  1. Dec 21, 2019 at 7:51 PM
    2000Strong
    2000Strong Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    What did you put in I put in a Sony xav ax1000
    because_wumbo-truck likes this.
  2. Dec 21, 2019 at 7:51 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve got a 2019 Toyota 86 factory radio
    bmf4069 and because_wumbo-truck like this.
  3. Dec 21, 2019 at 7:52 PM
    2000Strong
    Benjamin
    Washington
    Oh sick
    empty_lord[QUOTED] likes this.
  4. Dec 21, 2019 at 7:54 PM
    2000Strong
    Benjamin
    Washington
    Every light in my truck including my cluster got replaced with leds I might change the blinkers to incandescents as they are pretty bright and distracting when blinking. Only bulb I didn’t have was for the cig lighter so I took the condom off the factory oem bulb.
  5. Dec 21, 2019 at 7:55 PM
    empty_lord
    05 rollover special
    My gauge cluster is led from
    The factory so I’m good there. Everything else will be led soon
    Including the switches
  6. Dec 21, 2019 at 7:58 PM
    2000Strong
    Benjamin
    Washington
    Awsome the truck at least a 00 model uses like 20 c74s
  7. Dec 21, 2019 at 8:11 PM
    empty_lord
    05 rollover special
    That’s common. Order the hose now before it breaks and your stuck or worse
    NUDRAT likes this.
  8. Dec 21, 2019 at 10:38 PM
    empty_lord
    05 rollover special
    Better photo of the leds, full brightness. [​IMG]
    Rheywood456, bmf4069, BubbaW and 2 others like this.
  9. Dec 21, 2019 at 11:41 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Man I like that radio. I hate that my aftermarket radio don't automatically connect to my phone's Bluetooth like factory radios do and I miss having a volume knob with push to mute.
  10. Dec 21, 2019 at 11:46 PM
    empty_lord
    05 rollover special
    I love it, get in the truck and it connects automatically. Give it 30-40 seconds and musics playing
    It even reads my text massages to me
  11. Dec 22, 2019 at 1:12 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I'm just glad mine hand hands free calling but I wish it had all that
  12. Dec 22, 2019 at 4:29 AM
    Professional Hand Model
    Hand Protectors
    Mine were plug and play. I already had PerfectFit Fogs. No resistors needed. My Katanas did come with a driver pack? of some sorts (about the thickness and length) of a cell phone fold over on itself. I zip tied it to my other wiring.
    These new ones do not appear to have this driver? as its built into the bulb.
  13. Dec 22, 2019 at 4:55 AM
    Hand Protectors
    Its a hand model access only site. You’ll need 20 years experience before entering, but I give you the secret code. Just make sure not to get hurt out there. Ok?
    Go to toyota parts deal . Com for parts numbers THEN cross reference for better diagrams with your local online stealerships.
    hammeron, bmf4069 and FrenchToasty like this.
  14. Dec 22, 2019 at 5:01 AM
    Hand Protectors
    When is your write up coming?
    bmf4069 and BubbaW like this.
  15. Dec 22, 2019 at 5:02 AM
    Hand Protectors
    You can make/retrofit using the Partsams bulbs for that cig light.
  16. Dec 22, 2019 at 5:24 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Sweet! We have off untill the 2nd, campus wide shut down, it’s beautiful!
    I’m sure you will build something cool with your time off. My rear bumper is a kit from coastal offroad, it should turn out pretty badass once I get it done. I’m off on my frame rail holes by maybe a 1/4” total, so I might try and take pipe clamps(2 facing opposite directions) and slowly bend the rear section of the frame back square or just enough to get my bolt holes to line up. Hopefully after that hiccup it will be smooth sailing for the bumper assembly
  17. Dec 22, 2019 at 7:19 AM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Thank you... did remove, clean and seal... too cold to run a leak test...waiting for warmer temps...
  18. Dec 22, 2019 at 7:21 AM
    delz05
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Had not thought of that... next on the list when the temp rises a bit! thank you!
  19. Dec 22, 2019 at 7:26 AM
    delz05
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Yes... it was in the T3 movie... too old to remember exactly, but I think it came out in 03 or 04,,, all black Tundra Access Cab, special version of the front grill too!
  20. Dec 22, 2019 at 7:48 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Is that a normal fail - the hose leaking with a clamp on it?
    I'd just assume a crack in the neck it's attached to.
    Do you see that much - the neck cracking? Conversely, do you see the hose leaking often?
  21. Dec 22, 2019 at 8:27 AM
    Bubbles
    Bubbles Decent!
    Sunnyvale Trailer Park
    05 Tundra Limited, 96 Supra Turbo 6MT
    Damn I can't even find my ashtray's light, its just not there... Also some of my switches have blown bulbs too. I just want to replace with OEM bulbs with the green condoms, anyone wanna sell me a bunch of good bulbs yall removed after doing LED's so I can get all of mine back to working order?
  22. Dec 22, 2019 at 8:30 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    On 2004 one has to remove the ashtay frame held on with 2 phillips…..2005 not the same ?
  23. Dec 22, 2019 at 8:35 AM
    Bubbles
    Bubbles Decent!
    Dunno, I was looking for the wiring. Simply pulled the ashtray out and was like.... I see no light...
  24. Dec 22, 2019 at 9:00 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Jacked up the front today with the beast and checked each tire for any movement. First time doing this since replacing the outer tie rods. The side to side wiggle is gone.
    Also cleaned up the interior. This stuff has become a favorite for the dash and also works on the tires. Doesn't the dash greasy like armor all.
  25. Dec 22, 2019 at 9:15 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Can I get a YouTube video of these instructions please? Haha. I found em and ordered them last night after looking at pictures of the 2nd part number they match up correctly. Now to see if I can return these other ones unless someone with an access cab (I assume since the headlight assemblies are different/smaller) wants these covers.
  26. Dec 22, 2019 at 10:13 AM
    empty_lord
    05 rollover special
    When I get the backup camera done. Holidays come first though
  27. Dec 22, 2019 at 10:15 AM
    empty_lord
    05 rollover special
    It’s becoming a common sight. Once its leaking like yours if you just touch it hard enough it’ll snap off. Dealers usually stock them.
    lsaami likes this.
  28. Dec 22, 2019 at 10:36 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do you recall what size diameter hose fits into the front diff? I'm gearing up for a drain+fill.
  29. Dec 22, 2019 at 10:41 AM
    Hand Protectors
    I ran a 4’ long piece of 1/2” PVC line down from the upper radiator area. Put a slight bend in it to fit the diff hole angle. Put the funnel into the top other side of pipe and poured like I was doing a radiator top off.
  30. Dec 22, 2019 at 10:42 AM
    Hand Protectors
    Yes they do. Merry Christmas! And Merry Christmas to All! Hohoho!
