  1. Apr 4, 2020 at 10:53 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    47A12D11-12F5-4EC0-8B31-FDF161793710.jpg 2B8A912A-572C-428A-8225-529E3E2B8D05.jpg Clear coating 4runner rims for mommas whip(haha 2.5+ years after buying them!) using that spray max 2k, it is spitting a little bit but I can live with it. Also sprayed the exposed metal from my rear fender chop for the coastal bumper. I will probably put the bumper on tomorrow, I hope
    Levy, georgiey22, chrisb and 3 others like this.
  2. Apr 4, 2020 at 10:54 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG] [​IMG] [​IMG] Parts are in. 75 bucks for all the same stuff that Toyota sells for double or triple the price.
    chrisb, bmf4069, lsaami and 8 others like this.
  3. Apr 4, 2020 at 10:59 AM
    FrenchToasty
    Mo
    Bone stock
    Damn, I could have sent you my center bearing, I ordered that PN but it doesn’t have the seal like the 4wd PN does.
  4. Apr 4, 2020 at 11:02 AM
    empty_lord
    05 rollover special
    Your 4wd one looked different? This looks like all the ones I’ve ever done.. guess we’ll find out when I pull mine apart
  5. Apr 4, 2020 at 11:08 AM
    FrenchToasty
    Mo
    Bone stock
    Supposedly the 4wd one has a seal on both sides. The 4wd one is exactly the same just it has seals, supposedly either one works but I guess I wanted the “better one” a guy on scamazon does a side by side, if you look up that PN you have
    Tundra2 likes this.
  6. Apr 4, 2020 at 11:10 AM
    empty_lord
    05 rollover special
    Eh. I won’t worry about it. Price was cheap enough it doesn’t matter to me. Lol this truck while it will see Offroad won’t be extreme where I need to worry about seals under there it’s mostly here to haul and tow
    Tundra2 and FrenchToasty[QUOTED] like this.
  7. Apr 4, 2020 at 11:55 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    This is the "sealed" part number. Not sure how much difference it'll actually make.
    georgiey22, Tundra2, Darkness and 2 others like this.
  8. Apr 4, 2020 at 12:02 PM
    empty_lord
    05 rollover special
    Yea I see my old one now. Difference it makes? Next to nothing. The new one fits the flanges of the flange and shaft just fine so it’ll keep the same amount of stuff out.
    Tundra2 and NUDRAT like this.
  9. Apr 4, 2020 at 12:16 PM
    empty_lord
    05 rollover special
    She’s a wee bit tired
    bmf4069, Tundra2, Darkness and 3 others like this.
  10. Apr 4, 2020 at 12:45 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Add a leaf installed (wheelers). Time to measure and see what we gained for height.
    bmf4069, Tundra2, Darkness and 5 others like this.
  11. Apr 4, 2020 at 1:45 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Nah that's fine, just flip it over! Problem solved.
  12. Apr 4, 2020 at 2:38 PM
    empty_lord
    05 rollover special
    For sure.
    In other news I’m done
    oscardog86, Tundra2, speedtre and 2 others like this.
  13. Apr 4, 2020 at 5:19 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    nice. but now that exhaust joint can't be unseen. :)
  14. Apr 4, 2020 at 7:59 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    chrisb, MS22, bmf4069 and 3 others like this.
  15. Apr 4, 2020 at 8:10 PM
    empty_lord
    05 rollover special
    You think that things going to stay?
    NUDRAT[QUOTED] and Tundra2 like this.
  16. Apr 5, 2020 at 1:22 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Does anyone have a rough idea how many feet of vacuum line I'm likely to need?
    I would hate remove, and measure each one, and reinstall to get a ball park idea of how much I'm gonna need.
    I'd rather just buy what I need all at once, and spend the weekend going through.
    Also, hose clamps? I've noticed that the only thing with hose clamps on my truck are things that have been worked on. (Radiator, brake booster.)
    NUDRAT likes this.
  17. Apr 5, 2020 at 1:36 AM
    empty_lord
    05 rollover special
    vacuum line for what?
    and i would advise not using worm drive hose clamps.. they like to cause leaks. spend the coin for the Toyota spring clamps. (hose clamps can be easily overtightened and eat into the rubber hoses, spring clamps are a constant tension)
  18. Apr 5, 2020 at 1:54 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Vacuum line for my truck. I've got a few with ends that are starting to crack. I figure if we truly are laid off this coming Friday I can attack that in my time off.
    The trucks 18 years old. I figure it's time for an overhaul on the things I CAN do.
    NUDRAT likes this.
  19. Apr 5, 2020 at 10:01 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    14wa brake upgrade (13we original) final thoughts.
    Bled the brake lines again starting in the back this time. Took a much longer ride to test different ranges.
    Overall, I do feel an improvement from all ranges of braking but most significantly is hard braking. This is using OEM parts so I feel there's still room for improvement as well as installing the steel lines I have. Definitely happy with the upgrade and especially the cost I have into it. The final look is much more fitting than the much smaller 13we as well.
    I was originally planning to do testing before and after with actual measurements but since the quarantine, I got bored and started the install without getting the tool from work to do measurements so can't provide much out side of my "feelings".
    bmf4069, oscardog86, Tundra2 and 4 others like this.
  20. Apr 5, 2020 at 10:03 AM
    empty_lord
    05 rollover special
    I need to get this done... I’m torn between using the stock brakes or go with the 14wa. I’d have to buy new wheels sooner than I thought though.
    Tundra2 likes this.
  21. Apr 5, 2020 at 10:08 AM
    imDementeD
    I don't think I would upgrade if I had 13WL but because I had the much smaller 13WE I figured it was worth doing. I also found a wrecked GX460 that was be parted out so I got a good deal on the parts.
    Tundra2 and Darkness like this.
  22. Apr 5, 2020 at 10:15 AM
    empty_lord
    05 rollover special
    I have the calipers. (I have seem to hoard Toyota parts, seriously. I have 40 sets of corolla brake pads...) it’s just deciding if I want to actually buy wheel now or wait. My front calipers are sticking. Only a mater of time before they seize
    imDementeD[QUOTED] likes this.
  23. Apr 5, 2020 at 10:56 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Do you need 17" wheels to fit these wa brakes?
  24. Apr 5, 2020 at 11:15 AM
    empty_lord
    05 rollover special
    Yes
    TX-TRD1stGEN[QUOTED] likes this.
  25. Apr 5, 2020 at 2:37 PM
    FrenchToasty
    Mo
    Bone stock
    780266D8-0C75-4A6B-90A7-82C09F2FA176.jpg A36C8407-C285-462C-8BFD-E7E9E2B04CF5.jpg C607CA08-213A-4F9D-A0D9-01A04817A79E.jpg Bumper installed! I need to get 2 more 1/2 bolts(I added one new hole to each side for more bite on the frame) also put some edging on the fenders to clean it all up
    After I mount the swing arm I need to drill and tap the latch, and figure out my final solution for the skid/stop plate, and wire the license plate lights to the swing arm.
  26. Apr 5, 2020 at 2:48 PM
    empty_lord
    05 rollover special
    Drilling holes to put brackets in for a center console...
    bmf4069, Tundra2, Darkness and 4 others like this.
  27. Apr 5, 2020 at 2:59 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    What is the rubber weather strip around the windshield called?
    Mine is cracking and I want to order a replacement, but I don't know it's official name.
    Thanks.
    Tundra2 likes this.
  28. Apr 5, 2020 at 3:10 PM
    empty_lord
    05 rollover special
    [​IMG] Nd now I have all 3 access cab brackets
    Tundra2, jImmegart, bmf4069 and 4 others like this.
  29. Apr 5, 2020 at 3:14 PM
    FrenchToasty
    Mo
    Bone stock
    Did you originally have a bench in there? Or just not a full console?
  30. Apr 5, 2020 at 3:19 PM
    empty_lord
    05 rollover special
    Yhis truck was a bench truck
