  1. Oct 19, 2018 at 5:23 PM
    #1591
    Professional Hand Model
    Hand Protectors
    Just remembered the carrier bearing and u-joint replacement are coming up as prevent maintenance, too. OEM carrier and 2 rear prop spider joints add up to $300. Labor is $100 for spider joints pressing if I take it to heavy rig shop.
    Never ending, but better than a $600 month truck payment!
    Looking forward to getting Antique License Tags in 2 years and zero prop taxes!
    Trd307, Rheywood456, BestGen and 2 others like this.
  2. Oct 19, 2018 at 5:23 PM
    #1592
    Hand Protectors
    Oh and the muffler.
    Darkness likes this.
  3. Oct 19, 2018 at 6:00 PM
    #1593
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Exactly what I said the the parts guy at Toyota after paying for 600 worth of parts. Cheaper than a payment.
  4. Oct 19, 2018 at 9:22 PM
    #1594
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    I don't have a rear bar.
  5. Oct 19, 2018 at 10:44 PM
    #1595
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've been thinking about the damn nuts that were once welded to the tabs by my lower arms. The ones that hold the skid plate, they separated from the tabs.
    Since I'm pulling the lower arms out tomorrow I think I'm going to get a hold of a nutsert tool and pop a few nutserts in. Might have to drill the hole out a bit to fit a decent sized one in. Seems like the smartest way to handle it.
  6. Oct 20, 2018 at 6:54 AM
    #1596
    Hand Protectors
    Rear OEM mufflers prices.
    Cali vs. the rest of the Union prices. Check out the disparity on the center muffler. Wow!
  7. Oct 20, 2018 at 7:19 AM
    #1597
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Damn. I'd go to a custom exhaust shot and get a full car back for that price.
  8. Oct 20, 2018 at 7:29 AM
    #1598
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Wow it's just a y pipe and a resonator. If I knew they were THAT much I would have kept mine and sold it half price!
    Wait it's the same part number :rofl:
  9. Oct 20, 2018 at 9:07 AM
    #1599
    Hand Protectors
    This is what baffles me.
  10. Oct 20, 2018 at 9:17 AM
    #1600
    Hand Protectors
    The local stealership here wants 25-35% more than the above prices! Nothing is in stock here (money area). Means its best to just have it shipped to front door from this online store above. Compiling schematics now and going to decipher school to learn the stealership part codes for the smaller gaskets/bolts parts numbers.
  11. Oct 20, 2018 at 9:40 AM
    #1601
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The little gaskets on the y pipe are obscenely expensive from Toyota. The fiber donut ones.
    My truck is originally from AZ and had the resonator, I thought Cali native Tundras had a 3rd cat instead but that part number suggests otherwise.
  12. Oct 20, 2018 at 10:28 AM
    #1602
    Hand Protectors
    My manual specifies that the center muffler is a catalytic converter (its not from CA). Saw it the other night. Will need to go back and double check.
  13. Oct 20, 2018 at 12:22 PM
    #1603
    Hand Protectors
    ‘P’ and ‘D’ lamps just arrived. Now I’ll know what gear I’m in!
    $20 for both lamps.
    Jerry311SD and bmf4069 like this.
  14. Oct 20, 2018 at 12:26 PM
    #1604
    Hand Protectors
  15. Oct 20, 2018 at 1:38 PM
    #1605
    Hand Protectors
    20 minute job
    Removed burnt lamps.
  16. Oct 20, 2018 at 1:39 PM
    #1606
    Hand Protectors
  17. Oct 20, 2018 at 1:40 PM
    #1607
    Hand Protectors
  18. Oct 20, 2018 at 1:41 PM
    #1608
    Hand Protectors
  19. Oct 20, 2018 at 1:43 PM
    #1609
    Hand Protectors
  20. Oct 20, 2018 at 1:50 PM
    #1610
    Hand Protectors
    Also, was researching loose side windows/window rattle and the search took me over to Taco world site. Those guys were saying to tighten up the side bolt on the door jamb (connects to inside vert window track). Sure enough, its made the door shutting ‘sound’ more solid. Haven’t test driven yet so not sure fully. Sure sounds better when shutting which many Taco guys were saying was one thing they noticed also.
    Carefull to not over tighten bolt. Some guys broke the bolt flange on the inside and had to then take off door panel!
    Mine only took a 1/4 turn slowly! 10mm
  21. Oct 20, 2018 at 1:53 PM
    #1611
    Hand Protectors
  22. Oct 20, 2018 at 1:55 PM
    #1612
    Hand Protectors
  23. Oct 20, 2018 at 3:12 PM
    #1613
    Hand Protectors
    Tested windows and they are much sturdier now. Such a simple fix. 10 seconds per door.
  24. Oct 20, 2018 at 3:37 PM
    #1614
    Hand Protectors
    Tested the pass side door switch (broken for years) by swapping it with drivers side (working) and determined switch is bad.
    Must be tested with switch and 10mm fully screwed in (proper ground). upload_2018-10-20_18-34-49.jpg
  25. Oct 20, 2018 at 9:44 PM
    #1615
    Casper421
    In the woods
    06 DC
    Added up what my wishlist for the truck will cost...very glad I was sitting.
  26. Oct 21, 2018 at 6:06 AM
    #1616
    Hand Protectors
    Whats your number? Mine is hitting $1800.
  27. Oct 21, 2018 at 7:49 AM
    #1617
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Mine is about 5k
  28. Oct 21, 2018 at 8:11 AM
    #1618
    Casper421
    In the woods
    06 DC
    Spent 3k so far and another 16k or so to get it where I want it. Cheaper if I build my bumpers.
  29. Oct 21, 2018 at 8:22 AM
    #1619
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    I've never added up my wishlist but the first two items alone put me at over $15K! :eek:
  30. Oct 21, 2018 at 8:38 AM
    #1620
    Hand Protectors
    Wow! And I thought I was over-investing in mine, except you guys are doing mods/fabs custom stuff which is $$$ compared to me doing OEM maintanence stuff. You guys make me feel better.
    Sitting at $5k now. This additional $1800 is the stopping point!
    Not bad if I weight out not really spending or doing anything for the past 6 years to her outside of fluids and small maintenance.
    BestGen and Darkness like this.
