  1. Aug 11, 2019 at 7:25 PM
    #9001
    NMTundra
    NMTundra New Member
    Yeah it is nice and allows me to mostly scratch my 3rd Gen itch without having to lay out the cash for one. Depending on how the next couple of months go, I may sell my truck even and just have the work truck and the wife's 4Runner.
    Filthyphil[QUOTED] likes this.
  2. Aug 11, 2019 at 8:33 PM
    #9002
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    In all honestly I would probably do the same if I could drive mine for personal use.
  3. Aug 12, 2019 at 1:29 AM
    #9003
    tvpierce
    tvpierce Formerly New Member
    Maine
    Can '05 - '06 ball joints be used on a '00 - '04?
    because_wumbo-truck likes this.
  4. Aug 12, 2019 at 6:26 AM
    #9004
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    No, the 05-06 use 17mm bolts to hold the ball joint to the spindle compared to 14mm on 00-04. Also possibly a larger ball joint size as well. You’d have to get new 05-06 spindles to use them at the very least.
  5. Aug 12, 2019 at 9:33 AM
    #9005
    mscribellito
    mscribellito New Member
    Michael
    2006 White Regular Cab Tundra
    Since I got the truck, it had a super annoying vibration/humming sound coming from the passenger dash area. Only does it when the truck is in D or R. Turned out to be the cold air intake tube rattling in the inner fender. I put some insulating material around the opening and... silence :)!
    NUDRAT, Darkness and Filthyphil like this.
  6. Aug 12, 2019 at 10:45 AM
    #9006
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You’d need new control arms, spindles and ball joints. The uppers are thensame
  7. Aug 12, 2019 at 4:35 PM
    #9007
    JessiJane06Tundra
    JessiJane06Tundra New Member
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    If it makes you feel better that's how it broke off about 2 months ago
  8. Aug 12, 2019 at 6:42 PM
    #9008
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    What would you do? It's gonna take a month if I go with the upgraded version
  9. Aug 12, 2019 at 8:04 PM
    #9009
    turboser91
    turboser91 New Member
    Fresno
    06 DC 4x4
    6" RCD lift
    Have you checked to see if the upper and lower control arm bushings are bad? If they are still good and if it was my truck, I'd replace the upper and lower ball joint, outer tie rod and call it a day.
    JessiJane06Tundra likes this.
  10. Aug 12, 2019 at 8:35 PM
    #9010
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    just ordered a new bushing to fix my sloppy column shifter.....will install tomorrow. And now as I look out the window at the tundy, I ponder whether I should bedliner the fender flares and front bumper. I wanna stay white and keep going back to the durabak. Any suggestions? Line-X wants $400 for black or $700 to 'color match ish' white.
  11. Aug 12, 2019 at 10:10 PM
    #9011
    empty_lord
    05 rollover special
    you can order the bushing? the one that goes on the end of the cable?
  12. Aug 12, 2019 at 10:13 PM
    #9012
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Yeah, I think its like bushingfix.com or something. I need to do it but last time I looked I thought it was a little pricey for a piece of plastic no bigger than a fingernail.
  13. Aug 12, 2019 at 10:16 PM
    #9013
    empty_lord
    05 rollover special
    i stole mine out of a wreaked sequoia lol
    Darkness and because_wumbo-truck like this.
  14. Aug 12, 2019 at 11:22 PM
    #9014
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yep, its a spendy little $30 piece of plastic, but I'd rather not be stuck somewhere with my truck not able to shift into or out of gear. I bought it from bushingfix.com off Amazon so the shipping was free as well as fast.
  15. Aug 12, 2019 at 11:26 PM
    #9015
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Link?
  16. Aug 12, 2019 at 11:51 PM
    #9016
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  17. Aug 13, 2019 at 5:06 AM
    #9017
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  18. Aug 13, 2019 at 7:08 AM
    #9018
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Got the new peepers in. Gotta say, initially, I'm pretty impressed with these TYC lenses. Very close to OEM quality.
    Ignore the neighbors s/c X-Runner.
  19. Aug 13, 2019 at 7:45 AM
    #9019
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    How much you pay for those?
  20. Aug 13, 2019 at 7:56 AM
    #9020
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I got the CAPA certified ones for right at $100 ea. The NSF certified are around $90 ea but remember these are specific to a DC. AC lenses I have no clue about.
  21. Aug 13, 2019 at 9:05 PM
    #9021
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Figured I would spend this evening getting these headlights adjusted. I knew that I needed a Phillips screwdriver longer than any that I had to get to the vertical adjust screw so I stopped by Harbor Freight on the way home. It appears that Harbor Freight makes two lengths of screwdrivers.
    Standard Length - This is the size that everyone who has ever held a screw driver should be familiar with. Though it may vary by manufacturer, each length is reasonable.
    Comically Long - This screwdriver could double as a police baton. Wife nagging about a loose deadbolt? Never fear! You don't even have to get off the couch to cinch that baby up. I feel like the guy that made these was reading reviews on the last set of drivers that he designed and *maybe* someone complained about them being too short. Out of spite he says, "You want a long screwdriver, well I'll show you a long screwdriver."
    I purposely made this picture vertical. Scroll slowly for more comedic effect.
    On the other hand, they were only $5 and now the wife and I each have a new backscratcher if we ever need it.
    Darkness, bmf4069 and NUDRAT like this.
  22. Aug 14, 2019 at 3:26 AM
    #9022
    tvpierce
    Maine
    It's not a Phillips head. o_O
  23. Aug 14, 2019 at 3:32 AM
    #9023
    because_wumbo-truck
    Jon
    Houston, Texas
  24. Aug 14, 2019 at 9:32 AM
    #9024
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Yeah, I left the Phillips in the truck when I decided to take the picture and didn't feel like wandering out to get it. Graciously for $5 you get both!
    Darkness and NUDRAT like this.
  25. Aug 14, 2019 at 4:26 PM
    #9025
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ordered one of these. Excited to free up some space in the already cramped back seat.
  26. Aug 14, 2019 at 4:30 PM
    #9026
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    I can't make out the manufacturer, who makes these?
  27. Aug 14, 2019 at 4:46 PM
    #9027
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Casper421 likes this.
  28. Aug 14, 2019 at 4:58 PM
    #9028
    Casper421
    In the woods
    06 DC
    I can’t take the credit, another member was the guinea pig, I just took advantage and added a second.
    Looks like you went with the passenger side? Good choice.
    FirstGenVol[QUOTED] likes this.
  29. Aug 14, 2019 at 5:16 PM
    #9029
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
  30. Aug 14, 2019 at 5:17 PM
    #9030
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    What do you think of this? Is it sturdy?
