  1. May 11, 2020 at 5:03 PM
    Professional Hand Model
    Hand Protectors
    Whats your technique on the service?
    Tundra2 likes this.
  2. May 11, 2020 at 5:05 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Once I get mine back in working order I'll have to keep track of that, and start doing that. Any specific type of grease you all prefer?
    I can get some High temp grease from work once life ya know... resumes.
  3. May 11, 2020 at 5:07 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Peal the boots back, get old grease out, articulate the arm a few times and load it up with fresh grease.
  4. May 11, 2020 at 5:07 PM
    empty_lord
    05 rollover special
    I use super lube for almost everything lol
  5. May 11, 2020 at 5:09 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Almost everything except....?
    Lol
  6. May 11, 2020 at 5:23 PM
    empty_lord
    05 rollover special
    My guns.
    I use super lube for the brake arms
  7. May 11, 2020 at 7:29 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Been thinking about my rear crustiness. I know others have mentioned needle scaler which is a fantastic idea, but I don't have access to compressed air.
    Wire wheel it is.​
    https://www.amazon.com/dp/B00LI97LFY/ref=cm_sw_r_other_apa_i_0fGUEb88Q7SX3
    Big gurll specials.
    What are you some products you fellas have used to stop the crustiness?
    I perused the Hand model Role model page.
    https://m.autozone.com/greases-and-gear-oil/lubricant-grease/stp-moly-ep-grease-tub-15oz/561753_0
    Moly-B grease coat seems to me to be a preventative measure? Please correct me if I am wrong.
    Edit
    After some heavy search bar use... (I keep forgetting its there, and how to use it.)
    Remove as much scale as possible, and wire wheel wherever possible that are trouble areas.
    Fluid film seems like a reoccurring thing that most seem happy with, also a generous coating of penetrant, and then follow that up with the Moly after a few weeks.
  8. May 11, 2020 at 7:37 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    as usual, @empty_lord is right when it comes to parts, cross model compatibility, toyotas...life in general
    I've heard a few guys have their's break and leave em stranded so I go worried since mine had a bunch of wiggling to it...think of a manual trans in neutral wiggling.
    I didn't grease mine but I did replace the transmission linkage bushing and that did help a bit.
    empty_lord[QUOTED] and Tundra2 like this.
  9. May 11, 2020 at 7:41 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Also made a kayak rack for my truck. Still need to paint it and then mount the ‘J-Bars’.
    A few issues that led me to making this one instead of buying one.
    1. price
    2. I only needed the front rack and didn’t want the kayaks flat above the truckbed like canopy height
    3. Wanted to keep my tonneau cover
    4. Wanted to me able to pull the travel trailer with the tailgate closed and the still bring the two kayaks
    Cost me about $50 in parts and a little bit of time is all. I know it looks low but with the J-Bars mounted the kayaks will clear the back of the cab roof without being sky high
  10. May 11, 2020 at 7:45 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I bet @bmf4069 approves! how did you anchor into the stake pockets? Just a bolt?
  11. May 11, 2020 at 9:24 PM
    empty_lord
    05 rollover special
    Don’t worry. I’m wrong a lot. I’m just good at faking it till I make it
  12. May 11, 2020 at 9:58 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Maybe I’ll paint it black, But I do have white raptor liner that I thought about using.
    Yes it has an eyebolt that screws into it. Looks to be pretty solid but I’ll have to do a freeway test run once I’m done and get the kayaks on there
    Darkness, bmf4069 and Tundra2 like this.
  13. May 11, 2020 at 10:15 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Would it be wise to replace my E-brake cables when I get around to the bell cranks?
    Rears specifically? I'm not so concerned about the front part of the cable, just whats past the turnbuckle adjustment.
    Gut instinct says they are not stretched since they have been loose all this time...
  14. May 11, 2020 at 10:42 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I wouldn't worry abut the cable, there's so much adjustment. Here's a very good write up on the bell cranks.
    For the rust, clean it up, then use POR 15, or ospho or many other rust removers, then coat it.
    NUDRAT likes this.
  15. May 11, 2020 at 11:52 PM
    empty_lord
    05 rollover special
    im so tired of the bell cranks im half tempted to have my buddy make some out of 300 series stainless to see if they resist the rust better.
  16. May 12, 2020 at 3:36 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    PHM used a product called Ospho that looked promising. After you wire brush everything I would either use that or POR15.
    The grease rub would be a final step to protect it but you want to actually do something to the rust first. At least that's what I would do.
    NUDRAT likes this.
  17. May 12, 2020 at 5:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Get rid of those factory 90s and bend that shit! Or, use compression couplings. They're a lot stronger.
  18. May 12, 2020 at 7:42 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    How can a bend vs a 90 be stronger? Also the couplings are drilled through with bolts going through
    bmf4069[QUOTED] likes this.
  19. May 12, 2020 at 8:28 AM
    FrenchToasty
    Mo
    Bone stock
    He just means using the clamps w the pre bent 90 vs getting it bent in one piece. But that looks like 1 1/2 maybe, and most people don’t have a bender that big
    bmf4069 likes this.
  20. May 12, 2020 at 8:50 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    This might belong in the Off Topic forums
    CodyP, bmf4069, oscardog86 and 2 others like this.
  21. May 12, 2020 at 10:59 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, a full stick with 2 90s bent in it. We have a bender that will do up to 4". But with you drilling it through that'll be good.
    Darkness and Tundra2 like this.
  22. May 12, 2020 at 1:51 PM
    Hand Protectors
    @CodyP What kind of magic did we do here to make the round pipe fit into a square hole?
    bmf4069, Darkness and FrenchToasty like this.
  23. May 12, 2020 at 2:40 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Oh, I see what you mean. Yeah, I think that would look more 'boxy' to have the bars go straight up, and then right angle horizontally across so I went this way instead. Keeps the sides a bit shorter too since the swooping 90s give 6" of lift anyways.
    Yeah, I don't have a mandrel bender anyways and they have eyebolts holding them into the stake pockets.
    Black magic.... as well as my bench vice and a bit of hammer work. Just put the bottom 6" into the vice so the top of the short pieces are still circular to mate up to the corners and connectors.
  24. May 12, 2020 at 2:42 PM
    Hand Protectors
  25. May 12, 2020 at 2:46 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    hmmm...I feel you say that degradingly lol.
    I just needed something on the 2-3 times a year (which is the only time it will be on the truck) I haul a TT and kayaks and knew it wasn't worth the money to buy a full fledged kayak rack IF I could find one to work simultaneously with a tonneau cover.
    Tundra2 likes this.
  26. May 12, 2020 at 2:58 PM
    Hand Protectors
    I guess I could say a ‘feel’ your answer left me interested in how one pounds a 2”? round pipe into an approximate 1.25” square, but I already said that.
    I see you added some further explanation and an additional picture to your post which helps me see what you’ve done.
    Also, I think sometimes this site may be slow in uploading pics because I’ve read a post and then come back later and see something new added. Not sure if that was the case here.
    Tundra2 likes this.
  27. May 12, 2020 at 3:01 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    It was a 1.5" pipe down to 1.25 so it didn't take much finesse. Also, I posted it from my computer and then uploaded the picture a minute later from my phone so that's probably what caused the delay.
  28. May 12, 2020 at 3:04 PM
    Hand Protectors
    Cool. That was the confusion. I actually was at big box today looking at this pipe. @bmf4069 compression fittings are high dolla!
    One 2” fitting was $50!
    CodyP[QUOTED] likes this.
  29. May 12, 2020 at 3:05 PM
    FrenchToasty
    Mo
    Bone stock
    What was it made out of? That’s pricey!
    bmf4069 likes this.
  30. May 12, 2020 at 3:06 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yes, that was the other reason as well as these cheap ones being bolted together
