  1. Nov 17, 2019 at 1:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    747509D3-6340-49AE-821E-2566FB39B5CB.jpg I did “tucson wash” trail with about 15 other rigs from “southern Arizona offroad” mainly jeeps and a huge long bed double cab power wagon. Truck did great! I forgot to put it in 4low going over a big obstacle but my spotters got me thru it.....unscathed for the most part. I’ll update with pics once people start sharing them.
    @KarmaKannon
    Who’s needs sliders when you have pinch welds!!!! ME! I need sliders!
    Question about your kick out, do you basically bend a 90 and then make one leg way shorter at the far rear to get that kickout action? Second, are you coping by hand, w a grinder or do you have a notcher? I think I might do all tube, no square stock
  2. Nov 17, 2019 at 2:02 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I think I bent the kickout to about 110-120* but it was just me experimenting. I used a notcher for the support tubes and I had to notch the main tube to the kickout by hand . Using the square tube just made it easy to keep everything square to the mounting legs, it was also less expensive than the round tube, and it will help keep the legs from acting independently and act more like a beam. Round tube would work fine for all of it but either you design the strength into it with thinner material or you use thicker material. I chose a little of both.
    This picture might show the kickout tube angle a little better. It actually hits the 2x2 close to 90* at the rear.
  3. Nov 17, 2019 at 2:12 PM
    FrenchToasty
    Mo
    Bone stock
    Haha I had to read that twice, but I understand. Someone recommended round tube after seeing the sq tube on the 4runner sliders(the main) so I was headed that route, but your logic makes a Lil more sense
  4. Nov 17, 2019 at 2:14 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Well, more fun on the parts truck today. Getting all the surface rust off the bed and fenders before it gets colder and before I install them on my truck. Hoping to have everything prepped this weekend, an next weekend start moving parts over.
    F6BAE00C-B98B-4F2C-A7D5-00E5AE642E40.jpg 21A49E85-5571-4A37-A8F9-FFF8E33DDC41.jpg 2A11105D-F56D-42B9-BEEB-6BC0C265A95F.jpg 8E4A2D93-B15F-4F27-88B8-08F81BD0470E.jpg
    hammeron, Darkness and speedtre like this.
  5. Nov 17, 2019 at 2:15 PM
    KarmaKannon
    Utah
    Some junk
    My mounts are also square so square cuts on these will keep everything squared to the mounts for and aft and tilt also. Round tube is just harder to make assemblies from in my opinion with some exceptions.
  6. Nov 17, 2019 at 2:29 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    That’s the throttle motor. Don’t mess with it. Mess that bad boy up and your in the hole for a new throttle body. And they ain’t cheap
  7. Nov 17, 2019 at 2:51 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    I also run 10-30 mostly because my engine has a lot of miles and I feel better with thicker oil.
  8. Nov 17, 2019 at 3:18 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    My throttle motor occasionally locks up after I cancel the cruise control. A few pumps of the pedal and a restart and it is all better. Any idea on the cause?
  9. Nov 17, 2019 at 3:27 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    http://www.lostakey.net/
    speedtre[QUOTED] likes this.
  10. Nov 17, 2019 at 4:02 PM
    Professional Hand Model
    Hand Protectors
    Try swapping in the donor TB and see how she does. Experiment on the broken one. So we can see inside. :yes:
    lsaami[QUOTED] likes this.
  11. Nov 17, 2019 at 4:09 PM
    empty_lord
    05 rollover special
    they get funky. big issue with those older ones. when you pump the throttle enough your mechanically pulling the plate. thats likely what frees it up. best bet is to try and clean out all the gunk in the throttle plate area
  12. Nov 17, 2019 at 4:13 PM
    Hand Protectors
    That SeaFoam Engine spray cleaner can penetrate into those butterfly pivots and clean them up. Its also a lubricant per the instructions.
  13. Nov 17, 2019 at 4:22 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Are you going to rhino line the bed?
  14. Nov 17, 2019 at 4:24 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Like it's been said, I ended up taking the mirror off to get at the bolts to make it easier as the closest to the door is hard to tighten and not scratch the door at the same time.
    On another front, I tried and tried on the tailgate assist but I've given up. I was adamant about the strut being tucked into the channel between the tailgate and truck bed side metal. The issue is the space is small (vertically as well) and doesn't allow for much room.
    The other issue was the 2 struts I tried measured:
    'A' strut was 6" long closed and 9" fully extended.
    'B' strut was 9.5" long closed and 15" fully extended.
    Those points and really a bit in between on the longer one I couldn't get to line up anywhere. This may paint a better picture with 'A' strut. With the tailgate up/closed, the strut needed to be anywhere from 4-5.5" long and then with the tailgate open it needed to be longer than 9" to reach anywhere worth mounting. I gave it about 2 hours or creative thinking and I'm at a loss so I'm giving up for now.
  15. Nov 17, 2019 at 4:31 PM
    Hand Protectors
    Never give up. Re-group and reconsider the layout I did yesterday. Its extremely ideal and not in the way as much as one would think. Sure, having it tucked in is most ideal but not possible as alluded earlier. I really like mine. Was out there messing with it today. So smooth.
  16. Nov 17, 2019 at 4:32 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    for now I’m going to paint the ground down spots with rust reformer, then paint, then clear.
    after that, put a layer of fluid film on, and then put a bed mat in. If that’s too goopy I’ll probably go to a rhino line in the spring when it’s warm out.
    NUDRAT and FirstGenVol[QUOTED] like this.
  17. Nov 17, 2019 at 4:41 PM
    Hand Protectors
    Might I suggest you do the Rust Reform and then Rustoleum Bed Liner (3-4 cans for about $35) over that? I did it and its nice. Put the OEM bed liner back in over the newly sprayed bed and then sprayed the plastic bed liner with Rustoleum, as well. Stiffens it up and refreshes it.
    ethan1911 and lsaami[QUOTED] like this.
  18. Nov 17, 2019 at 5:15 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Either way, the fluid film over the bed is a good idea in Minnesota. Put that on last and it's not going to rust. @Pudge is doing this with his truck in CT with good success.
    @lsaami speaking of that, you should protect that new frame before winter sets in. Need to fluid film that thing.
  19. Nov 17, 2019 at 6:10 PM
    winmutt
    winmutt New Member
    Started working on replacing the stereo today. That was after spending the day working on my buddies 04 silverado.
  20. Nov 17, 2019 at 6:36 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    er - uh oh?
    We had some wind.
    I get wind from the back of the property & from the front of the property. They meet in the driveway next to the house. I get these mini cyclones = tidy pile of leaves in fall, big ass pile of snow in the winter. Went outside for clean up & noticed something wrong with my pile of leaves.
    There shouldn't be any 'silver' leaves...
    UH OH.
    Who the hell painted the hood of my Tundra? I need to be sure not to go back there. Holy cr*p - it wasn't 'that' windy!
  21. Nov 17, 2019 at 6:40 PM
    empty_lord
    05 rollover special
    Well shit. I’d be pissed
    oscardog86 and NUDRAT[QUOTED] like this.
  22. Nov 17, 2019 at 6:48 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Guess if I ever have a free Saturday I'll see what the junkyard has in stock.
    Seriously makes the truck look like a junker. ...and it was just some wind took it off.
    Oh well, got the truck cheap. Starting to look like an expensive one would've been cheaper though. :frusty:
  23. Nov 17, 2019 at 6:53 PM
    empty_lord
    05 rollover special
    A decent body shop will likely charge less for a decent paint job than trying to find a clean hood
  24. Nov 17, 2019 at 6:56 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    In the meantime buy you some primer and Toyota white spray paint. It won't match like it supposed to because of aging process, but it'll look better and you've got nothing to lose now
    NUDRAT[QUOTED] likes this.
  25. Nov 17, 2019 at 6:58 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    lol - mine isn't that fast, it's silver. ;-)
  26. Nov 17, 2019 at 7:00 PM
    ethan1911
    X2 on this, ive had several Toyota’s and everyone of them has had problems with the factory paint.
    NUDRAT likes this.
  27. Nov 17, 2019 at 7:01 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Whoops... Silver then. I was thinking about my truck and my experience with the Toyota spray paint.
  28. Nov 17, 2019 at 7:22 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Nice thought. The issue here is that it’s freezing here already, and bedliner is a bit more picky than my hack of a paint touch up thy I can redo in the spring.
    that’s the plan. I washed it today to get the salt off. I plan to do a thorough fluid filming when I take the bed off so I have easy access to all sides.
  29. Nov 17, 2019 at 8:13 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It's a sign! Your truck is becoming faster as the silver gives way to black! Don't fight it, help it!
    PAINT IT BLACK!
  30. Nov 17, 2019 at 8:23 PM
    FrenchToasty
    Mo
    Bone stock
    What thickness did you go with for the 2x2 and the round?
