  1. Dec 4, 2019 at 10:51 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
  2. Dec 4, 2019 at 11:24 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’m seriously debating a rigid slim 30” for the bumper and throwing some ditch lights on. The new oem headlights are bright. But out in the country roads all the light I can get will help with deer. Already almost creamed 3 with this truck.
  3. Dec 4, 2019 at 12:31 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Time for a big bumper
  4. Dec 4, 2019 at 1:03 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Exactly my plans for this. I have two 6” pods in the grill guard already, so I plan to put the 20” bar up front, a couple 4” pods in the rear for combo reverse/rear lights, something in the topper, and maybe something on the sides.
    you can never have too much lighting.
  5. Dec 4, 2019 at 1:15 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Closing time at the bar might disagree with you... ;-)
    NUDRAT and lsaami[QUOTED] like this.
  6. Dec 4, 2019 at 1:17 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I don’t drink, so no worries there.
    :cheers:
    speedtre[QUOTED] likes this.
  7. Dec 4, 2019 at 2:15 PM
    empty_lord
    05 rollover special
    I would like to. But that’ll be later on. I’ll probably fab one up. For now the factory steel bumper works fine and doesn’t kill the gas mileage.
    KarmaKannon likes this.
  8. Dec 4, 2019 at 2:18 PM
    Professional Hand Model
    Hand Protectors
    These came today.
    bmf4069 and FrenchToasty like this.
  9. Dec 4, 2019 at 2:28 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Maybe it’s cause of all your hand modeling but all I saw when you posted these was you flipping us off in the first pic. Lol
  10. Dec 4, 2019 at 5:33 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Cleaned up my new battery install. Swapped out the oem tie down and picked up some knobs just because..
    Darkness, oscardog86, NUDRAT and 3 others like this.
  11. Dec 4, 2019 at 6:17 PM
    turboser91
    turboser91 New Member
    Fresno
    06 DC 4x4
    6" RCD lift
    finally finished my fuse panel and switch panel. First time I've made this fuse panel.kou.jpg kou1.jpg
  12. Dec 4, 2019 at 6:41 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Very similar to what I wanna do. Nothing like having power right where you need it.
  13. Dec 4, 2019 at 7:01 PM
    empty_lord
    05 rollover special
    I keep looking at ssvec Eaton fuse boxes. Nice and compact. Still trying to figure out how I’m going to mount the sequoia center console so I can have switches in my tundra. Brackets don’t line up at all. Even though the front floor pan is the same part# as the sequoia vs reg cab tundra.
  14. Dec 4, 2019 at 7:05 PM
    KarmaKannon
    Utah
    Some junk
    Nothing like a car/truck manufacturer to make changes without telling anyone haha.
  15. Dec 4, 2019 at 7:09 PM
    empty_lord
    05 rollover special
    Well I see the holes under the truck. I’m just wondering what covers them up top. It might just be the asphalt coating with a sticker under it.
  16. Dec 4, 2019 at 7:19 PM
    KarmaKannon
    Utah
    Some junk
    That actually makes a lot of sense. Probably easier to have a mounting fixture than trim some of the insulation adhesive stuff different on some models.
  17. Dec 4, 2019 at 7:21 PM
    empty_lord
    05 rollover special
    I’m going to poke around next time I have it at work: hopefully get it figured out. Then just figure out he ac duct at driver side of the floor
  18. Dec 4, 2019 at 7:38 PM
    Aerindel
    Aerindel New Member
    Montana
    Replaced the OTHER inner tierod end because after I did the first one and took it to get aligned the shop told me the other one that I thought was good, actually wasn't.
    NUDRAT likes this.
  19. Dec 4, 2019 at 9:15 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I believe that’s one of the things you should replace in pairs anyways. Like front or rear brake parts. Plus it’s only another $30-50 to ensure that both are up to snuff since one or both will still require an alignment after you’re done.
  20. Dec 4, 2019 at 9:49 PM
    Aerindel
    Aerindel New Member
    Montana
    To be fair, one side had a torn boot so I figured it was the only one worn out...which it was....its just that the other side was also worn, although only about a tenth as much.
    artsr2002 likes this.
  21. Dec 5, 2019 at 6:56 AM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Knocked out the TPMS bypass, I made it 24 hours with that light on and I couldn’t take it anymore. If we got real time pressure data, I’d keep them, but for a light? I can find better things to do with $200 and check my own pressure.
    Aerindel, Outbound and Volt92 like this.
  22. Dec 5, 2019 at 12:12 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    2011 White Tundra RW
    2.5” level kit. 35” KO2
    Amen
  23. Dec 5, 2019 at 12:18 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    Fog lights went in today. Replaced the factory headlight stalk and worked perfectly with some after market fogs. I’ll probably upgrade to oem when I find the right deal. Also performing the anytime fog mod tonight or tomorrow. Looks way better!B752AF05-CD9C-4894-8385-EF8CCADD2C57.jpg
  24. Dec 5, 2019 at 3:25 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Ok, I may get sent to the corner for time out but why do some members have a line thru their name :confused:
  25. Dec 5, 2019 at 3:26 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Wow really?
    I wondered the same thing too actually lol. Maybe they’re in timeout?
    BubbaW[QUOTED] likes this.
  26. Dec 5, 2019 at 3:42 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I hope not, A------- is my go to guy for brake explanations :eek2:
  27. Dec 5, 2019 at 3:47 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Temporary time out.
  28. Dec 5, 2019 at 3:53 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Haha I thought it was “backing the brown” or something
  29. Dec 5, 2019 at 4:00 PM
    Hand Protectors
    Wondering, as well. And whats with the goofy thick glasses guy everyone uses as their profile pic.
  30. Dec 5, 2019 at 4:05 PM
    empty_lord
    05 rollover special
    Where does everyone’s battery gauge sit when at a stop light? I don’t have a chance to measure it. Just trying to see if my alt is weak
