  1. Jan 25, 2020 at 1:01 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  2. Jan 25, 2020 at 5:19 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Those are the Naturday cans man. Where the hell you been? :cool:
    I thought they were a limited releases so I'm surprised he still has them.
    bmf4069[QUOTED] likes this.
  3. Jan 25, 2020 at 5:20 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Wrong....
    You meant to say you forgot headers. With all that shit out of the way this is the perfext time to install them..
  4. Jan 25, 2020 at 5:32 AM
    empty_lord
    05 rollover special
  5. Jan 25, 2020 at 5:44 AM
    Professional Hand Model
    Hand Protectors
    You got this.
  6. Jan 25, 2020 at 6:13 AM
    empty_lord
    05 rollover special
    Tacoma needs some lovin too
    because_wumbo-truck likes this.
  7. Jan 25, 2020 at 9:11 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    D0802D26-71C6-4BD9-9A0C-40BA07CB1595.jpg 6738C3D4-133C-47BA-9856-4AE243143515.jpg 6292448C-C714-43B9-B0F5-F4A870B3D972.jpg It was pretty corroded down there! I’ll run that positive post connector until I can grab a new one. Letting it all dry after I baking soda the crap out of everything, removed the rad overflow, moved some wire looms and then simple greened everything and scrubbed w a wire brush, rinse/repeat and now it dries so I can throw some rust inhibitor paint in there
  8. Jan 25, 2020 at 9:22 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Ding, ding, ding. These things are bitchin. I didn’t think they were limited. I see them around all the time.
  9. Jan 25, 2020 at 9:33 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Does anyone have any suggestions on how to fix this driver armrest? You can see that I’ve tried to hot glue it but with our summers getting to 200 degrees, clearly that didn’t work. It looks like the vinyl has somehow warped that that’s pulling the foam back.
    speedtre and oscardog86 like this.
  10. Jan 25, 2020 at 9:36 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Yesterday I extended my helmholtz resonator to about 16-18". No resonance at all. I had some before, and I chopped up the tube to see if it made it better and I obviously had gone the wrong way. Now I really need to fix my exhaust leak up by (or at) the manifold because that's more obvious than ever.
    bmf4069 likes this.
  11. Jan 25, 2020 at 9:38 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Liquid nails...then wrap it in some newspaper, then use some duct tape to wrap the whole thing nice and tight while it dries. I don't think that level of heat will soften liquid nails.
    oscardog86 likes this.
  12. Jan 25, 2020 at 10:27 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Took of my skid plate today and uh-oh...
    I'm no engine expert but I'd say there is transmission fluid leaking. Does anyone know if there's a fix for this? I've dumped much money into repairs and it seems like a new one pops up whenever something's fixed :(
  13. Jan 25, 2020 at 11:01 AM
    speedtre
    speedtre New Member
    Inland Northwest
    That looks an awfully lot like you may have aa "A340 pink milkshake" going on...google it and then follow the process to determine if that in fact is what you have going on. If the truck is still driving well, you likely caught it in time. If it is a "pink milkshake" then..
    1. Don't drive it anymore.
    2. Replace the radiator immediately (Denso is your best value)
    3. Do a full drain and fill on you transmission 5 times
    Cross your fingers....good luck! :thumbsup:
  14. Jan 25, 2020 at 11:04 AM
    empty_lord
    05 rollover special
    Check the transmission fluid on the dipstick. If it’s milkshake looking DONT DRIVE IT
    get a new radiator and run 10 quarts through the transmission
    More if you do drain and fills over a day or 2
  15. Jan 25, 2020 at 11:44 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    I think I found the problem, looks like the radiator is leaking. Still strawberry milkshake?
    oscardog86 and NUDRAT like this.
  16. Jan 25, 2020 at 11:48 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Per @empty_lord's suggestion, what does your transmission fluid look like?
  17. Jan 25, 2020 at 11:53 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    potentially. Check your radiator, coolant overflow tank, and transmission dipstick for pink "milkshake" sludge. If you don't find any sludge, you're fine.
    theblurry1[QUOTED] and speedtre like this.
  18. Jan 25, 2020 at 11:59 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Why newspaper?
  19. Jan 25, 2020 at 12:03 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Here is the tranny fluid. Is it ok?
    mcharfauros and speedtre[QUOTED] like this.
  20. Jan 25, 2020 at 12:05 PM
    KarmaKannon
    Utah
    Some junk
    Looks like you just have a radiator leak to me. Kind of what I suspected because my coolant leak looks similar although much less serious. The pink coolant looks funny when it oozes out anyway.
  21. Jan 25, 2020 at 12:06 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    yep, looks good.
  22. Jan 25, 2020 at 12:09 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Don't want any leaking glue attaching to your straps. Newspaper will wear/cut away if glue leaks.
    bmf4069 and speedtre like this.
  23. Jan 25, 2020 at 12:11 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Good catch/timing.
    I'll suggest a spray down with Fluid Film between paint dried & reassembly.
  24. Jan 25, 2020 at 12:30 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Tundra brought home a Treadmill yesterday.
    ...but I got delayed at work, and my help to unload couldn't help that late, and it's too heavy for me to offload solo, & the rains came early today... hopefully I got the 'mill waterproofed.
    This one has a built in TV, I might actually keep using it.
    Tacoma raising it's arms in protest. Thinks we should gallivant in the woods rather than such electrical nonsense.
    bmf4069, Festerw, speedtre and 3 others like this.
  25. Jan 25, 2020 at 12:34 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Dropped the tundra off to get the bumper fab'd up. Hopefully will have some progress pics over the next few days.
  26. Jan 25, 2020 at 12:54 PM
    KarmaKannon
    Utah
    Some junk
    I have an exhaust tick that I'm guessing is from a cracked manifold. I'm wondering if anybody knows of I can use pre 05 (non-vvti) headers on my 06 and do an electronic secondary air bypass?
    To be short... Can the pre vvti headers fit a vvti 4.7? I'm not afraid of some exhaust work and I've seen pre vvti jba long tubes for around $530. Then again shorties are cheap and the same question applies. I'll probably go the cheap route if possible.
  27. Jan 25, 2020 at 12:54 PM
    Hand Protectors
    Round one of the ‘Third Times a Charm Trim Painting’. Also, I added some more insulation in quite a few more areas. She is getting quieter.
    Tomorrow the doors get finalized in black.
    Broke one of my ‘fixed 3 years ago’ control knobs after reinstall attempt after pulling the control panel to lube up those dial gears. Ordered up a 3 pack for $12.99.
  28. Jan 25, 2020 at 12:56 PM
    empty_lord
    05 rollover special
    The tick is usually just the gaskets
    Header time
    bmf4069, NUDRAT and FrenchToasty like this.
  29. Jan 25, 2020 at 12:57 PM
    KarmaKannon
    Utah
    Some junk
    Know if the pre vvti headers will fit?
  30. Jan 25, 2020 at 1:01 PM
    imDementeD
    I don't have a tick but I notice right before redline, I have this raspy breaking-up sound. I have the JBA shorties I plan to toss on. My mechanic said one header was leaking but they welded the crack. It only makes the sound in the last 2-300rpm before redline. Not sure if anyone has experience with this?
