offer is too good to refuse.
    I understand a swap is irrational, but my tundra is super sentimental not including all the money and time I've put into it already.
    What do you guys think? I think the ACC cab and Double cab share all those same parts.
    Edit: Congrats on reaching page 666
  29. Jul 1, 2020 at 4:10 AM
    Toyotundra06
    Toyotundra06 New Member
    Donald
    2006 Silver Tundra Access Cab
    Well its not been done yet but this weekend I get to do All 3 U-Joints this weekend.
    Had a vibration that I chased for a couple days till my airheaded self finally climbed under it.
    .....well they made it 140,000 before deciding to go
    Good news is I have the joints being shipped from Rock Auto that should be in tomorrow!
    And my new radio should be in today.
    speedtre, MS22, bmf4069 and 4 others like this.
  30. Jul 1, 2020 at 4:15 AM
    Hand Protectors
    Take pics!
    bmf4069, Thrussn and theblurry1 like this.
