  1. Sep 26, 2019 at 1:16 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    The HD version from General is supposed to provide 1 1/2 - 2 inches of lift. But there will not be improvements in the ride quality if you go this route, it would be much stiffer.
  2. Sep 26, 2019 at 1:24 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    I'll get measurements for you in a few when I get home.
  3. Sep 26, 2019 at 1:43 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    bmf4069 and Filthyphil like this.
  4. Sep 26, 2019 at 1:44 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    @FirstGenVol I am at 38 1/2 from ground to bottom of fender flare and 23 1/2 from center of hub to fender flare. 06 DC 4wd, no weight in the bed just a Backflip G2 folding tonneau (maybe 40 - 50 lbs).
    FirstGenVol likes this.
  5. Sep 26, 2019 at 2:15 PM
    toyotech2016
    toyotech2016 New Member
    2016 Tundra 1794 2004 Tundra TRD 2004 Sequoia Limited 1988 4Runner LT
    The most I have towed. My tundra alone is well over 6000lbs. 50/50 split and when towing my aluminum trailer and RZR. I couldn’t even tell it was back there and forgot a few times. 4.88 gears and 35s makes it a breeze to drive.
    I am running the prototype Archive Garage Overland Springs as I help brought them to life. They are also paired with AG shackle Flip Kit and extended shackles. Recently I added AG U Bolt Flip Kit with low profile bump stops.
    hammeron, speedtre, bmf4069 and 8 others like this.
  6. Sep 26, 2019 at 2:16 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    If you end up selling the icon add a leafs let me know. I'd like to do a full leaf pack eventually, but after building my front end I think my old lady is going to kill me if I spend too much more now. That and when I have a spare $1000 I'd rather it go to buying my kid a four-wheeler. Gotta hook them when they're young!
    NUDRAT and because_wumbo-truck like this.
  7. Sep 26, 2019 at 2:33 PM
    Casper421
    In the woods
    06 DC
    Stock vs AG:
  8. Sep 26, 2019 at 2:39 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    I'll likely be pulling the trigger around X-Mas (bonus time). I see you are in Utah, I could probably make you a deal on the whole leaf pack at that time.
    because_wumbo-truck likes this.
  9. Sep 26, 2019 at 2:43 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Looks like I’ll be looking into these leads when the time comes!
  10. Sep 26, 2019 at 3:13 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    It used to be in my early days that if one seriously upped the spring package for load, you would also up the axle shaft's size, in other words replace the axle with an axle that was larger in diameter to bear the increased load. Are you guys comfortable that the stock axle will bear the increase in load? Or are you only upgrading as a means to reduce general spring sag?
  11. Sep 26, 2019 at 3:17 PM
    toyotech2016
    1st gen tundra has been out for almost 20 years now. Within that time. There probably have been tons of people who have overloaded the rear axle/springs riding on bumps and yet I haven’t heard of anyone snapping an axle housing or axle. I personal know my dads 2000 work tundra has been overloaded more than I can count and it has over 440000 miles with original engine/trans. Axle. Drivetrain.
  12. Sep 26, 2019 at 4:11 PM
    marbleville
    Yep, last name too.
    State of Confusion
    That is most reassuring and, I guess, a testament to good metallurgy and engineering design. Around my neck of the woods and mountains, I seldom see Toyota pickups bearing overloads as they are typically being borne by full sized Ford, Dodge, Jeep and Chevy pickups, of which nearly everyone has one parked in their driveway. The Toyotas tend to be owned by a younger crowd and babied, until they hit the boonies where all former mild mannerisms are dropped in favor of rooting in the dirt, traversing the unfathomable, and ascending the impossible.:mudding:
  13. Sep 26, 2019 at 4:29 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Well my Coastal Off-Road kit came in and is now in the hands of my friend and local TW member/vendor Trail Toys
    They have an 05 tundra at the shop they can mock it up with. The timing couldn't have been better. In early or mid October that tundra is going under the knife hardcore. He's actually a member here as well.
  14. Sep 26, 2019 at 4:37 PM
    KarmaKannon
    Utah
    Some junk
    Sounds good. Let me know.
    MDobb79[QUOTED] likes this.
  15. Sep 26, 2019 at 5:17 PM
    empty_lord
    05 rollover special
    post pics when its done. even though im having OEM style bumpers painted eventually plate bumpers will be coming
  16. Sep 26, 2019 at 5:30 PM
    marbleville
    Yep, last name too.
    State of Confusion
    What with all you guys doing things to your burly rides, I have been messing with my cosmetic queen...
    I added a matched set of blue steelhead/salmon fly decals to add a slight more accent to her overwhelming gray imagery. Does it add or detract? Oh, and I got my security system back up and running. This coming weekend I plan on further cleaning up the wheels and painting the inside surfaces which are filthy and slightly corroded. Going with silver paint and hopefully bringing more light into the interior to light up my calipers and drums.
    [edit] Almost forgot, after spending hours at it...I attacked the face of my wheels with polishing compound and wire brushes attached to my drill...Amazon...
    https://www.amazon.com/ABN-Auto-Wir...69552664&sprefix=wire+brushes,aps,271&sr=8-24
    Acatlin96, Filthyphil and Darkness like this.
  17. Sep 26, 2019 at 5:39 PM
    trailbikerider
    trailbikerider New Member
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    2nd gen Tacoma leather steering wheel swapped in my truck. They are 100% bolt on for those curious.
    [​IMG]Untitled by Blake Nichols, on Flickr
  18. Sep 26, 2019 at 7:29 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's really the bummer about aftermarket leaf springs. If you want flex you generally lose payload. If you want payload you generally lose flex. The expedition pack might be expensive but it's the best of both worlds, if that came out before I got Alcans I would have got them.
  19. Sep 27, 2019 at 4:44 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    We have the same head unit.
  20. Sep 27, 2019 at 4:45 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    :thumbsup: for sure my dude
  21. Sep 27, 2019 at 6:26 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    I've heard of people having their stock rear leaf packs re-arched. Could be an economical option to freshen the pack up and gain a smidge of lift.
  22. Sep 27, 2019 at 10:50 AM
    empty_lord
    05 rollover special
    She’s lookin wonderful[​IMG][​IMG][​IMG]
  23. Sep 27, 2019 at 10:57 AM
    trailbikerider
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    Pioneer AVH-2330NEX?
    I've been super pleased with it. Before now I've always used Kenwood units.
  24. Sep 27, 2019 at 11:55 AM
    marbleville
    Yep, last name too.
    State of Confusion
    @empty_lord ...I hate being late to the party, even more so when I bear no gift, but did you have the frame checked for twist (assuming this is the rollover special)? I know of others, myself included, that have rebuilt a rollover only to find out later that the vehicle had a twisted frame. Mine showed as a truck that "wandered", making driving an almost constant effort to track straight (a condition completely lost on me due to the excitement of the acquisition and rebuilding process). I've since heard other tales of alignment issues that can not be corrected, one corner of the bed higher than the other by several inches (how do you miss that?), door and body panel "reveal" that is askew (the gaps between panels or door not running parallel, widening from one end to the other), and doors/windows that stick or catch when opening and/or closing.
    As it is, your rig is looking good with the body showing straight and the paint deep. Wishing you the best with your project...:amen:
    empty_lord likes this.
  25. Sep 27, 2019 at 12:11 PM
    empty_lord
    05 rollover special
    The frame had a slight curl at the end. It’s been pulled straight and true (I got lucky, we had a frame waiting for it’s new truck sitting at the dealer I used as a reference). She drives straight A’s can be and the alignment numbers are well within spec (but the lower left control arm is bent, that’s the next part I’ll be putting on). Body panel alignment is all good to. The bottom of the drivers door isn’t a perfect fit, but everything else is. Fixing the rocker to make the back bottom of the door perfect is extensive so I’ve decided to just live with that little minor issue
    Before putting any money into it I had it on the alignment rack. So I’m pretty sure she’ll be fine.
  26. Sep 27, 2019 at 12:30 PM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    Did my plugs and PCV valve today. Looks like it had Iridiums in it but I haven't a clue how many miles are on them(only picked this truck up a couple months ago).
    I put the "cheapies" back in.
    Glad I did the job though as one plug was not even fully hand tight and the coil tube was full of discoloration and carbon... I thought I had bad threads but got lucky as it just wasn't tightened correctly during previous job.
    georgiey22, bmf4069, NUDRAT and 2 others like this.
  27. Sep 27, 2019 at 12:50 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Ohh really? I will have to look into this as long as I can get it to match whatever color I have now. Fawn, sand, tan? No idea what my interior is
  28. Sep 27, 2019 at 1:18 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ordered SS brake line, front and rear. I like Wheeler's but their shipping prices are astronomical.
    lsaami and NUDRAT like this.
  29. Sep 27, 2019 at 3:44 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I don't know the.model name because I had an AVH4000NEX but I blew the amp so I made a deal on a comparable floor model Pioneer and it looks just like yours. My 4000 had more bottons and settings though
    I been really frustrated when i go to press the left tuning button on the screen and I accidentally hit something that re-tunes all my saved stations like wtf. I don't have the manual for either model since they were both basically used
    speedtre likes this.
  30. Sep 27, 2019 at 3:52 PM
    marbleville
    Yep, last name too.
    State of Confusion
    One thing I have found the web to be ideal for and that is getting your hands on digital copies of appliance manuals. I suspect if you were to google the model name and number you might very well find such a copy.
