  1. Oct 12, 2019 at 3:52 PM
    Aerindel
    Aerindel New Member
    Montana
    No, what people are replacing is the rubber line. Yes, you can just get a new section of brake line at the local parts store for about $5. But you have to bend it yourself, which is not hard. I had to replace mine last winter when I tire chain broke and ripped it off. You will also have to bleed that brake line.
    speedtre, marbleville, lsaami and 2 others like this.
  2. Oct 12, 2019 at 4:24 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No we're replacing the circled part. Take the old part into the auto parts store so they can match the diameter. I believe it's 3/16". @Aerindel already nailed it. I just went through this last weekend because I though I ruined the metal line.
  3. Oct 12, 2019 at 4:39 PM
    truckee_mctruckface
    truckee_mctruckface New Member
    Charles
    Seattle
    2005 DC SR5 TRD off road Spectra Blue
    Thanks. Appreciate the quick responses. I’ll work on figuring out how to shape some brake lines.
  4. Oct 12, 2019 at 5:11 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    well, got the first snow of the season here. It didn't stick so I didn't get a chance for a pic.
    Also, I ordered parts to completely rebuild my rear brakes and parking brake mechanism.
  5. Oct 12, 2019 at 6:16 PM
    Aerindel
    Aerindel New Member
    Montana
    For the size of brakeline on our trucks you can get away with a pair of pliers if your careful. You just about have to as brake line bender tools usually won't do as small of radius as you need.
  6. Oct 12, 2019 at 10:18 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    why must all the aftermarket USB things that fit the center console blanks be charging oil USB ports. Damnit i want to use it for the radio! :annoyed:
    tacoguybill likes this.
  7. Oct 12, 2019 at 10:47 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Look for panel mount USB extensions. I used a round one in the cigarette lighter.
    https://www.amazon.com/3Feet-Extens...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
    But you can get rectangular
    https://www.amazon.com/SINCODA-Wate...=1570945505&sprefix=usb+extension+pan&sr=8-13
    tacoguybill, NUDRAT and speedtre like this.
  8. Oct 12, 2019 at 10:50 PM
    empty_lord
    05 rollover special
    i was trying to avoid the lighter ones, but it may be what i have to use. ive got a sequoia center console insert coming that has 4 switch blanks. was hoping to put it there. but oh well
  9. Oct 12, 2019 at 11:28 PM
    SoCalPaul
    Paul
  10. Oct 13, 2019 at 5:46 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  11. Oct 13, 2019 at 8:21 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    The world just wants you to use Bluetooth. I used one of these https://www.amazon.com/AUKEY-Bluetooth-Receiver-Wireless-Hands-Free/dp/B00O8FYUJA
    With one of these hardwired to a switched hot wire to keep it charged. https://www.amazon.com/HOMREE-Step-Down-Converter-Module-Adapter/dp/B07222YDG7
    Just a thought.
  12. Oct 13, 2019 at 9:48 AM
    empty_lord
    05 rollover special
    I’m the weird guy that uses a USB stick for music.
  13. Oct 13, 2019 at 10:38 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I was super confused what you were looking/asking for at first. I think it’s going to be a very tall order to find a music/data USB chingaso that fits in our stock switch blanks. I found toyota specific data ports(made for Camry and tacos, but maybe you can trim a hole out on your sequoia console to make it look nice)
    https://www.amazon.com/Adapter-86190-0R010-Toyota-Corolla-Auxiliary/dp/B07WBWWFQ8
    Good luck with your search
  14. Oct 13, 2019 at 10:56 AM
    empty_lord
    05 rollover special
    I’ll figure something out.
  15. Oct 13, 2019 at 12:41 PM
    Outbound
    Aaron
    Northern Alberta
    Filled my washer fluid resevoir with my winter fluid, the stuff that doesn't freeze until -45 Celsius. My summer stuff whch is good down to 0C has frozen every morning this last week.
    I also poked around my battery a bit. I need to replace it this fall before things get really cold, debating between Northstar and Odyssey AGM batteries. It'll probably come down to price and local availability since I think they're both pretty close in quality. I'm going to need to replace my connectors as well, and I want to get those ones that have multiple connection points. Gotta figure out where to find those in Canada.
    I then located where I believe my front tow hooks are supposed to be, 2 bolts on the frame on either side of my skid plate. I really have to track down some tow hooks as well, now that I'm starting to explore deeper into the backcountry by myself. I'm kind of debating whether or not I should install a receiver hitch up front and save up for a hitch mounted winch. Right now, all I have is a come-along winch, which will work in a pinch but isn't ideal. The reciever would be a relatively easy install. Two biggest concerns are: screwing up my approach angle/clearance and it looking stupid (i'm vain that way lol). The pure utility of it would probably negate both concerns.
    Last thing I did was dig out my last oil filter and added a Fumoto F103N valve to my shopping list. I'll also need to pick up a tap with the same thread pitch as the Fumoto valve. For my last oil change, I had ordered one but it would only screw in 2 threads before binding up. Either my oil pan's threads are buggered or the Fumoto was. Ended up returning the Fumoto. I'll test the new Fumoto valve I buy and if it still doesn't work, I'll chase the threads on the oil pan with the tap which should get it all working.
  16. Oct 13, 2019 at 12:55 PM
    deke1691
    deke1691 New Member
    NorCal
    2000 AC V8 2wd
    Welcome to the 200k club!
  17. Oct 13, 2019 at 1:29 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Keep an eye on the group buy section. They do NorthStar group buys. Maybe they will ship to Canada
    NUDRAT and Outbound[QUOTED] like this.
  18. Oct 13, 2019 at 3:28 PM
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    Does your Ultra Gauge read your transmission temp
    Also whT year & model Tundra
  19. Oct 13, 2019 at 5:08 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I like the one left of ash tray. Howed you do it?
    MyFj08 likes this.
  20. Oct 13, 2019 at 5:30 PM
    FrenchToasty
    Mo
    Bone stock
    Do you chaps have costos up there?
    I’m not one to “cheat” the system, ok, whatever maybe I am. Anyways, all the dudes at work sware by Costco’s warranty, no guff, no real testing of the “dead” battery
    I ended up getting the x2 which is rebranded nortstar I think, from batteries plus, 5 year warranty for the group 31(that bad boy is heavy!!!!)
  21. Oct 13, 2019 at 6:01 PM
    Outbound
    Aaron
    Northern Alberta
    Yeah, we have Costco. I don't think their batteries are AGM's though.
  22. Oct 13, 2019 at 6:23 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    Finally got around to installing my new rear axle gears and found this nice surprise when I pulled the cover.132BDC5E-4746-4C22-AB0C-88B8F70B6973.jpg
  23. Oct 13, 2019 at 6:37 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You do WHAT?
    bmf4069 and NUDRAT like this.
  24. Oct 13, 2019 at 7:05 PM
    SoCalPaul
    Paul
    I was able to access the cigarette lighter through the ash tray. I removed the lighter assembly and installed the USB extension. For mine, the top is Android Auto for my phone and the bottom is for my iPod Nano.
  25. Oct 13, 2019 at 7:10 PM
    SoCalPaul
    Paul
  26. Oct 13, 2019 at 7:58 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Thanks
  27. Oct 13, 2019 at 8:17 PM
    truckee_mctruckface
    Charles
    Seattle
    Got a replacement piece of brake line for the front driver side caliper and bent it into shape mostly by hand. Got everything hooked up and the new brake line seems to be holding tight with no leaks. I bled the brakes and everything looked good.
    While cleaning up I noticed a drop of fluid on the pavement under the caliper that was not there right after bleeding the brakes and all the other work. I had a leak somewhere. So I started with the brake line, but that still looked good. But then I found a large drop hanging off the bottom of the caliper right above the drip spot. No track of fluid leading to it, it seems to be coming out right near the bottom bolt on the caliper. I check the passenger side which I finished yesterday and the same thing, brake fluid leaking out the bottom of the caliper. Has anyone had this problem? I’m calling RockAuto in the morning. So far I am not impressed with these power stop calipers.
  28. Oct 13, 2019 at 8:20 PM
    KarmaKannon
    Utah
    Some junk
    Was the bolt tight? I double checked mine on my new calipers and put viz torque tamper paint on them just so I could visually inspect them.
  29. Oct 13, 2019 at 8:22 PM
    KarmaKannon
    Utah
    Some junk
    Did Campbells make that soup?
  30. Oct 13, 2019 at 8:45 PM
    truckee_mctruckface
    Charles
    Seattle
    I did crank on it to see if that was the problem but it didn’t get any tighter.
