  1. Jun 27, 2020 at 4:40 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Darkness and theblurry1 like this.
  2. Jun 27, 2020 at 4:43 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I still wonder why I spent the money on a stock bumper. But meh. I can probably sell it easy enough when I upgrade
    jImmegart likes this.
  3. Jun 27, 2020 at 4:44 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Got back from camping/fishing at my mountain top lake, didn’t get many pics, I was busy having fun. I had a monster trout on, knew the hook wasn’t set, tried to set it, but the hog jumped off 5’ from the paddle board. I’ll add more pics when momma bear sends them. The truck ran great, got snubbed by some turdgens coming up the mountain, like bro, no ones gonna see you waving at a 1st gen don’t worry! D7B151D2-A55F-49FB-A3A3-C178987257F5.jpg
    Elote!
  4. Jun 27, 2020 at 4:57 PM
    Professional Hand Model
    Hand Protectors
    Good idea. You might try cleaning up and spraying some Aerospace 303 on your existing gaskets. You can also wipe down the doors contacts points where they meet the rubber and spray them, as well. Another trick is to bend and fluff your gaskets and tighten all your door hinge bolts.
    I’d recco visiting my build page and address all the leak points on our trucks first before going full banger on that video. The main wind noise I knocked down with Butyl Tape was at the A pillar where the door gaskets are attached at the windshield bracket. The second best thing was adding a combination of Butyl and Fiber Matting in the doors. Good video idea, but you may not need it.
  5. Jun 27, 2020 at 5:37 PM
    Hand Protectors
    Bump on this. Anyone change out their Cam/Drive Shaft Seals? Can the Cams Seals be done by pulling out and pushing new in? Or, does the Cam Shaft Shroud need removing? FSM is unclear.
  6. Jun 27, 2020 at 6:23 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    I love the look of the shortened rear quarter.
  7. Jun 28, 2020 at 7:37 AM
    Casper421
    In the woods
    06 DC
    Watched some guys fix a 3rd gens brakes and another get high centered after running Poker Flat yesterday.
    00B681A9-AEB6-48FF-9756-B9D8D57FD783.jpg 3751E48F-4063-462D-8A63-FDE7A768D5E8.jpg52B9D2E4-AD0A-4ED2-B6E7-0B652D2F70AB.jpg
  8. Jun 28, 2020 at 7:52 AM
    empty_lord
    05 rollover special
    lol 1st gen best gen
  9. Jun 28, 2020 at 7:57 AM
    JustGotDuals
    JustGotDuals New Member
    Made my own mesh grille to accomodate for the light bar that was way larger than expected. Should have bought a dremel to cut the grille because the angle grinder is too big, but it turned out alright for $10!
  10. Jun 28, 2020 at 8:05 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Yesterday I confirmed the gain in power from adding a tailpipe to my exhaust. There’s a certain hill on the way to my parents house that will require the truck to downshift to maintain 60mph.
    after adding the tailpipe, it maintains 60mph in overdrive. Not a huge difference, but I’d call that noticeable.
  11. Jun 28, 2020 at 9:09 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think I know a guy who can answer that. Ahem, @empty_lord, aka sexy voice over man, we have a question for you!
    Darkness likes this.
  12. Jun 28, 2020 at 9:17 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wonder if that would stop my doors from shaking on rough roads. Good idea.
  13. Jun 28, 2020 at 9:21 AM
    empty_lord
    05 rollover special
    I believe you can. The VVTi motors are totally different
  14. Jun 28, 2020 at 9:41 AM
    Hand Protectors
    Worked some Mojo on the truck today addressing some loose stuff.
    1) Used some Metal Roof Screws with Rubber Washers in place of the wallowed out plastic holes Hinges. Glove Box solid! The Console Screw over to the left is the same type and from last year.
    2) Access Cab door rattle fix? Fabbed up two Composite Shims junior wedges and affixed them on the door under jamb as pictured with Gorilla Tape for temporary testing. Took drives in Scientific Test on same patch of rough road with windows up and down each way. Once with wedges. Once without. Success!
    NUDRAT likes this.
  15. Jun 28, 2020 at 9:44 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    will rub threshold paint. keep waxed.
  16. Jun 28, 2020 at 9:47 AM
    Hand Protectors
    Uncanny timing. Check what I just posted. The wedges keep the larger front doors from clacking down during rough roads.
    Darkness[QUOTED] likes this.
  17. Jun 28, 2020 at 9:48 AM
    Hand Protectors
    Still working the Mojo Factor on it. Moving into Black Belt Level now.
  18. Jun 28, 2020 at 9:53 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    You could hot glue one to sill, one to door. they'd only rub each other.
    Full roll cage would tighten up the cab...
  19. Jun 28, 2020 at 9:55 AM
    Hand Protectors
    Thinking Double Sided Tape for now. Fuzeit is a back up. Not to worried about rubbing, as the composite is slick. Might mount it so the sill protector is in play.
    Tundra2 likes this.
  20. Jun 28, 2020 at 10:42 AM
    Hand Protectors
    Got it dialed. Doors have just enough back/neutral pressure on them from the wedges that when the fronts are latched up with the solid rear doors it becomes a Wurrld Peas thing of beauty. All is love and nobody gets rattled. Doorslives matter.
  21. Jun 28, 2020 at 10:48 AM
    Hand Protectors
    Got the inside plastic wiped with ‘sunscream’. Washing her up and she lookin’ fine!
  22. Jun 28, 2020 at 11:38 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Played around with the gun case foam and found a place for the coin holder. I'll clean up the gold sharpie marks with a black sharpie in a bit. I have three layers of 1/4" with the top cut out but think I'll cut out one more layer to tuck it down a little more.
    Not much but cleans it up a little...
  23. Jun 28, 2020 at 11:41 AM
    Hand Protectors
    Those coins are, and have always been, in perfect symmetry! The Wurrld will tilt off axis if you move them.
  24. Jun 28, 2020 at 11:44 AM
    abcinv
    Tommy
    NW Georgia
    This community needs to set you up with a coin holder. I'll add to the pot...
    Oh, got into my birthday stash as well, hit 51 earlier in the week -
  25. Jun 28, 2020 at 11:46 AM
    Hand Protectors
    That would be nice! I was out measuring my hand lotion bottles and the coin holder might effect their storage. It will be close.
    NUDRAT likes this.
  26. Jun 28, 2020 at 11:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Congrats.
    Cheers!
    Thrussn and NUDRAT like this.
  27. Jun 28, 2020 at 11:47 AM
    Hand Protectors
    I’ll second that!
    Thrussn, NUDRAT and Tundra2[QUOTED] like this.
  28. Jun 28, 2020 at 12:43 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I thought someone was going to hook you up with one recently. Did @lsaami not have one in his part-out truck?
    lsaami likes this.
  29. Jun 28, 2020 at 1:34 PM
    Hand Protectors
    Operation Revenge of the Zzzzzzzttttt!!! Success!
    Remember I made a rare hand model slip with the foil tape and sizzzzllled my Map Light Switch (pass side switch). That then gave me an idea to do the ‘Jumper Mod’ so one push lit up both lights. @theblurry1 sent me a New Map Light about 6 months ago that he scored at a junkyard. Today, I removed the Light Assy Portion out of his and installed it in mine. Now, the pass side switch works along with the drivers side. You can push either side and both lights come on.
    Also, I removed the metal Lens Covers way back in another mod. Lets out more light instead of just through the little magnifier. These pictured ones are gnarly yellow compared to the ones already on my Assy. and are for information use. Not sure if I put this mod in my Build Page as I lost many pics in a device change over. See pics.
    bassman417, artsr2002, abcinv and 4 others like this.
  30. Jun 28, 2020 at 2:18 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Hey y'all,
    My AC blows hot and the light blinks. Replacing the relay didn't help. When I hook up the gauges to add new refrigerant the low side is in the red (really high). Doesn't seem like the compressor is kicking on.
    Did my compressor go night-night? It looks original. Has anyone replaced one before, and if so what parts did you also replace? Compressor looks like it's about $200, after doing it myself I could probably take it to a shop so they could vacuum pump the moisture out of the system.
