  1. Jun 9, 2019 at 8:25 PM
    #7591
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Feed the Tundra today. He was hungry after helping me build my Tacoma Trailer.
    Lemon Grass is his favorite snack.
    and on the funny side - offered my BBQ on C'list. Guy shows up to get it - driving a Sequoia - same year & color as my Tundra! Nice.
    Need to mount the rear bumper & mount some Toyota rims (same bolt pattern!).
  2. Jun 10, 2019 at 5:49 AM
    #7592
    speedtre
    speedtre New Member
    Inland Northwest
    Well, call me shocked, shocked I say....:thumbsup:
    NUDRAT likes this.
  3. Jun 10, 2019 at 5:50 AM
    #7593
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    See, I was going with retired / semi-retired. But high energy/focused works too (& allows for my first guess). :)
    Darkness likes this.
  4. Jun 10, 2019 at 5:53 AM
    #7594
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Brilliant! and as the guy following too closely behind you who can't see through/around you at the traffic ahead - thank you!
    Casper421[QUOTED] likes this.
  5. Jun 10, 2019 at 6:01 AM
    #7595
    speedtre
    speedtre New Member
    Inland Northwest
    I remember it from first runs as a kid....we got to stay up late Friday nights. :) It was one of the shows that had attractive women nearly every episode...I was old enough to realize I really liked watching the pretty ladies...but not old enough to know why yet...at least not when it first aired. :thumbsup:
  6. Jun 10, 2019 at 6:43 AM
    #7596
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It appears I may have wasted $50 on this wheel speed sensor. I'm still getting false ABS activation, almost always as I'm moving slowly with the wheel turned to the right. I guess the next step would be to inspect the tone ring as @empty_lord suggested. I may just wait and eventually order moderate angle CV's from CVJ.
  7. Jun 10, 2019 at 6:51 AM
    #7597
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That and Magnum P.I.
  8. Jun 10, 2019 at 9:05 AM
    #7598
    Wings11
    Wings11 New Member
    Wings
    2002 Tundra garage whole life 80k
    So far new kicker speakers in doors and window tint all the way around
    Nice is there an instructional video for what has to come off to chenge the dash bulbs
    because_wumbo-truck likes this.
  9. Jun 10, 2019 at 10:03 AM
    #7599
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Check the wheel bearing if it’s when turning. If there’s play the tone ring might be getting out of the sensors range
    FirstGenVol[QUOTED] likes this.
  10. Jun 10, 2019 at 10:59 AM
    #7600
    Professional Hand Model
    Hand Protectors
    Added some zip ties to the evap hoses and finalized taping off the wire harnesses where they over lap and/or have connector braces attached where the OEM tape has frayed/dried out.
    Darkness and NUDRAT like this.
  11. Jun 10, 2019 at 11:00 AM
    #7601
    Wammer
    Wammer New Member
    MN
    2003 Tundra SR5
    Yep. Check here: gear indicator lamp
    tvpierce likes this.
  12. Jun 10, 2019 at 1:49 PM
    #7602
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What do you guys use when even an impact driver won't get a stuck nut to budge? A friend and I tried to remove his axle nuts over the weekend and even with the impact driver he rented they wouldn't budge. Tried a breaker bar. Soaked it in Kroil. Nothing. Maybe we just need one with more torque? I don't know the specs for the one he rented.
    Edit to add that the vehicle came from up north and has a ton of rust.
  13. Jun 10, 2019 at 1:52 PM
    #7603
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Breaker bar and a pipe. Have a friend stand on the brakes to keep everything from moving.
    NUDRAT and Jerry311SD like this.
  14. Jun 10, 2019 at 2:21 PM
    #7604
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    What are the specs on the compressor? Air flow is extremely important for an impact wrench. I recommend high-flow fittings. Do not use the small diameter coiled hose.
    https://www.amazon.com/Flexzilla-Hi...a+high+flow+air+fittings+,aps,206&sr=8-1&th=1
  15. Jun 10, 2019 at 2:27 PM
    #7605
    SoCalPaul
    Paul
    I also have one of these. It spun it off like it was nothing.
    https://www.amazon.com/Nitrocat-125...itrocat+1250k&qid=1560201947&s=gateway&sr=8-2
  16. Jun 10, 2019 at 2:52 PM
    #7606
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This one was battery powered. No compressor.
  17. Jun 10, 2019 at 3:40 PM
    #7607
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I'll use a 2 ft breaker bar with a 4-6ft pipe slid over the handle. if that doesn't break something loose nothing will.
  18. Jun 10, 2019 at 3:43 PM
    #7608
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    General Spring with Icon AALs
  19. Jun 10, 2019 at 3:48 PM
    #7609
    tvpierce
    tvpierce Formerly New Member
    Maine
    That’s not even going to come close to the torque necessary.
  20. Jun 10, 2019 at 4:10 PM
    #7610
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The new ones are pretty powerful. Clearly this one wasn't.
  21. Jun 10, 2019 at 4:33 PM
    #7611
    Hand Protectors
    What brand?
  22. Jun 10, 2019 at 4:48 PM
    #7612
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Makita. I looked it up, it's reporting 1,500 inch lbs of max torque.
  23. Jun 10, 2019 at 4:50 PM
    #7613
    Hand Protectors
    INCH pounds?
    1500 divided by 12 = 125 foot pounds.
    Someone?
  24. Jun 10, 2019 at 5:01 PM
    #7614
    Casper421
    In the woods
    06 DC
    bmf4069, speedtre, Darkness and 2 others like this.
  25. Jun 10, 2019 at 5:30 PM
    #7615
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    How much those generals set you back? Specs?
  26. Jun 10, 2019 at 5:33 PM
    #7616
    because_wumbo-truck
    Jon
    Houston, Texas
    Got my truck back from the shop. I don't feel too noticeable a difference with the new injectors. But.i do have a fast clicking on the passenger side, possibly the rear wheel. I don't think it's a rock in the tire, it's too fast sounding. I think it's a bearing.
  27. Jun 11, 2019 at 3:36 AM
    #7617
    Hand Protectors
    I think the garage gremlins snuck into your truck at the shop.
  28. Jun 11, 2019 at 3:38 AM
    #7618
    tvpierce
    Maine
    @Professional Hand Model 's math is correct... 125 ft lbs. We're talking the front axle nut, right? The torque spec is something like 250 ft lbs, and you'll need more than that to loosen one. My guess would be about 400 - 500 ft lbs would do it.
    Put the wheel back on and get it off the jack/stands so the weight of the truck is holding the axle in place. Then use a breaker bar with a cheater pipe on the end. And make sure your pushing down rather than pulling up on the bar. That means on the passenger side, you'll be behind the front axle, on the driver's side, you'll be in front of the axle.
  29. Jun 11, 2019 at 5:36 AM
    #7619
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's interesting that we both get our trucks back from the shop and now have NEW issues we never previously had. That's not how it's supposed to work.
  30. Jun 11, 2019 at 5:57 AM
    #7620
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Funny it worked like that every single time my parents took their car to the Chrysler dealer back in the day. Huh. :evil:
