  1. Nov 30, 2019 at 9:59 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The door ones have holes and adhesive, pretty time consuming to take off. I slid masking tape in all around, then did a few inches of tape as a border with double layer of tape immediately around the strips to protect paint while I sanded them. Then I taped up plastic sheeting all around the area and did prep and paint with bed liner.
  2. Nov 30, 2019 at 10:00 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You could get white bed liner. Looks nasty when dirty but it should clean easy.
    One thing worth noting on bed liner, the rough texture will catch on your cleaning gear if you use those lamb skin looking wash mits.
  3. Nov 30, 2019 at 10:22 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm skeptical of going white. It's unlikely I could match my paint so then I'd have two shades of white. That's what happened with the plasti-dip. Plus I already repained my fenders black and mirrors too.
    Wait a minute! Just who the hell are you? "Paint it white".. Darkness would never say this.
  4. Nov 30, 2019 at 10:25 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I umm, I meant black bro. :D
    While you are at it you can pop off your bed rails and sand/spray them too. Those pop up pretty easy. If they match your door trim it looks good.
    bmf4069 likes this.
  5. Nov 30, 2019 at 10:27 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did you just suggest painting something a different color than black? :bananadead:
    Darkness[QUOTED] likes this.
  6. Nov 30, 2019 at 10:33 AM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    I don't have a photo, but I used carbon fiber look vinyl wrap and covered up the chrome strip. It's holding up great and I like the look. It's a snowy mess outside now so I can't get a picture.
    FirstGenVol[QUOTED] likes this.
  7. Nov 30, 2019 at 10:37 AM
    Trailscape
    Alabama
    2006 Tundra SR5
    I also did this. I used high bonding primer, bedliner spray, primer again and then white.
    On my 02 Tundra, I removed the original trim and covered the holes up with this thin trim I found on eBay.
  8. Nov 30, 2019 at 11:15 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Looks good. Any links for the screens? Did you space it out off the handle? I had to move mine away with washers to keep the handle from being visible in the video.
    Weatherproof fog light connectors for the power and an rca for the video.
  9. Nov 30, 2019 at 11:54 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Master Tailgaters is who I’ll use for the mirror camera; buy from their site or from Amazon.
    I’ll follow up on your other question once I get the mirror and get everything ran.
  10. Nov 30, 2019 at 12:23 PM
    Professional Hand Model
    Hand Protectors
    The texture from the bed liner undercoat should offset any slight difference in color once painted over in white. The white finish coat will smooth out the rough fiber catching Darkness alludes. My mitts don’t catch any jags when washing, but a microfiber will when dry.
    Bed liner is a nice finish raw. Hides smears and scratches. Will show a powdery rub, but a quick wipe with the raw hand gets rid of it.
    Trailscape has a nice example of the look.
  11. Nov 30, 2019 at 12:55 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nooooooo, I said he can get white bed liner but never said to use it :hattip:
  12. Nov 30, 2019 at 12:58 PM
    Trailscape
    Alabama
    2006 Tundra SR5
    Took a close look at my radiator and noticed an odd spacing between the hose and fan shroud.
    Is it possible someone put the wrong one in? Access Cab vs Double cab maybe..
    NUDRAT likes this.
  13. Nov 30, 2019 at 1:26 PM
    Hand Protectors
    Is it safe to say that having already replaced all 2002 Interior bulbs (2 doors, 2 map lights, 1 dome, 1 footwell) with new LED bulbs that there is now additional freed capacity to install 4 feet (2 feet per door) of LED flexible strip lights that consume 8.5 watts?
    Looking to add some of the said strip lights under the door jamb as down/puddle lights in the 15A Dome fuse circuit. Will ‘T’ off the door wires going to the door panel lights. Activated when all interior bulbs light when door switch opens.
    speedtre and FrenchToasty like this.
  14. Nov 30, 2019 at 1:39 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think it would be safe at .708 amps. Sounds like a pretty cool idea.
  15. Nov 30, 2019 at 2:01 PM
    Hand Protectors
    Thank you. Hows this look? Any suggestions? Type connector should be used to tap these wires pictured?
    I want quality that will hold the jiggles.
    bmf4069[QUOTED] likes this.
  16. Nov 30, 2019 at 2:14 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Why not just use a small spot type led and put them on the bottom of the mirror? Super easy to get into the mirror since you’ve got the door panel off and you wouldn’t have to worry about them staying stuck to the door.
  17. Nov 30, 2019 at 2:15 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've seen a few people put Sequoyah radiators in our trucks. That may be the case here.
    Trailscape[QUOTED] likes this.
  18. Nov 30, 2019 at 2:23 PM
    Hand Protectors
    Good idea and one I’ve thought through. Reasons why not to:
    1) Drilling a hole (not scared just don’t want to drill a hole in my mirror).
    2) Round puddle light is a direct spot type light.
    3) Cost.
    Reasons for LED strip:
    1) Flexibility in strip allows light up side jamb and also down on ground.
    2) Ease in install. Peel and stick. Not worried about peeling off.
    3) Future problems? Remove and done with it. Or, buy a new strip vs finding ‘round puddles lights’.
    4) Cheap cost
    5) Modular design allows strip lighting the full length of door from side jamb and up the other side jamb if I want it that long. Lighting will be far superior.
    speedtre likes this.
  19. Nov 30, 2019 at 2:52 PM
    Trailscape
    Alabama
    2006 Tundra SR5
    I tapped the door light and put an eagle eye led through the bottom of the door. Gonna swap it out with something like this.
  20. Nov 30, 2019 at 3:14 PM
    Hand Protectors
    You have rink? (Link in Chinese)
    bmf4069 likes this.
  21. Nov 30, 2019 at 4:07 PM
    Trailscape
    Alabama
    2006 Tundra SR5
  22. Nov 30, 2019 at 5:02 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I say frameless.
    If you're going for a display - go for a display.
    Questions, what is the fail method? If it sheits the bed, does it fail to basic mirror?
    Day / night - do they both have it?
    I've had several OEM auto-dim mirrors fail. They fail to day, so it works during the day, but are a PIA at night. Blinding.
    I'm the exception but will always opt for a basic day/night mirror w/ back up camera display anywhere else.
    Ever have setting sun behind you, or sun reflecting off the windscreen of the vehicle behind you? Auto dim won't compensate 4 that.
  23. Nov 30, 2019 at 5:12 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Mounted up this Amp Research bedstep. My open tailgate/bumper are just high enough that it’s hard for me to step onto so I’ve wanted one of these for a long time. I originally thought I wanted the rear under bumper one but found this front bedside one and used it at the side rear corner. I like it and these things are pretty stout. Drilled one hole and used an existing one from the towing receiver. Best $110 I’ve spent.
  24. Nov 30, 2019 at 5:13 PM
    Hand Protectors
  25. Nov 30, 2019 at 5:21 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    you're up in snow country. That's a nice set up, but I think I'd give all the joints a good dousing with Fluid Film. It's right in line of fire with tire spittle, road salt...
    CodyP[QUOTED] likes this.
  26. Nov 30, 2019 at 5:24 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    be more worried about the wages paid & environmental damage done to get you stuff so cheap. The Chairman is busy with his 10 new parks.
  27. Nov 30, 2019 at 5:28 PM
    KarmaKannon
    Utah
    Some junk
    What about lights under the rocker panel that come on when you unlock or open the doors? That's what I was thinking, but I don't mind your idea either. I guess the way I go depends on how hard it is to tie into that unlock circuit. What about a connector like these. It would require you cut your wire but at least it's more weatherproof than a scotch lock. Throw in some heat shrink butt connectors and some tesa tape and you'll be stylin. https://www.amazon.com/gp/aw/d/B01A6LTK44
    better than chairman Mao spying on you haha.
  28. Nov 30, 2019 at 5:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    [​IMG] [​IMG] Radios in. All plug and play. Microphone is mounted on the cluster bezel.
    Still need to add reverse camera and some small wires to make it all work 100%
  29. Nov 30, 2019 at 5:40 PM
    Hand Protectors
    That yellow line is my proposed install site for the peel and stick flex strip. The wires I propose to ‘T’ into are the 2 light wires going to the already existing door panel lights (light box connector removed in picture and light box still connected to door panel).
    The bottom of the door is slanted about 35° so the light will wash down and back (without blinding) where needed versus a limited mirror installed puddle type. The flexibility will allow the strip to come up and shine into the floor boards as well. Its a KISS design. Just trying to find an off the self local waterproof LED product right now.
  30. Nov 30, 2019 at 5:43 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Never even crossed my mind. Don’t even know what this fluid film is but I’ll get Er done. Thanks
    NUDRAT[QUOTED] likes this.
