  1. Jul 26, 2019 at 12:35 PM
    #8671
    Archive
    Archive New Member Vendor
    Eric
    '22 Tundra CM 6.5' TRDOR
    Archive Garage Suspension
    Was replaced in 2012, needed cleaning up and I sprayed some Noxudol 900 tar on some areas
  2. Jul 26, 2019 at 12:46 PM
    #8672
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    That looks freaking sweet. Should you flip the hose clamps on the remotes though so you dont have to pull the bed if you need to remove them?
  3. Jul 26, 2019 at 1:04 PM
    #8673
    Archive
    Eric
    Thanks, Good call! The reservoirs can be mounted outside the frame rails as well, bed is going back on so I can work this horse
  4. Jul 26, 2019 at 2:19 PM
    #8674
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    Got my new bumper on and fits/looks good, only hiccup was my dumbass twisting one of the braces into a pretzel, didn’t realize it was spinning til it was to late and I spun it good. Then figured I’d re-plasti dip my emblems and paint the plastic pads while I was at it, paint can sputtered, used a can of break cleaner to fix it then decided to use rattle can bed liner. It’s got a couple runs but it’s a truck, screw it. Looks good from 10 feet out.
    5A822C2E-52F4-41E3-B106-94C8585F3AF1.jpg 3014223F-BAC4-4BA8-94CB-9D793510EEB0.jpg
  5. Jul 26, 2019 at 3:11 PM
    #8675
    Professional Hand Model
    Hand Protectors
    Non-stop 5 hours of clay bar, polish, and wax today. She looks good.
    Crawled under the chassis and loaded up PB Blaster in those ‘grease traps’ I concocted last year around the cross member to frame connections. Also, spayed some other frame areas including the transmission bolts in prep for pan drop and new screen install.
    Good news: The Mobil1 5-30 Synthetic ‘High Mileage’ Formula seems to have cured my slight weep at the engine oil pan gasket. Just a reminder that the weep started last fall after a conversion from syn-blend from garage service for years to me taking over maintenance and going full syn. I used the Extended mileage Mobil 1 Synthetic for the first time and thats when the slight weep started. Moved on to regular Mobil1 full syn and the weep slowed.
    The Mobil1 High Mileage Synthetic Formula looks to have done as it purports in just over 1k miles since the last oil change. Key word is ‘gasket modifiers’.
    In celebration, I broke out the good stuff to dress the black truck trim. Its a bottle from 1996 As Seen on TV.
    Formula 2001 space age!
    NUDRAT, Archive and TX-TRD1stGEN like this.
  6. Jul 26, 2019 at 3:19 PM
    #8676
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Did you ever end up getting the Bakflip?
  7. Jul 26, 2019 at 3:19 PM
    #8677
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Soo. Who has any ideas how to open a driver side door that won’t open from
    The inside or outside handle
  8. Jul 26, 2019 at 3:24 PM
    #8678
    Outbound
    Aaron
    Northern Alberta
  9. Jul 26, 2019 at 3:25 PM
    #8679
    Outbound
    Aaron
    Northern Alberta
    Pictures of truck!!
    :worthless:
  10. Jul 26, 2019 at 3:31 PM
    #8680
    Hand Protectors
  11. Jul 26, 2019 at 3:36 PM
    #8681
    Hand Protectors
    Ok. I’ll take her on a modeling shoot later during sunset. She still is lacking the side boxes which will be going on tomorrow as I need to fab up some new custom brackets due to me breaking one during removal.
    Outbound[QUOTED] likes this.
  12. Jul 26, 2019 at 3:39 PM
    #8682
    empty_lord
    05 rollover special
    Soo. Who has a
    I’ll have to try that later. Funny I was using the truck all this week, get home, go back out to go get something and the doors stuck, fuck
  13. Jul 26, 2019 at 3:41 PM
    #8683
    Hand Protectors
    My idea might not be doable as the door panel needs removal and that might be improbable with the seats being in the way.
  14. Jul 26, 2019 at 3:59 PM
    #8684
    empty_lord
    05 rollover special
    Yea, door panel is an issue. There’s one screw I can’t get off due to the dash blocking it. Linkages all appear to be on from what I can see. I think the lock has broke internally... may be a bitch and a half
  15. Jul 26, 2019 at 3:59 PM
    #8685
    empty_lord
    05 rollover special
    Since the fenders off I guess I’ll just take the damn hinges off and see if I can get the lock to come off... or if I can get into the thing and cut the striker. Hmm tricky
  16. Jul 26, 2019 at 4:30 PM
    #8686
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Time to pull the dash off again.
  17. Jul 26, 2019 at 4:33 PM
    #8687
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think I need that in my life. I'm sure of it. I think I have a set of 12" foxes too...
    Archive[QUOTED] and TX-TRD1stGEN like this.
  18. Jul 26, 2019 at 4:39 PM
    #8688
    Mike Tread lightly.
    south carolina
    That's cool.. going to have to check into that
    Archive[QUOTED] likes this.
  19. Jul 26, 2019 at 5:45 PM
    #8689
    Hand Protectors
  20. Jul 26, 2019 at 5:53 PM
    #8690
    empty_lord
    05 rollover special
    yea i'll cut the door off before i do that.. the doors bent anyway.
  21. Jul 26, 2019 at 5:54 PM
    #8691
    empty_lord
    05 rollover special
    that appears to be a bolt on crossmember. you make it yourself?
  22. Jul 26, 2019 at 6:00 PM
    #8692
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Professional Hand Model truck looks a lot better without those tool boxes. What all do you keep in them? (Besides tools)
    TX-TRD1stGEN likes this.
  23. Jul 26, 2019 at 6:12 PM
    #8693
    Hand Protectors
    Not much actually. I used to carry my checkbook in the driver side box until I went 4 years without writing a check.
    Had my tire repair plugs in the the pass side, but moved them under the pass side back underseat storage well which was still hermetically sealed from 2002.
    Thanks, but I believe the boxes are going back on tomorrow. I’ll give Mz Hand the final say so before reinstall.
  24. Jul 26, 2019 at 7:18 PM
    #8694
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I know Prius (& several other Toyotii) electric locks go bad & the fix is to replace a little RC motor in the door. Sometimes folks reinstall a bit reversed (don't recall which bit) which results in latched door that won't unlock/open from in or from out. So sorta your situation. It's been about a year, so I'm vague on specifics - but it's on YouTube. Try searching Toyota door lock repair, I'm certain there was someone who found a way with the door closed & door card mounted.
  25. Jul 26, 2019 at 7:18 PM
    #8695
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Measured my leaf springs to see if they're compatible with the Archive Garage u bolt flip kit, 58mm so they might work. Looked under my truck and visualized what I would have to do if I go for that rear shock set up, looks like muffler and tailpipe need a rotation or just move the muffler forward and turn the pipe out the side by the door. Going to look for the Fox shocks I have in storage, I believe they are 12" but can't recall. They are 2" with reservoirs and I've had them for ages just sitting. @Archive you may have a sale by month end with no rush on delivery.
    Hit the interior with the shop vac. Sprayed the floor mats down with the hose. I'd really like to get nicer mats up front with more coverage, considering Husky since I have a $40 Amazon card, that just about cuts the out of pocket cost in half. I've been rocking a pair of $9 wally world specials since 2009.
  26. Jul 26, 2019 at 7:30 PM
    #8696
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Or an old T4R
    speedtre[QUOTED] likes this.
  27. Jul 26, 2019 at 7:36 PM
    #8697
    because_wumbo-truck
    Jon
    Houston, Texas
    I hope you have a new axle ready
  28. Jul 26, 2019 at 7:38 PM
    #8698
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Here is one link to the locks. Maybe a tip in some of the follow ups.
    https://priuschat.com/threads/fixed-door-lock-actuator-in-gen-ii-prius.113850/
  29. Jul 26, 2019 at 7:41 PM
    #8699
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah, I feel for him on that one. I was thinking he likely can't do a drain and fill on that rear diff. Can't imagine those plugs will open. Rust sucks.
  30. Jul 26, 2019 at 7:55 PM
    #8700
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I thought the same when my pumpkin started to weep. I used an impact wrench & the plugs came right out with no issues. mine was a lot worse than this one before I addressed it. So far so good!
