  1. Jan 22, 2020 at 3:34 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This is known to be illegal in the state of California.
    bmf4069, oscardog86, NUDRAT and 4 others like this.
  2. Jan 22, 2020 at 3:41 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It most definitely causes reproductive harm in that state as well
    bmf4069, Trailscape, CodyP and 2 others like this.
  3. Jan 22, 2020 at 3:47 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Better than King in what way?
  4. Jan 22, 2020 at 4:48 PM
    Professional Hand Model
    Hand Protectors
    Taking a methodical approach to my brakes based on recent bleedings showing some black debris. Assuming it to be deteriorated rubber from original rubber flex lines and/or caliper piston rubbers.
    Ordered 4 new brake lines.
    Plan is to get these new lines installed first, drive her for a few weeks, and then rebuild the front calipers and rear cylinders shortly thereafter. Scientific Method Style Technique.
    bmf4069 and because_wumbo-truck like this.
  5. Jan 22, 2020 at 5:18 PM
    Outbound
    Aaron
    Northern Alberta
    I foresee many grins.
    Everything is either illegal, cancer causing or both in California, the Fun Sponge State.
  6. Jan 22, 2020 at 5:32 PM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    Installed my ECGS bushing and new axle seal today. Thanks to @FrenchToasty for loaning me the tool. For an amateur DIY guy it wasn’t too bad of a job. Getting the CV axle out and back in solo is a little tricky, a second set of hands would be real helpful with those steps!
  7. Jan 22, 2020 at 6:04 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    Sorry I'm late to mention it, but I used a giant zip tie around the spline end to the outer most strut mount bolt. It held the main part of the shaft straight, so I could knock it out solo.
    oscardog86 likes this.
  8. Jan 22, 2020 at 6:09 PM
    FrenchToasty
    Mo
    Bone stock
    I used my handy jack stand and a block of wood to kinda cradle it as it came out. We all skin cats differently, I love it!
  9. Jan 22, 2020 at 6:35 PM
    Whothefat
    Clark
    Las Vegas
    I ended up using a bungee cord hooked to the coil spring to hold it parallel to the ground.
    all good methods!
  10. Jan 22, 2020 at 7:12 PM
    KarmaKannon
    Utah
    Some junk
    The 20 or so times I've done it, wrap the CV in a rag and loop a bungee around it and pull it up into the fender well. You knock it out and it sort of stays there, mostly suspended, without scratching anything or tearing a boot.
    I really got good at this when cycling my suspension when I was messing with the geometry. I didn't want to scratch the pretty shocks or tear those brand new boots.
  11. Jan 23, 2020 at 12:23 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Mine came in today. Install maybe Sunday or next sunday
    oscardog86 and FrenchToasty like this.
  12. Jan 23, 2020 at 6:51 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Dropped mine off at the dealer to get the recalled recall airbags replaced.
    NUDRAT likes this.
  13. Jan 23, 2020 at 6:57 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Is this only for certain years? I've not had any recall notices.
  14. Jan 23, 2020 at 7:20 AM
    Hand Protectors
    Thats because the 2002 year was ranked the best in terms of ownership cost amongst all the 1st Gen Class.
    bmf4069 likes this.
  15. Jan 23, 2020 at 7:39 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Not speaking for Fester but the latest that affects our year(2004 DC) was a FRONT PASSENGER AIRBAG INFLATOR MODULE for certain 2003 – 2006 model years that came out in Oct 2019.
  16. Jan 23, 2020 at 7:50 AM
    speedtre
    speedtre New Member
    Inland Northwest
    And if, like me you have curtain air-bags, there is one for that too...
  17. Jan 23, 2020 at 7:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wish I had curtain airbags. Were they standard on DC's or just an option?
  18. Jan 23, 2020 at 8:08 AM
    speedtre
    speedtre New Member
    Inland Northwest
    They were an option...I just lucked out, as I would have bought it regardless...but I'm glad to have them.
  19. Jan 23, 2020 at 8:13 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Mine is the same but they are apparently replacing both driver and passenger under the recall.
  20. Jan 23, 2020 at 8:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    When I had mine performed in Oct, they may have mentioned that but don't recall. It's my understanding is that the Oct 2019 was a recall of the recall that I had performed in later part of 2018. Hopefully they get it right or have gotten it right finally. Don't want to ever have to need it but when I do need it, work properly :amen:
  21. Jan 23, 2020 at 8:51 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I'm comparing it to roll-on or brush-on bed liner I've seen applied to beds, body parts, and entire trucks. The rolled/bushed-on has a much more severe texture -- it looks almost furry and not very uniform. The Duplicolor goes on even and just has a mild texture to it. I don't get the feeling it would stand up to abrasion like a professional bed liner, but I don't expect my bumper will be subject to much abrasion -- just the occasional bump or scuff. The Duplicolor also seems like it would be easy to touch-up in the event of a more substantial mishap. (although that's speculative since I haven't had to do any touch-up)
    Mustanley likes this.
  22. Jan 23, 2020 at 9:25 AM
    JustJake
    JustJake New Member
    2006 AC
    My interior color code is FD11 (it's a light gray). I am trying to find spray paint to touch up a trim piece. Can anyone point me in the right direction.
  23. Jan 23, 2020 at 9:56 AM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    @oscardog86 Looks like there is a 2003 in chula vista that showed up today. It looks like it has the TRD 4runner wheels
  24. Jan 23, 2020 at 10:06 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I ordered a grey 36" High Wedge Design DCU cap
    with dual rear doors from my local A.R.E. dealer.
    My new cab height LEER 100R is up for sale.
  25. Jan 23, 2020 at 10:32 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That will be sweet. I know that wasn't cheap. I priced out new ones a few years ago and didn't realize how much they cost. Some guy out there is probably looking for a long bed camper and will be happy when he comes across your listing. There likely isn't many of those out there.
    Rex Kramer[QUOTED] likes this.
  26. Jan 23, 2020 at 10:39 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Thanks for the heads up! But im over in LA county area so thats a bit of a drive. Plus im interested in a front bumper to practice on for modding my bumper i currently have on the truck.
    jImmegart[QUOTED] likes this.
  27. Jan 23, 2020 at 10:45 AM
    Rex Kramer
    Georgia
    I didn't realize how much they cost either... long tube headers for the 2007 will have to wait.
  28. Jan 23, 2020 at 11:27 AM
    jImmegart
    Jonah
    California
    Ya its like 1hr and 40 from me and all I want is a black rear bumper but I can barley see it. Anyone in san diego area there is a tundra with trd pros in the chula vista west junk yard. If someone goes, let me know if the rear bumper is factory painted or sprayed after! It came up today so everything should be there.
  29. Jan 23, 2020 at 12:44 PM
    jImmegart
    Jonah
    California
    Tried some carguys plastic trim restorer on the flaps, bumper step cover, and mirror. The flaps didn't seem to come out very well so might need to paint them? Not sure how to make them dark again, but I dont except this stuff to last very long.
    theblurry1, Darkness and oscardog86 like this.
  30. Jan 23, 2020 at 2:19 PM
    Hand Protectors
    Noticed the pass side door courtesy lights not coming on yesterday at Dereks Center.
    Pulled the 1 year new Wells Door Switch off for inspection. The OEM tape around the plastic wire base had shrunk loose inside the door and the inside metal friction tab was not full contact. Put some electric grease in the slot and taped up the connector. Switch Operates Flawlessly!
    Stoked!
    Cancelled last nights brake lines flawed order. Placing another order via Wheelers tonight per @FirstGenVol recco. All the nuts are 10mm btw with exception of one 14mm? on the rear hose at the ‘tee’ above the rear diff.
    Cleaned up the brake flare nuts and put some penetration oil on them in prep for next weeks hose replacement. Nothing wrong with the hoses now. Brakes seem fine to me now. Nothing ‘overly’ spongey at the pedal. Actually feels nice as ever since the fluid bleedings coupled with the parking brake cable tuned in. Doing this for prevent maintenance with a side benefit of slightly better pedal feel per reviewers. Better braking?
    Ordered up the rear drum brake cylinders rebuild kit at Stealership. I’ll reconsider plans on the front calipers once everything above is dialed in. May just rebuild the WE’s to keep cost down. The pads/rotors are less than 14k miles old.
    Truck is driving sweetly.
    bmf4069 likes this.
