  1. Dec 14, 2019 at 4:40 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Removed the green. Now they just look sickly and don't match the rest of my trucks lights. Will have to buy some green LEDs or better bulbs and put the condoms on em
  2. Dec 14, 2019 at 5:00 PM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Costco had 6 quart boxes of Mobile 1 for $21.95 so I picked up a couple and grabbed some oil for the rear diff and knocked those out this afternoon.
    On a side note, mine has all its records from Toyota, including the last oil change around 4K miles ago and they forgot to put a crush washer on the drain plug - awesome. It had a slight drip at the plug so glad I went ahead and took care of that.
    Going to repaint the skid plate and fluid film tomorrow.
  3. Dec 14, 2019 at 5:02 PM
    Professional Hand Model
    Hand Protectors
    Bummer. Guess they are shot and need replaced.
  4. Dec 14, 2019 at 5:03 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah they're dim and ugly lol
  5. Dec 14, 2019 at 5:04 PM
    Hand Protectors
    Nice. Your instrument panel is different than the 2002 now that you mentioned this it makes sense now.
  6. Dec 14, 2019 at 5:04 PM
    Hand Protectors
    Musta been pretty bad.
  7. Dec 14, 2019 at 5:20 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Very nice setup! Have you used the recovery boards? What brand and how do you like them?
  8. Dec 14, 2019 at 5:25 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That, my good sir, is fucking awesome.
    That, my good sir, if fucking hilarious.
  9. Dec 14, 2019 at 5:27 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, I guess new bulbs may be in my future too.
  10. Dec 14, 2019 at 5:28 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Nice! How do your rear parking brake cables look? And how did the diff juice look? Rear axles seals still good? Breather mod done?
  11. Dec 14, 2019 at 5:38 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Battery appears to be a little weak....~9+ volts ???
  12. Dec 14, 2019 at 6:03 PM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    They are X-Bull, which I bought on Amazon, and at least when I was shopping they would periodically drop as low as around $60 for some colors.
    Have I used them? Sorta. So far I've only used them to level the truck so I have a nice flat bed to sleep in. I have not used them to get out of a predicament, as I have not yet gotten myself into a predicament. Guess I need to try harder.
    Do I like them? Meh. They are much bulkier than the expensive brands, and I'm sure they are not as good.
    I did find a video online once, where some guy in Australia, I think, compared them and the fancy ones, and these held their own, surprisingly. He did a variety of tests - getting out of sand, using as a ramp, and even as a bridge, and these were ok.
    As far as I can tell from my research (again, not personal experience) they aren't as good, but they might be good enough to be worth the price difference.
    If they break after a couple of uses you can replace them 4-5 times for the price of some of the others, but then maybe the others wouldn't break and leave you stranded somewhere.
  13. Dec 14, 2019 at 6:10 PM
    KarmaKannon
    Utah
    Some junk
    Perfect! That's pretty much what I'd seen about the xbull boards. I think that's what I'll get because as you stated I can replace them many times over.
  14. Dec 14, 2019 at 6:57 PM
    Hand Protectors
    Since everyone is grooving on the light bulbs here is the ignition ring with the same white Partsham bulbs used in the other areas discussed today. Blues were used on the instrument cluster. White Zevo Sylvanias used on the dome, map, and door lights. She lights up good now.
  15. Dec 14, 2019 at 7:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Led interior bulbs are my next thing for sure... granted having map lights and a dome light in the reg cab is already overkill
  16. Dec 14, 2019 at 7:07 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    That was a great post dude! I enjoyed all the organization and the labeling. I do the same thing with my grocery bags too. I think they work better cuz they have handles to hang them and they are pretty thick/strong plastic. And perfect size too
  17. Dec 14, 2019 at 7:08 PM
    Hand Protectors
    You should try the jumper mod at the map light. Removing those metal lens covers helps to really light it up.
  18. Dec 14, 2019 at 7:17 PM
    KarmaKannon
    Utah
    Some junk
    I know you posted it before but what did you use for the ignition ring? Not sure why I want one but I want mine red.
  19. Dec 14, 2019 at 7:26 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Thanks. Leaving it completely stock. I was in a Tacoma DCSB but needed a little extra room, so started my hunt for a 2005-06 Tundra AC. Don't need or want a full-size double / crew cab. The 7/8ths size is just right. These AC's are hard to find in good condition for sale. I may upgrade the 16" wheels to 17", but otherwise it is staying stock.
    I am not. He stole the name from me... :) . Seriously, I have been called this for the last 35 years...
    It is indeed the Bluesteel Mica. I love the color. I was searching for white / silver / gray, and I am surprised how much I like this color. Very unique.
    Yes, last year at 99k miles. The service records are very good.
    Thanks for the welcome guys!
  20. Dec 14, 2019 at 7:33 PM
    Hand Protectors
    I think Partsam sells them in red. Got these on Big Gurrrll in White and Blue.
  21. Dec 14, 2019 at 8:08 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    FWIW, the P.O. of my RV redid all the interior bulbs with LEDs. It took some hunting, but he found them in a color pallet that was very close to the old incandescent 12v bulbs instead of the harsh white of most LEDs. I've not had reason to dig in & find specifics, but something gentler is out there - FYI
  22. Dec 14, 2019 at 8:32 PM
    empty_lord
    05 rollover special
    Oh I took the covers off. It’s stupid bright
  23. Dec 14, 2019 at 8:32 PM
    empty_lord
    05 rollover special
    My Avalon is all led interior lights. Its wonderful
  24. Dec 14, 2019 at 9:00 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    Cables looked good, seals were good, diff oil was actually somewhat clean. When I changed the diff oil in my ‘03 AC it smelled burnt and was dark. This one was slightly dark and the magnet had a little grime on it, previous owner had the fluid changed at 50K and 100K.
    Haven’t done the breather mod, this thing will never be in water so, correct me if I’m wrong, I didn’t think it’d be worth it?
  25. Dec 15, 2019 at 12:13 AM
    KarmaKannon
    Utah
    Some junk
    The breather mod is mostly done to keep the axle seals from going south if the factory breather gets clogged. I used a fuel filter on mine when I rerouted it to the tail light area.
  26. Dec 15, 2019 at 12:15 AM
    empty_lord
    05 rollover special
    I’ve got an arb diff breather I got for work done on a truck... need to get that sucker plumbed up still
  27. Dec 15, 2019 at 4:01 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Look for a something in the 3000k range, the cool white is closer to 5000k the lower you get on the spectrum the more yellow it gets.
  28. Dec 15, 2019 at 4:12 AM
    Hand Protectors
    At the minimum, just install a new one. The road grime and salts can take a toll on these like they did mine which lead to clogging which lead to my axle seals blowing ($$$). I think the part is around $10-15.
  29. Dec 15, 2019 at 4:19 AM
    Hand Protectors
    Good chart. Most people don’t realize about the Kelvin Scale and how it affects what you see. My Sylvania Zevos are in the 5-6k scale by looks (not sure of the exact spec). I like it lit up, when I want light, and these do the job very well. A more modern look.
    SOS CONCEPTS and bmf4069 like this.
  30. Dec 15, 2019 at 4:29 AM
    Hand Protectors
    I hear you. In your situation on the RV, I’d want softer light around 3k as you probably have these lights on all the time for living inside. Like Fester suggests, 3-4k is ideal and what I have in my home relaxation areas. For the truck, 5-6k daytime bulbs for quicky need to see it all light are the go to. Just depends on what the space requires and personal choice, as well.
