  1. Feb 1, 2020 at 3:54 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  2. Feb 1, 2020 at 4:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sadly the terminals are made in Japan, so finding them is rare. The old type 2 (the big pins on the main power wires for the radio) are easily attainable. It’s the small wires for all the accessories that are difficult/impossible to find.
    If I can find enough in junkyards for get long pigtails it’s less of an issue. But the cars using the newer small pins are far and few between
  3. Feb 1, 2020 at 5:05 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    You shortened it? I thought it was all about extending it :confused:
  4. Feb 1, 2020 at 5:07 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I thought the tranny and trans case skids bolted to the cross member
  5. Feb 1, 2020 at 5:08 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I haven't even attempted to install mine yet because I need to straighten my cross member first. Now I guess I'll need to do a mock install just to check fitment. Thanks for the heads up!
    oscardog86[QUOTED] likes this.
  6. Feb 1, 2020 at 5:11 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yeah.......rusty randy wasn’t having it and it snapped off. Luckily I backed off the lock nut underneath, and I still had threads to get the bracket back on. Supposedly the local steeler has it. I would try the homer depot option of an eye bolt but I’m sure yota has a weird diameter eye and then the bushing wouldn’t fit
  7. Feb 1, 2020 at 5:12 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Hmm now I guess I'll be checking the hole on the oil pan skid. I believe it lined up though. I means there's only one right way and one wrong way right?
    Edit: v6 ok that makes sense
  8. Feb 1, 2020 at 5:42 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    You should be good to go. Its basically because I have the V6 manual transmission. But luckily I found a way to bolt up the Transfer case skid. I just gotta drill a few holes tomorrow and should be just fine. The transmission skid however I will be returning. With the way the cross member is, its awkward to mount it, and not worth my time to try to make that one work. But they said theyd give me a full refund for that skid and cover shipping both ways. So atleast I got 3 out of their 4 skids installed :yes:
    Oh and as far as the oil pan skid not being directly underneath the oil drain plug, im just gonna install a fumoto valve with nipple and run tubing out of the hole in the skid. And now the fumoto is pretty protected as well. I hope it all works!
  9. Feb 1, 2020 at 6:45 PM
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    If you remove the flares, let me know if you want to sell them. Just put spacers on my ride and the tires stick out enough to bug me.
  10. Feb 1, 2020 at 7:42 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I installed my front braided brake lines. Flushed the fronts.
    First test drive the pedal feel is improved. (I didn’t think mine was bad, it’s better now) Probably 70/30 fresh fluid/brake lines.
    20200201_154452.jpg 20200201_164225.jpg 20200201_174245.jpg 20200201_161751.jpg
  11. Feb 1, 2020 at 7:46 PM
    SoCalPaul
    Paul
    So I go to the market & park near the end of the lot away from everyone and doofus parks right behind me almost to my bumper.20200201_190801.jpg 20200201_190813.jpg
  12. Feb 1, 2020 at 7:49 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I find the Chinese factories have no shame in replicating foreign designs - cars, appliances, plugs, caps, wire terminals....
    bmf4069 likes this.
  13. Feb 1, 2020 at 8:14 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    a company named Sodfunt sells a lot of connectors. I see 2p to 6p off hand & 1p in a flat blade, but don't really understand what I'm looking for, so...
  14. Feb 1, 2020 at 8:36 PM
    empty_lord
    05 rollover special
    Special shape connectors
    For the Toyota connectors
  15. Feb 1, 2020 at 8:38 PM
    SoCalPaul
    Paul
    I pulled my Toyota ceramic pads and they look the same.
  16. Feb 1, 2020 at 8:51 PM
    SoCalPaul
    Paul
    These shims came with my Toyota ceramic pads.
  17. Feb 1, 2020 at 9:01 PM
    SoCalPaul
    Paul
    Those definitely have a different color code then the ones I had.
    jImmegart[QUOTED] likes this.
  18. Feb 1, 2020 at 9:05 PM
    empty_lord
    05 rollover special
    Forgot to mention, happy one year to my tundra
    [​IMG] [​IMG] [​IMG] [​IMG]
  19. Feb 1, 2020 at 9:21 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Did seafoam in the booster tube while it wasn't running and then started if for a minute. I then put the rest of the can in with 1/4 tank of gas. I took my copilot over to get some french toast sticks and get a halfa$$ touchless carwash. The truck feels stronger and drives better already. We even had a little fun on a couple areas with a little frost left on the road. Seems like I'm chirping tires more than usual. Maybe that's the extra throttle response and maybe that's my foot having fun with the stronger bottom end either way I'm probably not going to calculate this tanks mpg.
    I also retreated to the garage after a heated debate over wanting to retrofit another set of headlights with demon eyes. I guess my wife thinks she's the only one in the house that can buy useless stuff. Haha if she only knew. Anyway I touched up my sliders and went crazy with the touch up paint on all my minor blemishes. No more fighting and a better looking truck. A positive feedback loop of constructive behavior!
    Darkness, NUDRAT, bmf4069 and 4 others like this.
  20. Feb 1, 2020 at 9:22 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Pics?
  21. Feb 1, 2020 at 9:32 PM
    KarmaKannon
    Utah
    Some junk
    I think that's right up there with my 1 year anniversary.
  22. Feb 1, 2020 at 9:44 PM
    Musashi66
    Pics of my tires?
  23. Feb 1, 2020 at 9:49 PM
    empty_lord
    05 rollover special
    This things been one of my best purchases. Yes it’s cost me what it’s worth but for that cost I’ve got effectively a new truck with a damn near whole new suspension. Interiors going to be nicely sorted hopefully by spring. Can’t find one this nice
  24. Feb 1, 2020 at 10:31 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Do you wanna borrow it?
    NUDRAT likes this.
  25. Feb 1, 2020 at 10:48 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yo. How much was that tranmission skid? I have a proposition. What if I buy it and skid row covers shipping? They win because they only lose on shipping instead of also having to refund you. You come out the same either way...
    Darkness and because_wumbo-truck like this.
  26. Feb 1, 2020 at 10:53 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    @empty_lord where did you get those tail lights? I am looking for some for my truck.
    because_wumbo-truck likes this.
  27. Feb 1, 2020 at 11:01 PM
    empty_lord
    05 rollover special
    Came with the bed. It’s oem 2005 lights
    NUDRAT likes this.
  28. Feb 1, 2020 at 11:02 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Stock 05-06 taillights. Should be able to find em online with ease and they should work fine.
    mcharfauros likes this.
  29. Feb 1, 2020 at 11:06 PM
    empty_lord
    05 rollover special
    These are eagle eye aftermarkets that the bed had. not too impressed with em... might snag the ones off the truck im getting the cap from if theyre OEM
  30. Feb 2, 2020 at 2:16 AM
    jImmegart
    Jonah
    California
    They have a few that are on Amazon that are oem, but It would be around 100 and Im not 100% they will fit in a 2003 but I see no reason why they wouldnt.
