  1. Dec 16, 2019 at 4:33 AM
    Professional Hand Model
    Hand Protectors
    Good points. On all of my exteriors I’ve used the Zevos or LL Sylvanias, as well (except for the headlight/lamps). Zevos have a lifetime warranty and Autozoned is right up the skreet. I’ve only used the el cheapo made in Chinas due to that size bulb is not available off shelf. The Autozoned guy actually recco’d the Partshams.
  2. Dec 16, 2019 at 5:55 AM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    that's exactly how my knobs are. i can barely seem them at night
  3. Dec 16, 2019 at 6:21 AM
    Hand Protectors
    IIRC there are 3-5 bulbs for the climate dash. Getter’ dun.
    kodyquist21[QUOTED] likes this.
  4. Dec 16, 2019 at 6:24 AM
    speedtre
    speedtre New Member
    Inland Northwest
    The entire harness, I doubt, a sub-harness for that system that plugs into the main harness, probably. What I would do, since you already have that piece, is to look at the parts fiche for the Sequoia, identify if there is a sub-harness (or that there isn't and then you are done, cause it's not worth it replacing the whole harness). If there is, then you would need to open up your dash and see if the Tundra main harness has the unconnected sub-harness connection tucked up in there. If so, then it may be as simple as just getting that sub-harness (this is assuming electronic control for the unit is all self-contained in that piece you have and that the sub-harness is mostly for power. If it requires a Sequoia main ECM, well, then it's again, a non-starter). It's not that much work to find out at this point since you already have the dash piece. Heh, if you make this work there will be a run on that dash piece and sub-harness at junk yards...:)
  5. Dec 16, 2019 at 7:06 AM
    kodyquist21
    Kody
    Buckeye, AZ
    Man, this is why i love this forum. y'all keep it up!
  6. Dec 16, 2019 at 7:18 AM
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    Is there a trick to pulling the climate control cover off?
  7. Dec 16, 2019 at 8:08 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Nope it's pretty easy
  8. Dec 16, 2019 at 8:39 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    They don't, no salt is used so it's just rain water. After my T-100 rusted out, I bought another one from Oregon and it had zero rust. It was really nice after coming from the east coast rotted truck.
  9. Dec 16, 2019 at 9:12 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Harness, blend doors, etc
  10. Dec 16, 2019 at 10:07 AM
    SOS CONCEPTS
    SOS CONCEPTS SOS Concepts
    Good to know thanks
  11. Dec 16, 2019 at 10:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    In my opinion, you're taking a big risk in buying 1 without seeing the frame in person. I think you mentioned before you were wanting to buy one online and have it shipped to you.. Or am I wrong?
  12. Dec 16, 2019 at 11:19 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I never could find the 3rd breather. I know @Professional Hand Model hand model said it was near the firewall. I only found the 2 that are mounted on the frame near the driver side front tire.
  13. Dec 16, 2019 at 11:28 AM
    empty_lord
    05 rollover special
    those 2 are the breathers for the Diff and the actuator on the diff tube. The trans and transfercase are ontop of the transmission
  14. Dec 16, 2019 at 11:33 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Would I be able to access them from under the truck? The other 2 were pretty nasty so I'd like to clean them out.
  15. Dec 16, 2019 at 11:37 AM
    empty_lord
    05 rollover special
    with long extensions and a swivel yes
  16. Dec 16, 2019 at 11:46 AM
    SOS CONCEPTS
    I said I could not a big deal. I've done it before and either shipped them or flew out and drove them home. Would rather find one around here but if I can't find something I'm looking for not afraid to look outside the state
    Bubbles likes this.
  17. Dec 16, 2019 at 12:00 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm procuring the parts for this job today. Is it really necessary to get the expensive Toyota FIPG? I have a tube of Permatex sitting on the shelf. I know I'm going to use only use 10% of the Toyota tube if I buy it.
  18. Dec 16, 2019 at 12:01 PM
    kodyquist21
    Kody
    Buckeye, AZ
    After work im going to sand off the black spray paint onmy rear bumper and spray it with bed liner. i've been digging the way it looks on other feeds
    Outbound, Darkness and FrenchToasty like this.
  19. Dec 16, 2019 at 12:37 PM
    Hand Protectors
    Your call. I happily paid it knowing thats what the Toy ‘pros’ use. The counter people helped me out nicely with a few things so it was worth it for me. Just think of your labor savings!
  20. Dec 16, 2019 at 12:38 PM
    Hand Protectors
    Thats what she said!
  21. Dec 16, 2019 at 12:38 PM
    empty_lord
    05 rollover special
    Permatex works fine. but the FIPG tends to last longer. hell i trust that shit so much i used it on my mothers ford flex when i did the water pump and had to reseal the timing cover
  22. Dec 16, 2019 at 12:41 PM
    Hand Protectors
    The third is between firewall and back of manifold. You can feel it before seeing it unless you have that Tom Cruise Levitation Device.
    Its hiding in plain sight once you know where to go. Its the plastic type breather on a long rubber hose on mine and should be in good shape where it is located not getting weathered. You should be good. Give it a swirl.
    FirstGenVol[QUOTED] likes this.
  23. Dec 16, 2019 at 12:42 PM
    Wings11
    Wings11 New Member
    Wings
    2002 Tundra garage whole life 80k
    So far new kicker speakers in doors and window tint all the way around
    Can anyone help me with the wiring of a backup camera. I've checked Mitchell and I don't think I'm getting the right harness diagram . I just need a visual on the wire I need to tap into for the parking switch I've got power . Ground and I'm pretty sure everything is correct
  24. Dec 16, 2019 at 12:44 PM
    Hand Protectors
    The other hidden breather is almost impossible to get to located on top of the transmission. A gorilla arm can touch it maybe, but getting a tool on it?
  25. Dec 16, 2019 at 12:50 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yeeesssssss. Is that not what the VSC is doing when a tire slips???
  26. Dec 16, 2019 at 12:57 PM
    empty_lord
    05 rollover special
    if you take the transmission cross member out and move the trans with a jack down, you can get your hand up there
  27. Dec 16, 2019 at 12:57 PM
    empty_lord
    05 rollover special
    VSC means you have trac
    luckily my tundra only has ABS. and even that i dont like
  28. Dec 16, 2019 at 12:58 PM
    Hand Protectors
    Push two vents pointed up to access a screw in each. Remove three control knobs and there are screws behind them. Pinch assy and pull. It will come out. Going on mammaries here so I may have forgotten something.
  29. Dec 16, 2019 at 12:59 PM
    empty_lord
    05 rollover special
    im going to try and make a nice breather setup for all the breathers.. thinking about running a metal line like the EVAP lines and have the rubber lines connect to it as a maifold as it goes to the front of the truck then into the ARB breather.
  30. Dec 16, 2019 at 1:01 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Create a thread for this question, it will likely get lost in this section if you don't.
    bmf4069 likes this.
