  1. Jun 22, 2019 at 2:52 PM
    #7891
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Those are KMC Enduro wheels. Not sure what size Darkness has. Mine are 16x8 and they fit fine.
    Disregard the TRD center cap, it doesn't fit
    Darkness, fs007[QUOTED] and ncoldwell like this.
  2. Jun 22, 2019 at 2:59 PM
    #7892
    Professional Hand Model
    Hand Protectors
    I bet this was fun and once considered doing this but nothings broken so it will be left alone. Stoked your overdrive is back up!
    What did you use to clean everything?
    Did you drop the ‘screen’ filter and clean it?
    Did you snug any of the bolts on the valve body while it was open?
    You see much gunk/debris?
  3. Jun 22, 2019 at 3:01 PM
    #7893
    Hand Protectors
    Believe his are the same size. Tires are 285/75r16. And he doesn’t believe in spacers to the best of my knowledge.
    Darkness likes this.
  4. Jun 22, 2019 at 3:05 PM
    #7894
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    I used brake cleaner on everything. I pulled the screen and all the solenoids off to clean them separately. I didn’t snug any bolts because everything seemed good and tight that I removed. It was really pretty clean inside here’s the inside of the pan before I cleaned it .690F9708-732B-4AD9-A362-E7F2AE94D400.jpg
  5. Jun 22, 2019 at 3:20 PM
    #7895
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    It's already a 2.5"/1.5" lift. Wasnt panning to go higher
    because_wumbo-truck likes this.
  6. Jun 22, 2019 at 3:51 PM
    #7896
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    3" body lift would do trick. Plus it gives you some space to work under and around the truck.
  7. Jun 22, 2019 at 4:02 PM
    #7897
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    I don’t think I could handle not having overdrive. I need to get on some maintenance since I didn’t get any records with my truck.
    Always loved these wheels. Good choice.
  8. Jun 22, 2019 at 6:03 PM
    #7898
    because_wumbo-truck
    Jon
    Houston, Texas
    I'd go the minimal BL. Maybe 1-1.5 inch if I can find one
  9. Jun 22, 2019 at 6:04 PM
    #7899
    because_wumbo-truck
    Jon
    Houston, Texas
    Thanx. A local TW members was offering em up cheep after he got scs 17s. Same route I'll eventually take. Or Level 8 or FN. I just want to be able to use my TRD center caps
  10. Jun 22, 2019 at 6:09 PM
    #7900
    Hand Protectors
    Fuze’em in!
  11. Jun 22, 2019 at 6:24 PM
    #7901
    because_wumbo-truck
    Jon
    Houston, Texas
    How do you mean? I'm mostly concerned about the fronts, because the black plastic dust cap sticks out a little too far for em to sit flush. Then there's the fact the bore of my wheels is 2mm larger than the diameter of the TRD center caps.
  12. Jun 22, 2019 at 6:25 PM
    #7902
    because_wumbo-truck
    Jon
    Houston, Texas
    I think his are actually 17x8.5 which is what I kinda wish I had.
    If not his, then the guy with the same wheels as us but chrome, might be who's I'm thinking of.
  13. Jun 22, 2019 at 6:38 PM
    #7903
    Hand Protectors
    Put a couple dabs of Fuze caulk by Liquid Nails on the inside rim to hold the caps in place.
  14. Jun 22, 2019 at 7:03 PM
    #7904
    dd04tundra
    dd04tundra New Member
    david
    04 tundra 4.7
    None ......YET
    Went to the wash today with my youngest daughter, she did a really good job of helping me clean out my 18 yr sons mess from my truck.
    NUDRAT likes this.
  15. Jun 23, 2019 at 8:00 AM
    #7905
    imDementeD
    Removed mud flaps and front bumper. I think a sludge hammer will give me adequate spacing for this tire size to work but if not, a good friend of mine is a great fabricator that can cut/weld me up. I may go that route but will talk to him first as I know suspension will flex so I need to take that into consideration.
    Driver side:
    Passenger Side:
  16. Jun 23, 2019 at 9:43 AM
    #7906
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Looks like you are in for some cutting. It's not as bad as everyone says. I cut and tacked mine back together and then did construction adhesive in a couple hours. It was stinky tacking around the factory seam sealer but it wasn't terrible. The cutting is never my favorite part because I hate getting metal dust in my hair and face, but oh well.
    Just make sure you seal it up really well haha. I used construction adhesive and it seems to have worked just fine. Mine still rubs every once in a while though. No matter, distance from the frame will surely help with that.
    What did I do to my Tundra today? Just sold some stuff and in the next day or so I'm ordering my extended front axle shafts. I also just ordered heims and uniballs for one side of the front suspension. I'll order the other side in a week or so, but I can still play around with suspension geometry on one side. Oh and I got my upper uniball adapters and ordered round stock to replace my lower ball joint with a uniball. Excited for new suspension! Build thread to come as soon as I have something to show haha.
  17. Jun 23, 2019 at 11:42 AM
    #7907
    fs007
    fs007 New Member
    04 tundra
    thank you! what's the offset on those? love the center cap :)
  18. Jun 23, 2019 at 2:04 PM
    #7908
    because_wumbo-truck
    Jon
    Houston, Texas
    Too bad the center cap is 106mm and the wheel hub bore is 108mm. Plus the plastic dust cap on the front hubs won't let the center caps sit flush.
    fs007[QUOTED] likes this.
  19. Jun 23, 2019 at 2:06 PM
    #7909
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Busy day. Sold my old wheels and tires on Facebook in less than an hour.
    Finally dipped my rear bumper.
    Did a transmission drain and fill on my wife's car.
    In between coats I checked each ignition coil.
    6 looked great but 2 are burnt. Not sure the #s. Both are 3rd from the front on each side.
    I wish I knew if these have ever been replaced.
    The rest all looked like this.
    bajaphile likes this.
  20. Jun 23, 2019 at 2:07 PM
    #7910
    Hand Protectors
    Trim some off the backside for a flush fit. Jerry did his this way. Make it happen!!!
  21. Jun 23, 2019 at 4:55 PM
    #7911
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    Got some 285s on stock wheels (will need wheel spacers to avoid rubbing on a arms). Then I did the steering shaft seal. No more fake exhaust leak noise!
  22. Jun 23, 2019 at 5:06 PM
    #7912
    Hand Protectors
    You may consider a high dollar alignment to correct your rubbing coupled with grinding a slight amount off the arm nub to give you another 1/4” of space between tire and arm protuberance (an Office joke).
    Acatlin96 and bajaphile[QUOTED] like this.
  23. Jun 23, 2019 at 5:07 PM
    #7913
    Hand Protectors
    What exactly did you do to this steering shaft seal?
  24. Jun 23, 2019 at 5:39 PM
    #7914
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ditto. I'm curious about this as well.
  25. Jun 23, 2019 at 5:56 PM
    #7915
    bajaphile
    Solana Beach, Ca
    2001 4x4 Limited
    @FirstGenVol @Professional Hand Model
    Woops... I forgot to take a pic of the actual seal/boot. The one that acts as the seal @ the firewall for the steering shaft. (not pictured in my post). You can see the remnants of the old one on the steering coupler.
    If grinding A-arm, would I need to weld in a plate? I might try that. It's not really that bad. I'm worried now a 1.25" spacer will move the rubbing to the fenders....
  26. Jun 23, 2019 at 6:12 PM
    #7916
    Hand Protectors
    Post a part # of your seal.
    The arm grinding: I only mentioned because someone grinded mine in the past or maybe even with my recent suspension work done at a shop. I didn’t notice until recently that one side had some grind marks (done by grinder for sure). The other side looks normal. Only about 1/4” looks removed.
    I’m leery of spacers and try to keep it all OEM dynamics for the most part. I’ve posted pics of my ‘16 years of inner frame rub’ as I’ve been on this size tire since 2003. Its barely a rub mark. They’re Michelins and they seem smaller due to lack of sidewall nobbies.
  27. Jun 23, 2019 at 7:17 PM
    #7917
    KarmaKannon
    Utah
    Some junk
    Stock wheels keep everything the same but even different size tires change kpi and leverage. As far as geometry is concerned 4.5" backspacing on the same width wheel as one with with 5.5" backspacing and 1" spacers it's the same. Obvious with spacers you have an extra set of lugs and possible issues with that or hub centric issues.
  28. Jun 23, 2019 at 8:13 PM
    #7918
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Professional Hand Model and @because_v8 are correct.
    16x8, no spacer. I run 13WL calipers (2004-2006 used them) and they clear fine.
  29. Jun 24, 2019 at 5:46 AM
    #7919
    fs007
    fs007 New Member
    04 tundra
    thank you!
  30. Jun 24, 2019 at 6:00 AM
    #7920
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
