  1. Sep 16, 2019 at 7:20 AM
    #9691
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    If you have JBL you should have JBL logos on both the head unit and the door panels
    EDIT: Apparently this only applies to Double Cabs. In 05+ Access Cabs, the amp is in the storage beneath the rear seat.
    TX-TRD1stGEN likes this.
  2. Sep 16, 2019 at 7:31 AM
    #9692
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Then I don't have JBL
    I currently have it all connected by the 70-8112 harness.
  3. Sep 16, 2019 at 7:35 AM
    #9693
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Take any and all of the blue wires coming from the 8112 harness and hook them up to the remote turn on lead from the Pioneer. I cant remember exactly which one turns on the amp but try them all.
  4. Sep 16, 2019 at 7:45 AM
    #9694
    because_wumbo-truck
    Jon
    Houston, Texas
    I also have the other harness in B. In fact.i had it wired in until yesterday when it didn't connect.to the harness in A.
    So you're saying I could either splice.into my A harness? or remove it and rewire in the B harness and it plugs into the amp?
  5. Sep 16, 2019 at 8:03 AM
    #9695
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Using the 8112 harness integrates the factory amp by plugging into the same vehicle side harness that plugged into your factory head unit.
    In order to use the 1761 harness and bypass this amp you need to unbolt the amp from its location. On the bottom of the amp you will find two plugs that match up to the 1761. These plugs are shown below:
    Shown in 1 pic
    Darkness and TX-TRD1stGEN like this.
  6. Sep 16, 2019 at 8:06 AM
    #9696
    because_wumbo-truck
    Jon
    Houston, Texas
    So I'm set up like A and have no sound. I can't seem to local an amp after removing the ac ac controls
  7. Sep 16, 2019 at 8:13 AM
    #9697
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    You cant follow the harness shown in the top pic and find the amp shown in the second? What the hell kind of freak truck do you have?
  8. Sep 16, 2019 at 8:44 AM
    #9698
    because_wumbo-truck
    Jon
    Houston, Texas
    :notsure: I followed it as far as i could (not far).
  9. Sep 16, 2019 at 8:51 AM
    #9699
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Dead serious that Ive never seen this. Is it possible that the JBL logo rubbed off or was knocked off of the door panels? Makes me wonder if the AC's were an entirely different animal.
    @SoCalPaul, you've got an uber Limited right? Does your interior show JBL logos anywhere?
    @because_wumbo-truck Do you have an amp beneath the rear seat?
  10. Sep 16, 2019 at 9:23 AM
    #9700
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    From some old post on Tundra Solutions:
    because_wumbo-truck likes this.
  11. Sep 16, 2019 at 9:47 AM
    #9701
    because_wumbo-truck
    Jon
    Houston, Texas
    I can check
  12. Sep 16, 2019 at 9:50 AM
    #9702
    because_wumbo-truck
    Jon
    Houston, Texas
    So that exactly the boat I'm in except his speakers work lol
  13. Sep 16, 2019 at 10:01 AM
    #9703
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    According to Crutchfield your amp is under the right rear seat and you need Metra 70-8121 to bypass it.
  14. Sep 16, 2019 at 10:07 AM
    #9704
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Whoever solves this should get a steak dinner from Jon.
  15. Sep 16, 2019 at 10:33 AM
    #9705
    because_wumbo-truck
    Jon
    Houston, Texas
    It might just get taken to a pro. I'm like 90% over it.
  16. Sep 16, 2019 at 10:35 AM
    #9706
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This is why I always recommend Crutchfield. If you get stuck in situations like this they will talk you through it. I will gladly pay a few bucks more over Amazon to get tech support.
  17. Sep 16, 2019 at 10:44 AM
    #9707
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I got lucky as the previous owner had already installed a single Din radio. It made my install pretty straight forward. I think I just had to use the standard Toyota aftermarket radio connectors.
  18. Sep 16, 2019 at 10:49 AM
    #9708
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I have a non JBL AC and my amp is right behind the HVAC stuff. It's in a pita spot.
  19. Sep 16, 2019 at 10:53 AM
    #9709
    because_wumbo-truck
    Jon
    Houston, Texas
  20. Sep 16, 2019 at 10:55 AM
    #9710
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah im about to call them
  21. Sep 16, 2019 at 11:02 AM
    #9711
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Whats behind door number 2 there?
  22. Sep 16, 2019 at 11:09 AM
    #9712
    Festerw
    Festerw New Member
    04 Tundra DC
  23. Sep 16, 2019 at 11:16 AM
    #9713
    because_wumbo-truck
    Jon
    Houston, Texas
    Let's find out...
    I think we've found it.
    Now how the fuck to run wires to it from the dash?
  24. Sep 16, 2019 at 11:20 AM
    #9714
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    See post # 12 in that other thread. Although even here, this looks like a different style plug. There has to be some freaking way to turn that "Non JBL" amp on and integrate it without doing a bypass.
  25. Sep 16, 2019 at 11:23 AM
    #9715
    because_wumbo-truck
    Jon
    Houston, Texas
  26. Sep 16, 2019 at 11:30 AM
    #9716
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I can probably decode the colors if you wanna run some 9 conductor back there. Can you cut back a little of the harness wrap on both sides and take a clear picture showing all of the wire colors in both harnesses? It is ok to unplug the amp for a little more room.
  27. Sep 16, 2019 at 11:34 AM
    #9717
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You guys should facetime at this point honestly. It may be easier than going back and forth on here. :cheers:
  28. Sep 16, 2019 at 11:34 AM
    #9718
    Festerw
    Festerw New Member
    04 Tundra DC
    So it looks like the Metra 70-8121 is what you need. Running the wires though the center console or along the passenger still plates is probably the easiest.
  29. Sep 16, 2019 at 11:56 AM
    #9719
    because_wumbo-truck
    Jon
    Houston, Texas
    So Crutchfield rep said I needed the amp bypass for $25 so I ordered it. Will be here Wednesday. Too bad the first guy I ordered from didn't catch it when he recommended all the other crap. The second guy didn't catch it when I called for help. Car Toys didn't catch it when I say I needed a different harness.
    This third guy hopefully is legit.
  30. Sep 16, 2019 at 12:01 PM
    #9720
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    In other news, I was about to share that I ordered new head and fog LED's when I realized that I ordered 2 sets of headlights...:facepalm:
    I meant to order Lightning Dark LED's and a different brand for Fogs. I may test both and see which I like better. Either way, I now have to order the fog lights.
