  1. Feb 25, 2020 at 7:15 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Oh that’s why you said test mule...:rolleyes: Jesus it’s been a long day.
    NUDRAT likes this.
  2. Feb 25, 2020 at 7:15 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Don’t worry. It’s been a long day for me too! Lol
    Filthyphil[QUOTED] likes this.
  3. Feb 25, 2020 at 7:33 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Filled my power steering reservoir that nearly went empty. Guess the hose clamp trick didn’t fix my leak.
    anyone know where I can buy new power steering hoses without OEM prices?
    NUDRAT likes this.
  4. Feb 25, 2020 at 7:40 PM
    empty_lord
    05 rollover special
    Apparently scan gauge code for trans temp on 05-06 tundras is the same as 05-09 Tacoma’s. I have a reading. No idea which sensor it is. I’ll have to confirm later.
    Filthyphil and FrenchToasty like this.
  5. Feb 25, 2020 at 7:42 PM
    Filthyphil
    Phil
    Go to a hose and fitting store and see what they can do?
    FrenchToasty likes this.
  6. Feb 25, 2020 at 7:46 PM
    empty_lord
    05 rollover special
    A shop that does hyradulic lines should be able to make new ones if you take the originals to them. (Steal em off the parts truck)
  7. Feb 25, 2020 at 7:48 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    This is a great option if you have another vehicle to use while the truck is down. I took my hi side AC condenser hose to a local place and had them redo the hose, new orings for 30$
  8. Feb 25, 2020 at 7:53 PM
    empty_lord
    05 rollover special
    ok so trans temp with a short test appears to work. but its 4 degrees off. dont know whats up with that.
  9. Feb 25, 2020 at 7:53 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    If you're changing your hoses - check the 2 lines on top of the steering rack. Those aren't part of 'the kit', but mine went right after a hard line below the reservoir went. Very annoying to deal with it 2x in 2 months.
  10. Feb 25, 2020 at 7:56 PM
    FrenchToasty
    Mo
    Bone stock
    4 isn’t bad, maybe the SG takes a bit to level out. Will you share a link or the code sequence?
    CodyP likes this.
  11. Feb 25, 2020 at 7:58 PM
    empty_lord
    05 rollover special
    Transmission Fluid Temperature
    TXD: 07E021D9
    RXF: 032180000000
    RXD: 2810
    MTH: 00070065FE70
    NAM: TFT
    In degrees
    Filthyphil and NUDRAT like this.
  12. Feb 25, 2020 at 8:02 PM
    FrenchToasty
    Mo
    Bone stock
    Awesome!! Thank you!
  13. Feb 25, 2020 at 9:14 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Checked my power steering fluid levels. Looked good. No leaks at the hoses.
    I received my bypass kit for the air pump nonsense. Looking forward to not having to clear out the check engine light with my scanner anymore.
  14. Feb 26, 2020 at 6:22 AM
    Professional Hand Model
    Hand Protectors
    Which paint finish did you use? Looks nice.
    The detail in the Toy emblem is a lot of work. Good job.
    JustGotDuals[QUOTED] and Tundra2 like this.
  15. Feb 26, 2020 at 7:41 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just installed the backer rod for the dash rattle. Whoever came up with this idea is a genius. It took me less than 10 minutes and blends in so nicely I can hardly see it. :hattip:
    I went with the 5/8th inch.
  16. Feb 26, 2020 at 7:43 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What are they trying to show us with the cell phone in the picture? I don't get it.
  17. Feb 26, 2020 at 8:15 AM
    Turf Guy
    Turf Guy New Member
    Cam
    2006 SR5 4WD 4.7L AC Salsa Red Pearl
    Just picked up the truck from my local mechanic with a new timing belt and water pump and it's making a squealing sound during acceleration and a softer squeal at idle. When I told him his answer was that antifreeze must have gotten on the serp belt during install and some belt lube might work. It worked, but only as far as it took to get out of the lot. If his assumption was correct will the sound just dissipate over time?
  18. Feb 26, 2020 at 8:58 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Bought a case of 6 quarts of Toyota Type IV ATF. I used 4 & 1/2 quarts to do a drain and fill on the transmission. Have owned the truck since Feb of 2017 and this is the first time I've replaced any ATF in it after 3 years and 50,000 miles. The fluid that came out looked just as good the virgin ATF that replaced it.
    After that, I used the left over 1.5 quarts to do a full flush of the power steering system. The fluid that came out of the PS by comparison looked brown and smelled off/burnt.
    I also removed the throttle body and cleaned it thoroughly along with the MAF. My idle was whack afterwards, stuck at 1500 rpms until I disconnected the battery cable and did the idle relearn steps.
    Last up came an oil change with Mobile 1 synth high mileage and a Purolator BL30001 filter.
  19. Feb 26, 2020 at 9:25 AM
    Hand Protectors
    Just like a Seinfeld Show: We could discuss something about nothing that makes sense all day long.
  20. Feb 26, 2020 at 9:26 AM
    Hand Protectors
    Fresh!
  21. Feb 26, 2020 at 9:27 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    One of my favorite shows of all time.
  22. Feb 26, 2020 at 9:28 AM
    Hand Protectors
    Reminds me of the red light warranty used car guys used to joke about. “As soon as their red brake lights disappear off the lot so does their warranty.”:eek:
  23. Feb 26, 2020 at 9:39 AM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    Hey has anyone here installed "Raptor" hazard lights to their grill? i have a buddy with a 98 4runner and he has them and they look sick. there are a bunch that i can order and find a way to install, but i wanted to see if anyone has done it on here. here is his rig
    oscardog86 and theblurry1 like this.
  24. Feb 26, 2020 at 9:44 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do they actually put out much lumens?
    kodyquist21[QUOTED] likes this.
  25. Feb 26, 2020 at 9:57 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    They're for visibility/style. They don't contribute to your ability to see. Think about the lights on top of semis or DOT trucks, but mounted lower.
    kodyquist21 likes this.
  26. Feb 26, 2020 at 10:05 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I think that's the way it was with the torque app too. I can't remember if I used a Tacoma or 4runner code , but I think it was one of them. I'm guessing the sensor I have is reading the pan because it's generally lower than I would expect to see climbing hills and such the few times I've checked it.
  27. Feb 26, 2020 at 10:08 AM
    KarmaKannon
    Utah
    Some junk
    I almost did it, but I have gotten over it fast. Seems like every 4runner with bright headlights, bright "fog" lights aimed in my eyes (3' higher than their headlights), and bigger tires, has the raptor lights. Not sure I want to be associated with that crowd too often.
  28. Feb 26, 2020 at 10:30 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    I have!
    Got mine from Oznium, here's the product:
    https://www.oznium.com/led-bolts-prewired-leds/premium-side-view-led-bolt#photos
    Wiring was pretty easy, I simply tapped into the DRL wire on the passenger side since these are accent lighting. I could have also spliced into the turn signal but felt that would be weird. Ran the wires up the strut and across the hood into the grill. Mounting the actual lights only required a hole drilled into the plastic. Unnecessary to increase the fuse size because these are so low voltage, nothing has popped so far.
    These accent lights are bright enough to provide a little more visibility to oncoming traffic, etc. And they compliment my LED DRLs. Let me know if you have any questions. :)
    Filthyphil, NUDRAT, Tundra2 and 3 others like this.
  29. Feb 26, 2020 at 10:36 AM
    kodyquist21
    Kody
    Buckeye, AZ
    That is exactly what i was loooking for, so all you did was drill a hole and stick them in there? how did you mount them, did you screw them on or use glue?
    theblurry1[QUOTED] likes this.
  30. Feb 26, 2020 at 10:39 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Glad to help! That's precisely it. Match the bolt part up to your drill bits and find the size that's snug (I don't remember what it was). The light pokes into the hole and is secured tightly with the nut.
    Whether you want two, three, or more is up to you!
    Tundra2 and kodyquist21[QUOTED] like this.
