  1. Nov 7, 2018 at 6:18 PM
    #1921
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    Used it to take the trash out at work :rofl:
  2. Nov 9, 2018 at 8:31 AM
    #1922
    WutsaZJ
    WutsaZJ New Member
    2006 Double Cab 4x4 trd offroad
    5100s, 285 wildpeaks, snugtop,rear bags, and a bunch of plastiderp
    Rebuilt my JBL door speaker.
  3. Nov 9, 2018 at 2:34 PM
    #1923
    Professional Hand Model
    Hand Protectors
    Are these the original speakers? What is the rebuild process?
  4. Nov 9, 2018 at 2:38 PM
    #1924
    WutsaZJ
    WutsaZJ New Member
    Original JBL speakers. Bought the rebuild kit because my passenger door speaker foam was wasted and sounded like trash. Rebuild kit was 25 bucks for two speakers. Theres a step by step video on YouTube that walks you through applying a new foam ring.
  5. Nov 9, 2018 at 6:36 PM
    #1925
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    So I bought a rear.bumper a couple weeks ago that needed some love. So I got aalocal TW/TTC member, Nathan of Trail Toys to do some work on it. Here' a few sneak peaks. Next weekend I should have time to install it and wire some reverse lights.
    Before
    After
  6. Nov 10, 2018 at 12:47 PM
    #1926
    Outbound
    Aaron
    Northern Alberta
    Winter tires are on. Studded Nokian Hakkapellita 8's.
  7. Nov 10, 2018 at 2:45 PM
    #1927
    Casper421
    In the woods
    06 DC
  8. Nov 10, 2018 at 2:53 PM
    #1928
    Hand Protectors
    What are these lime greens?
    Darkness and because_wumbo-truck like this.
  9. Nov 10, 2018 at 3:07 PM
    #1929
    Casper421
    In the woods
    06 DC
    A product every black vehicle owner should have, https://www.jamhandle.com/
    TRD-tv and Darkness like this.
  10. Nov 10, 2018 at 3:17 PM
    #1930
    Hand Protectors
    Installed the new rear diff breather with an extension going up to behind the gas cap door area. Used about 5’ of 3/8” inside diameter rubber gas hose. Perfect fit diameter.
    Inspected around for this transfer case breather. Its located on the very top of the case in a difficult spot to reach. Did some arm yoga and was able to put my hand on the cap. It was stuck in one postion. Spun it and tapped it multiple times until the spring action kicked in. Squirted it with PB blast. Spun it again and feels like the factory action is working on it. Good thing because it is in a difficult location to replace.
    Teflon sprayed the upper control arm bushings. Looked at the upper ball joint. Is there any benefit to lubing these joints? Mine are the OEM originals and are still in great shape per the service techs that rebuilt the front end a few months back. Feels like there is no more grease in the rubber. Thinking about getting a needle and injecting some grease in there.
    Whatcha think?
    Rheywood456 likes this.
  11. Nov 10, 2018 at 3:19 PM
    #1931
    Hand Protectors
    Man thats next level stuff. Two, three, or 4 finger choices!
  12. Nov 10, 2018 at 3:20 PM
    #1932
    Casper421
    In the woods
    06 DC
    It’s the little things in life.
  13. Nov 10, 2018 at 3:21 PM
    #1933
    Hand Protectors
    Thats what she said.
  14. Nov 10, 2018 at 5:55 PM
    #1934
    because_wumbo-truck
    Jon
    Houston, Texas
    To make your door visible at night?
  15. Nov 10, 2018 at 5:58 PM
    #1935
    Casper421
    In the woods
    06 DC
    Can’t see it when the doors closed.
    Matty4wd likes this.
  16. Nov 10, 2018 at 9:20 PM
    #1936
    Matty4wd
    Matty4wd Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    Wait so whats the purpose lol i missed it
  17. Nov 10, 2018 at 9:24 PM
    #1937
    Casper421
    In the woods
    06 DC
    No fingerprints on your clean truck from closing the doors.
    Matty4wd[QUOTED] likes this.
  18. Nov 11, 2018 at 4:27 AM
    #1938
    because_wumbo-truck
    Jon
    Houston, Texas
    I'm talking about when open. Lol
    What's the point of em? You said specifically it's a must for black trucks. Why
  19. Nov 11, 2018 at 4:29 AM
    #1939
    because_wumbo-truck
    Jon
    Houston, Texas
    Oh
  20. Nov 11, 2018 at 7:05 AM
    #1940
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    They're for people with nice trucks. Mine doesnt need em. :p
  21. Nov 11, 2018 at 7:29 AM
    #1941
    Hand Protectors
    Researched the lubing of non zerk bushings. Gonna buy a needle for the grease gun hose tip and pierce inject grease until the bushing swells. Will be doing the upper ball and tie rods.
    Ran across another nice piece of side info that will help me hopefully solve the front propeller shaft grease zerk situation I’m having by not being able to squirt grease in them (2). The rear prop have 5 joints that grease easily. The front two won’t take grease. The tip fits on but grease squeezes out at the fitting. Thinking the zerks have hardened grease. Will remove them, HEAT them up to melt grease and test them. Whilst off I’ll grease inside the prop through where the zerks were. Screw zerks back on after.
  22. Nov 11, 2018 at 8:15 AM
    #1942
    Hand Protectors
  23. Nov 11, 2018 at 2:23 PM
    #1943
    Hand Protectors
    Plumped up the upper-control arm and outside tie rod bushings with some grease via needle injection. Also, shot some in the dust cover of the inner tie rods.
    Removed rear door inside panels to inspect speakers. Looking for a rattle. They are in fine shape. The rattle was from a worn foam pad at the door handle where it sits on a metal support. Cleaned it up and installed some weather gasket in place. Rattle gone.
    Lubed up the door cables and latch springs.
    Still stumped on this front propeller zerk situation. No way to remove the zerk or fill it due to them being offset. Might have to partially grind one side of the grease tip to make it happen.
  24. Nov 11, 2018 at 5:39 PM
    #1944
    Casper421
    In the woods
    06 DC
    No more green gauges:
  25. Nov 11, 2018 at 8:29 PM
    #1945
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Plumped em up? Needle injection? Did you give your suspension saline injections? :D
  26. Nov 11, 2018 at 9:09 PM
    #1946
    WutsaZJ
    WutsaZJ New Member
    Took off the shell and extended a pair of chains we had laying around. Fit the 285s nicely. Just in case we actually have a winter this year haha
  27. Nov 11, 2018 at 9:11 PM
    #1947
    WutsaZJ
    WutsaZJ New Member
  28. Nov 12, 2018 at 9:54 AM
    #1948
    because_wumbo-truck
    Jon
    Houston, Texas
    How do I know if I need VSC rear brake lines or regular? Wanting to buy some from wheelers on black friday
  29. Nov 12, 2018 at 12:31 PM
    #1949
    TUNDRAIN520
    TUNDRAIN520 TUNDRAin520
    Travis
    Tucson, AZ
    2001 Extended Cab 4x4 SR5
    I have had this beast about 30 days now...
    2001 Extra Cab SR5 4x4. 219K
    She had already been completely de-badged when I got her.
    So far I have done the timing belt, replaced the leaking exhaust manifolds with JBA Cat4ward headers, repaired the exhaust pipe back to the muffler, replaced the muffler with a Flow Master 2 into 1, removed the dual tailpipes with chrome tips and added just a single 3 inch tailpipe that dumps behind the passenger side rear tire.
    Last night I bought and put on a set of 2014 (i think) Tacoma Wheels
  30. Nov 12, 2018 at 12:35 PM
    #1950
    because_wumbo-truck
    Jon
    Houston, Texas
    Looks good. Sounds like you been busy.
    TUNDRAIN520[QUOTED] and Matty4wd like this.
