  1. Sep 12, 2019 at 7:28 AM
    #9571
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Check the junkyards. shouldn't be so scary used.
    Some rope, a gasket, some goop & 3 bits of glass.
    Junkyard might even give you trade in value on your solid pane.
  2. Sep 12, 2019 at 7:35 AM
    #9572
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    It's totally the two doors catch each other up top - forces you to open front door wide to get back door open & you need room to step around it all. PIA in tight spaces, then do the dance again to close it all up. If the top gasket attached to the truck instead of the door.
    But size wise the truck is awesome (with bed extender on occasion).
    speedtre[QUOTED] likes this.
  3. Sep 12, 2019 at 8:05 AM
    #9573
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve got a brand new one from my buddy at the glass shop. 250 bucks. Sliding rear window. Quality looks good. They’re simple enough
    To replace if I ever decide to go power
    In other news my rear harness came in. So when the beds off illl be replacing it so I can have the 7 pin working
  4. Sep 12, 2019 at 9:45 AM
    #9574
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    For those that have installed a backup camera, or a screen with that capability,
    What/where do I tie the reverse signal input into?
  5. Sep 12, 2019 at 10:03 AM
    #9575
    Casper421
    In the woods
    06 DC
    Reverse light.
  6. Sep 12, 2019 at 10:10 AM
    #9576
    because_wumbo-truck
    Jon
    Houston, Texas
    See that's what I was thinking, but that a long way to run a wire from the dash. If the signal wire came off the camera like I expected it to, that's exactly how i'd prefer to wire it.
    So i called Crutchfield and I can tap into the reverse wire on a harness behind the driver kick pannel. It will either be green w/ red stripe or red w/ black stripe.
    Sangre Kid likes this.
  7. Sep 12, 2019 at 10:21 AM
    #9577
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I see it listed as red/black, drive kick panel, gray 8 pin plug, pin 2.
    You get that bypass?
  8. Sep 12, 2019 at 10:25 AM
    #9578
    empty_lord
    05 rollover special
    You could just wire t to the reverse wire that lights up the dash. Should be pretty close to the radio
  9. Sep 12, 2019 at 10:30 AM
    #9579
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Are you talking about the bulb that lights up inside the gauge cluster? I think that would be a huge pain compared to simply going to the kick panel. Plus it could be extremely low current. I doubt the reverse input needs much current but I would still recommend the kick.
    Definitely try to keep it inside the cab if possible. You risk corrosion by going anywhere outside. Yes, I know there are ways to prevent it but when I did mine I went to the kick and was done in half the time it took me to type this.
  10. Sep 12, 2019 at 10:37 AM
    #9580
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You looking for reverse power for the camera or for the head unit?
    For the camera it's pretty easy to tap the trailer wiring harness. For the head unit I have no idea since the screen I have gets the signal from the camera to activate.
  11. Sep 12, 2019 at 10:45 AM
    #9581
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Most all cameras that I have done only have two wires, power and ground, and an RCA output that plugs into the head unit. The head unit typically has a wire that needs reverse input signal to tell the head unit to switch sources to view the camera.
    I would always wire the camera power to the radio accessory circuit and use the vehicle reverse wire for the head unit input.
    This way the camera is always on anytime that the headunit is on and you can always view the camera by selecting the source if need be. Some cameras had a super slow startup time as well. So powering them off of the reverse light would have an annoying delay before the camera turned on.
    This method will draw the current from the vehicle accessory wire, which should be rated at 10A and can handle the draw. It also only uses the reverse circuit for a trigger which puts very little additional load on this circuit that Toyota probably didnt design for additional load.
    speedtre and because_wumbo-truck like this.
  12. Sep 12, 2019 at 10:57 AM
    #9582
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    My recollection is that there is a connector you can tie into behind the radio. I found a youtube video of a guy with a Sequoia that found it. I don't have the link handy.
  13. Sep 12, 2019 at 11:02 AM
    #9583
    because_wumbo-truck
    Jon
    Houston, Texas
    I guess it's time ...
    Outbound, LASurf, tacoguybill and 4 others like this.
  14. Sep 12, 2019 at 11:11 AM
    #9584
    because_wumbo-truck
    Jon
    Houston, Texas
    That's how I'm going to wire it then
  15. Sep 12, 2019 at 11:11 AM
    #9585
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Thank god Jon. I was about to mail you a restoration kit. Your truck is about to look a lot nicer.
  16. Sep 12, 2019 at 11:12 AM
    #9586
    because_wumbo-truck
    Jon
    Houston, Texas
    Yes I did. Thank you. I forgot to let you know when I received it.
  17. Sep 12, 2019 at 11:13 AM
    #9587
    because_wumbo-truck
    Jon
    Houston, Texas
    :laugh: plz don't, I have like 3 different ones somewhere around here lol
    Now I just gotta figure out how to get these signals removed so I can get to the last screw on the headlight
  18. Sep 12, 2019 at 11:18 AM
    #9588
    SoCalPaul
    Paul
    Try this. I just tinned the reverse wire from the head unit & stuck it in the connector and taped it up.
    https://www.youtube.com/watch?v=cm1kA4OEQYQ
  19. Sep 12, 2019 at 11:18 AM
    #9589
    because_wumbo-truck
    Jon
    Houston, Texas
    For the head unit. I bought a pioneer camera for my pioneer screen thinking it would be plug n play. I'm not thrilled with it so far. I got waaaay too many wires I gotta fit into the dash now. It would've been so much easier to tap into the reverse.light for signal and the head unit itself for power
  20. Sep 12, 2019 at 11:21 AM
    #9590
    because_wumbo-truck
    Jon
    Houston, Texas
    Awesome. It's going down Sunday. Thanx
    SoCalPaul[QUOTED] and bmf4069 like this.
  21. Sep 12, 2019 at 11:28 AM
    #9591
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Meh, trust me, you could fit a small cow (or a really large cat) back there. I have everything that you do plus two small amps, and they all tuck away nicely if you keep the wiring organized.
    Try doing this on any kind of VW product and you'll be super grateful for the real estate these trucks have.
  22. Sep 12, 2019 at 11:43 AM
    #9592
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    https://www.tundras.com/threads/200...-adventure-build-barnabas.48300/#post-1255147
    check post #4. has pictures and appears he did what you are going for.
    Hope this helps!
  23. Sep 12, 2019 at 12:00 PM
    #9593
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Does anyone think it's worth it to try and sell my factory front skid plate? I can't seem to find the part for sale online to know what it would cost new. Is it worth $75-50? It's in good shape overall.
  24. Sep 12, 2019 at 12:02 PM
    #9594
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    That ignition illumination looks great! I'll have to try that.
    because_wumbo-truck likes this.
  25. Sep 12, 2019 at 12:04 PM
    #9595
    KarmaKannon
    Utah
    Some junk
    I use my feet to lift the tires back up. If the truck is low enough to the ground it makes it much easier. I don't like hugging tires and wheels to lift them.
  26. Sep 12, 2019 at 12:35 PM
    #9596
    empty_lord
    05 rollover special
    The signal wire should run in the look
    Near the radio. T-tap should make it work. But there are other options
  27. Sep 12, 2019 at 12:55 PM
    #9597
    because_wumbo-truck
    Jon
    Houston, Texas
    Cool. I just recall it being cramped back there on my first gen tacos
  28. Sep 12, 2019 at 12:56 PM
    #9598
    because_wumbo-truck
    Jon
    Houston, Texas
    00TundraZ[QUOTED] likes this.
  29. Sep 12, 2019 at 12:59 PM
    #9599
    because_wumbo-truck
    Jon
    Houston, Texas
    All clear now.
    She needs a bath bad. Too many bugs and dust on my commute lol
  30. Sep 12, 2019 at 5:29 PM
    #9600
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Starting early, I removed the rear drums and using a 1/2" drill with wire wheel and some WD40 rust remover cleaned up the rust, washed with Brakleen and dried them. I then washed them with Adams Heavy Duty All Purpose Cleaner and degreaser, rinsed and dried again. Hit them with three coats of primer, three of blue base, and three clear coats. Between coats, I sprayed the brake parts with a heavy stream of Brakleen and cleaning up the brake dust. Mounted the wheels with my shovel technique and retired, pooped. Got this project done just in time as the weather is moving quickly into fall with much cooler temps and rain beginning tonight.
    The blue paint adds a very subtle bit of blue color to the truck and its solid grayish color - not garish or overdone in my opinion. Kind of goes with my blue interior lighting, though when the lighting shows best - at night - the blue of the calipers and drums is hard to see as other than dark.
    Can't wait until spring when the sun will shine once again and I get to see them in strong sunlight.:turtleride:
    hammeron, speedtre, SC T100 and 3 others like this.
