  1. Feb 10, 2020 at 4:01 PM
    Professional Hand Model
    Hand Protectors
    I’d have to feel and mediate over the action on this one to know whats going on. Touch plays a big factor in diagnoses.
  2. Feb 10, 2020 at 4:02 PM
    Tohopko
    Tohopko New Member
    2004DC
    Anticipating that I would have one stuck on the Hemi in our Jeep, a mechanic friend suggested the same, slowly turning it back and forth a little with some penetrating oil on it. I was lucky to not have one stuck, but hopefully it works for you. I've found Kroil or Sea Foam Deep Creep with the part warm to be the best working.
  3. Feb 10, 2020 at 4:21 PM
    AlbertaBeef
    AlbertaBeef New Member
    Glen
    Airdrie, Alberta, Canada
    2001 Tundra 4x4 Access Cab TRD Off Road
    17" Rims and 265/70R17 tires, 20" Light Bar, Power Stop Brakes, Diff Breather Relocate
    Luckily, did NOT strip it. Took it slow, final 20% of threads was about 1/4 turn at a time, backing it off then slowly tightening a bit again, waiting a few minutes and then repeating the process. LOTS of PB Blaster on this one, sprayed it about 4 times. It was a PAIN, especially on my back, being bent over for what felt like hours, even though it was only a few moments at a time.
    Yeah, the trick worked. I have both PB Blaster and the Sea Foam Deep Creep ... I grabbed the one closest to the truck, LOL.
    Oh - I should take some pictures of some of the plugs - they were OLD. A couple of them have almost no perceptible electrode left. I'm starting to think previous owner wasn't big on maintenance.
    BTW ... it feels like a NEW TRUCK. LOL. I had no idea it was this smooth and powerful when it runs right!
    Volt92, SC T100, NUDRAT and 3 others like this.
  4. Feb 10, 2020 at 4:30 PM
    Hand Protectors
    Nice! Glad you got it. Stoked she is getting in prime shape.
    AlbertaBeef[QUOTED] likes this.
  5. Feb 10, 2020 at 6:00 PM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    Hey you guys, my check engine light came on and its showing my 02 sensor is out it ran code P0135, I was looking up how to change it and it looks fairly simple. The videos i found, it showed the sensor underneath the cab on the right and passenger side. Has anyone on here changed theirs before?
  6. Feb 10, 2020 at 6:05 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've removed and replaced then before, piece of cake if you don't have JBA shorty headers.
    KarmaKannon likes this.
  7. Feb 10, 2020 at 6:07 PM
    kodyquist21
    Kody
    Buckeye, AZ
    was it underneath or in your engine bay next to your intake?
  8. Feb 10, 2020 at 6:08 PM
    AlbertaBeef
    Glen
    P0135 is Bank 1 sensor 1 which is DRIVER side, not passenger. It's the heated O2 sensor closest the manifold on the drivers side. (FYI, passenger side is Bank 2, and would give a code P0155)
  9. Feb 10, 2020 at 6:10 PM
    Tohopko
    Tohopko New Member
    2004DC
    I got shorter. Downright stubby, in fact. Haven't tested reception just yet. Small victories until the throat is healed!
  10. Feb 10, 2020 at 6:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    They're nowhere near the intake. They're on the exhaust manifolds near between the frame and the transmission. Space can be a bit tight to turn the wrench but its straight forward, if you can change oil you can swap those sensors.
    Get Toyota sensors, a lot of Bosch ones don't seem to work well on these trucks.
    kodyquist21[QUOTED] likes this.
  11. Feb 10, 2020 at 6:21 PM
    AlbertaBeef
    Glen
    Yeah, what he said. But don't get them at the dealer if overpriced. FYI, Denso is the OE for the Toyota upstream/heated sensor. Denso Part# 234-4169. Personally, I'd change both of the heated/upstream sensors at the same time, but I'm all OCD and need symmetry.
    If you don't know - there's FOUR o2 sensors on your Tundra. 2 on each side, one upstream and one downstream of the catalytic converter. Downstream/Upstream are different parts, but Left/Right of either (upstream/downstream) are interchangeable for each side.
  12. Feb 10, 2020 at 6:47 PM
    kodyquist21
    Kody
    Buckeye, AZ
    Gotcha, is it possible to change without the sensor socket, or would i be saving myself a lot of cussing and slamming if i got it
  13. Feb 10, 2020 at 7:35 PM
    AlbertaBeef
    Glen
    Just get it. It's cheap. Also, the day before you're going to change it, SOAK the threads liberally in PB Blaster or another similar penetrating oil.
    kodyquist21[QUOTED] and NUDRAT like this.
  14. Feb 10, 2020 at 7:50 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Sounds like you did good. I paid $750 for welding and $50 for paint, I don't recall the price of the kit. But sounds like we paid about the same.
    FrenchToasty likes this.
  15. Feb 10, 2020 at 8:30 PM
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    I had to change both my headers as I needed new O2 sensors and they wouldn’t budge at all. Good luck with yours!
  16. Feb 10, 2020 at 8:54 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    Whothefat likes this.
  17. Feb 10, 2020 at 9:06 PM
    jImmegart
    Jonah
    California
    I dont tow and I haul mainly music gear so not super heavy. I wanted just P rated for weight but they dont make alot of highway tires in P only E. I saw that Toyo A/T 2 are available in the size and rating but I dont really need A/T tires, Im so torn D:
  18. Feb 10, 2020 at 9:10 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    im probably just going to spend the coin on a new set of gauge faces. i dont want to be unable to go back! lol
  19. Feb 10, 2020 at 9:11 PM
    empty_lord
    05 rollover special
    Thats SO much nicer than the buzzer setup on the access and reg cabs. i actually cant stand how mine just lays around bouncing around the way toyota has it. Im probably going toget the piezo off an avalon like mine, the chirps nicer and i can mount it somewhere
    BubbaW[QUOTED] likes this.
  20. Feb 10, 2020 at 9:16 PM
    empty_lord
    05 rollover special
    Bosch sensors never work with Yotas. Denso or NTK are the only ones that work. Toyotas are picky
  21. Feb 11, 2020 at 1:00 AM
    jImmegart
    Jonah
    California
    Volt92, Darkness, oscardog86 and 3 others like this.
  22. Feb 11, 2020 at 1:39 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
  23. Feb 11, 2020 at 3:30 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    That sounds awesome. I can't wait to see more about this project .
    I'd suggest a gps speedometer so you can see your actual speed if you ha e larger tires, and a transmission temp gauge.
    Tohopko and NomadicFrog[QUOTED] like this.
  24. Feb 11, 2020 at 4:26 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
  25. Feb 11, 2020 at 5:43 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Mine was a Port install item that I took off a few months back when I had my whole front end painted. It will not be going back on and will live it's life with the other items in my basement I can't seem to throw away :oops:
  26. Feb 11, 2020 at 6:06 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    One of those 6 point open sockets would work. A crow's foot works too. It's a bit tight in there to spin a wrench but little by little it will work. Like Beef said do some soaking pre-game first. Also be careful with the clips as they get brittle.
    AlbertaBeef likes this.
  27. Feb 11, 2020 at 6:14 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Betcha a couple $$$ would change your mind.
    because_wumbo-truck likes this.
  28. Feb 11, 2020 at 6:19 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Not exactly sure what you mean but if you're meaning selling it, I have no plans only selling. However, if I run across someone who wants it, including brackets....shipping costs is all I'll ask for.
  29. Feb 11, 2020 at 7:22 AM
    Recycled
    Recycled New Member
    Reedley, California
    2002 diamond in the rough.
    Anyone ever removed the back window? I have a broken or missing glass.
  30. Feb 11, 2020 at 7:28 AM
    Recycled
    Recycled New Member
    Reedley, California
    I would like to replace it with a plastic lexan.
