  1. Jan 3, 2020 at 10:14 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Most of the ones I see are lightweight editions. Aka the beds rotted out
  2. Jan 3, 2020 at 10:15 AM
    Bubbles
    Bubbles Decent!
    Sunnyvale Trailer Park
    05 Tundra Limited, 96 Supra Turbo 6MT
    oooo the LTW mod.
  3. Jan 3, 2020 at 10:22 AM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    For living near the beach rust isnt bad here, Uncles is super rusted but he lived in Tahoe for ten years and never cleaned the underside of salt nor done any work on it, Only oil changes every 5000. His tires are from 09 and basically bald with it misaligned. I see alot of DC.
  4. Jan 3, 2020 at 11:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I see a TON of 1st gen Tundra's here in East TN but they usually aren't in great shape. I rarely see many that have been modded and the most common are white access cabs that haven't seen a coat of wax in a decade.
    I recently stopped near another 1st gen at a light and saw the guy take a picture of my truck. I blushed.
  5. Jan 3, 2020 at 11:17 AM
    empty_lord
    05 rollover special
    i'll never forget the moment i had a guy in a ferrari stop to take a picture of my truck..
    i still wonder how many WTF IS THIS THING reddit threads my truck is on
  6. Jan 3, 2020 at 11:33 AM
    Professional Hand Model
    Hand Protectors
    Did he get the business side or the party side?
  7. Jan 3, 2020 at 11:59 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Where are you located? For some reason I thought you were in the south west
  8. Jan 3, 2020 at 12:04 PM
    empty_lord
    05 rollover special
    Chicagoland.
  9. Jan 3, 2020 at 12:53 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    perfect time for throwing him a T sign....he be like WTF
    Darkness and because_wumbo-truck like this.
  10. Jan 3, 2020 at 12:57 PM
    empty_lord
    05 rollover special
    Well ordered another $518 in parts
    napa premium lower control arms - $150 each (OEM my cost was about 230.. nope)
    OEM ball joints - $185 as a kit (recall part number)
    Napa end links - $35 total
    and i surprisingly had some camber sleeves and nuts and bolts.
  11. Jan 3, 2020 at 2:48 PM
    jImmegart
    Jonah
    California
    Two questions. first one is would adding a rear sway bar stiffen up my ride a lot? or is it really only worth it for hauling heavy loads?
    And second does anyone have a a muffler they use that doesnt drone alot? I was looking at the dirtydeeds ones with the Reso on is but looking for other suggestions. I dont wanna dumped after axle either because I have a snug top on.
  12. Jan 3, 2020 at 2:58 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I thought a sway bar was.more for corner by preventing body roll
    What does your snugtop have to do with dumping the exhaust?
    oscardog86 and FrenchToasty like this.
  13. Jan 3, 2020 at 3:03 PM
    Hand Protectors
    Hellwig 7700 stiffens and plants the rear end. I highly recommend! It has 3 settings of which you start with the less stiff and move progressively depending on your preference. I moved to the middle setting and have left it there for about a year. Makes the truck drive sporty. Handles sharp corners without wobbling around like it used to. Adds stability for towing. Highway speed lane changes are quick and responsive. I also have the original front sway bar. All around good for regular driving and tow/haul.
    Muffler? I still have the OEM. Read up on some members recommending Walker as a decently priced, delivered to the door, and DIY friendly option.
  14. Jan 3, 2020 at 3:04 PM
    jImmegart
    Jonah
    California
    Ya it is but I would think when the bed is empty it wouldn't body roll nearly as much as with a heavy load. I drive with the bed empty or light loads most of the time, so seeing if someone who has it thinks its worth the purchase
    Ive seen a few people say if you dump the exhaust right behind the real axle or any where down to the ground it will resonate through the bed and get trapped by the top. I think
  15. Jan 3, 2020 at 3:05 PM
    empty_lord
    05 rollover special
    it will. you want the tailpipe to exit off to the side or out the back of the truck
    I personally plan on running 2 QTP mufflers when i do my exhaust... loud and quiet mode.
    bmf4069 and jImmegart[QUOTED] like this.
  16. Jan 3, 2020 at 3:06 PM
    jImmegart
    Jonah
    California
    That was the one I was looking at. I wanted to upgrade rear shocks as well so maybe when I do that I get the hellwig and do them both. Thanks!
  17. Jan 3, 2020 at 3:11 PM
    Hand Protectors
    My truck suspension went through 3 phases:
    1) Old and worn out front suspension with broken front sway links.
    2) Front end rebuild with new front sway links and a working front OEM bar again. Felt good again!
    3) Added Hellwig rear and WOW! why didn’t I do this sooner?
  18. Jan 3, 2020 at 3:12 PM
    empty_lord
    05 rollover special
    i dont know if i'll do a rear sway bar.. unless i can devise a way for quick disconnects.. i dont want to kill the rear suspensions flexibility
  19. Jan 3, 2020 at 3:17 PM
    Hand Protectors
    I don’t climb rocks so no need for rear end flex in my case. Any off road is sand driving which doesn’t require flex. If you drive street mostly and tow/haul the Hellwig is key.
    A quick connect would be nice if one was alternating between daily driving and rock driving on a daily basis. Might look goofy with those pull pins?
    FrenchToasty likes this.
  20. Jan 3, 2020 at 3:18 PM
    empty_lord
    05 rollover special
    i havent looked at the rear design. but looks wont matter to functionality. ive been thinking about a DIY QD front setup too.
  21. Jan 3, 2020 at 3:22 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s nice because you only need to disco one side. I want to find someone to go in on a set with!
  22. Jan 3, 2020 at 3:25 PM
    Hand Protectors
    This makes sense. Kills two (maybe 4 birds) with one stone?
    Although, that rear sway might catch/jab on some rocks on the other side still connected.
  23. Jan 3, 2020 at 3:48 PM
    empty_lord
    05 rollover special
    [​IMG] [​IMG] Added some more foam to the kick panel area. (from a gun case, going to try and find the same stuff as oem)
  24. Jan 3, 2020 at 4:07 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    lol .. I was watching those. Figured someone here probably scored a deal.
  25. Jan 3, 2020 at 4:56 PM
    empty_lord
    05 rollover special
  26. Jan 3, 2020 at 5:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @jImmegart there are a few keys to getting a muffler that doesn't drone.
    Don't go to a bigger pipe size, you can get by with 2.5" if needed but nothing beyond that. Make sure the tailpipe exits out the side or out the back to avoid reverb. Stay away from chamber mufflers (flowmaster or magnaflow) as they tend to drone from all the walls in the baffle. A straight through muffler usually won't drone if sized right but may be raspy.
    Dirty Deeds makes very good mufflers for first gen trucks. I've heard a couple in person and they can be mellow. I've been running a Spintech Prostreet with the stock piping for 9 years, no drone but it's a bit on the loud side.
  27. Jan 3, 2020 at 5:11 PM
    empty_lord
    05 rollover special
    magnaflows are straight through (at least the ones ive had) flowmaster is the only baffled design i can think of.
    Darkness[QUOTED] likes this.
  28. Jan 3, 2020 at 7:03 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Well, I’ve got the rear shocks in, and am now working on the front. This darn axle nut is going to be the death of me. And tips to removing it?
    bmf4069 and because_wumbo-truck like this.
  29. Jan 3, 2020 at 7:05 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Breaker bar with four foot pipe.
    Helps if you put your tire back on and on the ground so it doesn't spin
  30. Jan 3, 2020 at 7:05 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Why do you need to remove that? Are you doing some work in addition to the c/o's?
