  1. Jan 19, 2020 at 8:02 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    I think that's the reason it's difficult today.
    imDementeD[QUOTED] likes this.
  2. Jan 19, 2020 at 8:37 AM
    Professional Hand Model
    Hand Protectors
    Crawled under the 02 yesterday to inspect Bearing/Axle job. Everything looks like it was put back into place and cleaned up nicely. Will drive it a few more days and do some rear shoes brake service. I have new shoes and want to buy new Toy brake cylinders.
    Should I buy new spring kits? Turn my old OEM rotors at shop?
    Never done brakes before.
    TX-TRD1stGEN likes this.
  3. Jan 19, 2020 at 8:44 AM
    bmf4069
    TX
    02 AC sr5 4wd v8
    New drum stuff is cheap enough I just replace it all. But mine was garbage anyways. You can get the drums turned anywhere.
  4. Jan 19, 2020 at 8:49 AM
    Hand Protectors
    Thanks. The online Toy parts is pricey on the separately sold springs/etc. I’ll call stealer this week, to see if they have an OEM Kit, and price them out. I definitely will be buying new OEM wheel cylinders.
  5. Jan 19, 2020 at 9:01 AM
    bmf4069
    TX
    02 AC sr5 4wd v8
    OEM is always more. RA has the kits you need, and reputable brands.
  6. Jan 19, 2020 at 9:08 AM
    Hand Protectors
    Thanks for this. I want OEM cylinders for sure. You guys think the NAPA springs kit (pictured) is good with proper fitments and parts?
  7. Jan 19, 2020 at 9:36 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    You said you were looking all over for a project and you like step sides. Plus it's in the south which means a clean frame no rust.
  8. Jan 19, 2020 at 9:41 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Strange. I've never had an issue with titles in Texas. One party signs (I honestly don't recall which) one takes the title.
    speedtre likes this.
  9. Jan 19, 2020 at 9:41 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    No more projects.. gotta finish my Tacoma now
  10. Jan 19, 2020 at 9:42 AM
    empty_lord
    05 rollover special
    My title was easy.. they came out, did the vin check, said holy shit this things fucked up... and I got a title within a few hours
    KarmaKannon likes this.
  11. Jan 19, 2020 at 9:44 AM
    empty_lord
    05 rollover special
    Napa springs are fine
    Have the drums turned. Aftermarket drums are a noisy nightmare
  12. Jan 19, 2020 at 9:51 AM
    SOS CONCEPTS
    SOS CONCEPTS SOS Concepts
    RHD specialties out of Charlotte is importing the shit out of them now that the 25 yr rule permits importation of R33s without DOT, EPA, etc. We have a bunch of R32 & 33s running around NC as well as other imported cars that fall under that 25 yr rule.
    A lot of people actually have figured out how to register vehicles in TX, TN or other lax states so they can essentially drive race cars on the st.
    mcharfauros and bmf4069[QUOTED] like this.
  13. Jan 19, 2020 at 9:54 AM
    Hand Protectors
    Thanks. This confirms a few readings I’ve done. Best to use the factory drums. Mine still have the counter balance weights on them.
    Those Powerstop drums (and others) have horrible reviews.
    Whats your take on a rear drum shoe cylinder rebuild? They have OEM rebuild kits (cups/springs) for around $23.
  14. Jan 19, 2020 at 9:58 AM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    020D3612-05D2-402A-BEE4-58B89027C1CB.jpg A90BF07E-6E9A-4926-9FF7-EC6C393F6196.jpg Made some bracketry out of 3/8 plate, did a custom bend at work on the 20ton harbor freight press(my lead said “good luck”) I welded 1/2” bar stock on the center line of the bend, then flipped it and welded two more even spaced from that center line, slapped it in the press, easy peasy!
    @KarmaKannon if my double sheer Heim joint doesn’t work out,I might have to order that 4xinovations hinge kit, because now I’m stuck trying to figure out a good open/close stop
  15. Jan 19, 2020 at 10:01 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Looks good! The only thing I'd caution is maybe leaving a little Gap in the inside corner of the gusset for water and mud to escape.
  16. Jan 19, 2020 at 10:01 AM
    empty_lord
    05 rollover special
    I do rebuilds.. it’s not hard. Saves money. Hell I rebuild my own front calipers too
  17. Jan 19, 2020 at 10:07 AM
    SOS CONCEPTS
    A company already tried a dual double shear heim set up for a swingout hinge, it wasn't too sturdy.
  18. Jan 19, 2020 at 10:07 AM
    Hand Protectors
    Ok. Got it. I’ll do a rebuild kit on the rear cylinders. Might buy the front kits just for grins, too.:D
    Then do a DOT5.1 fluid swap. :yes:
  19. Jan 19, 2020 at 10:08 AM
    Hand Protectors
    You just challenged him into success.
  20. Jan 19, 2020 at 10:27 AM
    empty_lord
    05 rollover special
    Overkill.
    Just like me
  21. Jan 19, 2020 at 10:42 AM
    KarmaKannon
    Utah
    Some junk
    If the mount is strong I see no reason heims wouldn't work. They seem to do a good job holding my tire and knuckle straight.
    Brown Bear and mcharfauros like this.
  22. Jan 19, 2020 at 10:44 AM
    SOS CONCEPTS
    I hope so. Just know from what I've seen it doesn't work as well as a true one direction joint.
  23. Jan 19, 2020 at 10:45 AM
    KarmaKannon
    Utah
    Some junk
    Two hiems in double shear and on the same pivoting axis are a one directional joint with adjustable legs.
  24. Jan 19, 2020 at 10:51 AM
    SOS CONCEPTS
    No that wasn't the issue at all its the vertical axis when opening the gate they drooped inherent to the design of that joint.
    Kinda it still drooped a little until bind. They had to adjust them so that one was "pulling" the other "pushing" from the joint. What 4x sells as well as the spindle style work better for a swingout. But if you can accomplish it the awesome.
  25. Jan 19, 2020 at 2:19 PM
    KarmaKannon
    Utah
    Some junk
    I would be interested in seeing this bearing setup that has literally no play in it. Might not be so good if you have any movement during welding(because it wouldn't be adjustable like hiems), but it would be impressive nonetheless.
  26. Jan 19, 2020 at 3:34 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    Hot water heater passed away today. Bought a new one, brought the Tundra to the pickup area & parked next to a 4dr 1st gen.
    Had to remove my trifold for it to fit. Need an 8' bed or taller bed sidewalls. Canoe needs taller sidewalls too.
    Of course the heater gave up on a Sunday, & Monday is a plumbers holiday. guess I'll be making hot water on the stove top Monday.
    But the Tundra is spot on.
    Darkness likes this.
  27. Jan 19, 2020 at 3:43 PM
    empty_lord
    05 rollover special
    I recently replaced our dead water heater and the dying radiant heat water heater. With a Navian boiler and a indirect water heater for domestic.... that was fun.
    FrenchToasty and NUDRAT[QUOTED] like this.
  28. Jan 19, 2020 at 4:18 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    Love seeing this thing after work!
  29. Jan 19, 2020 at 4:33 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It was a US car that he imported to Mexico, then we struggled to bring it back here.
    bmf4069[QUOTED] likes this.
  30. Jan 19, 2020 at 4:54 PM
    jImmegart
    Jonah
    California
    Anyone know if the 05-06 tail lights are interchangeable with 00-04s?
    because_wumbo-truck likes this.
