  1. Jun 8, 2019 at 2:39 PM
    #7561
    Professional Hand Model
    Hand Protectors
    Sounds like they didn’t test drive it after the work was done. Thats the only way to get it right from my experience.
    They probably hustled on the work. Filled it and done with driving it farther than the parking spot. Probably needs about a 1/2 gallon more coolant if the res is dry.
  2. Jun 8, 2019 at 3:09 PM
    #7562
    Hand Protectors
    Cleaned the throttle body. The dirty spots on rag are about half the soot I removed just going in through the front butterfly. Last time I did this about 6 months ago, I removed the throttle body assy and cleaned it from the backside as well as the front. This was much easier today. The grime from 6 months driving!
    Added about 3oz. of CRC limited slip juice in the rear diff as I’ve noticed a small grumble on sharp turns from a stop and suspect the LS clutch needs the extra fortification even though the existing diff oil is newer Lucas for LS. Read some reviews on the CRC where a few 1st Gen Tundra and Taco guys had the same problem whether using Mobil1 LS or Lucas LS diff oil.
    Replaced the transmission filter on the Mz Handmodel car. Took two hours of forearm skin tearing arm wrestling with the hose clamps not the mention the wires and other crap in the way. Here is the post mortem pic. Looks dirty with 36k miles. Never mind the metal shavings from the saw blade cutting.
  3. Jun 8, 2019 at 4:55 PM
    #7563
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    That's exactly what happened. They told me.it would be ready Friday and I got there as they were closing and they had just rolled it out maybe 10 mins prior.
  4. Jun 8, 2019 at 4:57 PM
    #7564
    because_wumbo-truck
    Jon
    Houston, Texas
    I don't know where you find all the time to do some much truck stuff lol
  5. Jun 8, 2019 at 5:00 PM
    #7565
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I learned my floor jack is no longer tall enough to lift my front tires off the ground. Anyone recommend a jack?
    I had to replace my wheel speed senor with the tire on. It wasn't difficult but made it harder to reach. We will see of this fixes the false ABS activation. I drove it for an hour and it never happened.
    I also did another drain and fill of the transmission today. 4 quarts out, 4 in.
  6. Jun 8, 2019 at 5:12 PM
    #7566
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I’ve got a Harbor Frieght Daytona 3 Ton. It’s great. It lifts up to I think 24.5”. But it’s one of the highest lifting floor jacks out there (besides the Pro Eagles)... but this one is under $150
  7. Jun 8, 2019 at 5:16 PM
    #7567
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I typically jack it up under the lower control arm and put the jack stands a little farther back on the control arm.
    If I need some more height I've got some 2ft lengths of 2x12 to stack up.
    speedtre likes this.
  8. Jun 8, 2019 at 5:17 PM
    #7568
    Hand Protectors
    Todays work on the truck took about 30 minutes tops. It was the other car that set me back 2 hours for a simple filter. Starting to focus on the other vehicle a little bit now that the truck is tightened up for the most part.
    Its all in the planning. Efficient use of time is time wisely spent. Spend extra time doing something right and it frees up the time wasted to re-fix a rush job which frees up time for other stuff on your list. I only like doing something once properly the first time.
    Plus, I am a high energy guy. Highly focused and not easily distracted.
  9. Jun 8, 2019 at 5:20 PM
    #7569
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This reminds me. Have you seen these throttle body spacers for our trucks? What do you guys think about these?
  10. Jun 8, 2019 at 5:22 PM
    #7570
    Hand Protectors
    From my readings they are useless, but can’t speak from experience.
    FirstGenVol[QUOTED] likes this.
  11. Jun 8, 2019 at 5:32 PM
    #7571
    Hand Protectors
    Cut a couple of scrap 2x6 blocks and keep them in your backseat well with your OEM jack. You can use them for your service work with your floor jack and will definitely need them if changing a spare on the road.
    Your transmission is loving it.
  12. Jun 8, 2019 at 6:37 PM
    #7572
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    New exhaust :woot:
    E5715086-76BE-43C3-A04B-0EC7498F05F4.jpg 4C241FCA-1D5B-4EF7-A40D-D292185333F0.jpg 90268409-C7B3-487C-B9FA-B5C1DB65A7A5.jpg 7EF87C07-9946-4154-98D0-83B4A35E4C6F.jpg F862E942-2E5C-4755-9566-8B7946689BDA.jpg
    Not a fan of how low I had to make it, so I might buy a 15 degree bend to raise it up a couple inches while still avoiding the leaf spring.
  13. Jun 8, 2019 at 6:58 PM
    #7573
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Waste of money from what
    I’ve experienced on ones people have had me instal
    Good for drilling and installing methanol injection kits though
  14. Jun 8, 2019 at 7:01 PM
    #7574
    because_wumbo-truck
    Jon
    Houston, Texas
    I just use a piece of 4x4 on top of my jack
    tvpierce and speedtre like this.
  15. Jun 9, 2019 at 4:50 AM
    #7575
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    It’s duplicolor bed armor
    phiredrop[QUOTED] likes this.
  16. Jun 9, 2019 at 4:57 AM
    #7576
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Nice. It seems everyone is getting exhaust. How does it sound?
    lsaami[QUOTED] and Filthyphil like this.
  17. Jun 9, 2019 at 9:34 AM
    #7577
    Wammer
    Wammer New Member
    MN
    2003 Tundra SR5
    Replaced my drive indicator bulb.
    Mr. Pink, Wings11, Rex Kramer and 5 others like this.
  18. Jun 9, 2019 at 12:42 PM
    #7578
    lsaami
    lsaami Let ‘er buck
    Minnesota
    It sounds good. Not as good as it did with no muffler and a rusted out resonator, but good enough. I’m working on an exhaust video. Hopefully have it done tonight.
    justfortun and Filthyphil like this.
  19. Jun 9, 2019 at 1:04 PM
    #7579
    Hand Protectors
    Went Island Hopping today. Took a siesta on the way back and enjoyed the nice salty breeze with the doors open.
    bmf4069, NUDRAT, Rheywood456 and 2 others like this.
  20. Jun 9, 2019 at 1:31 PM
    #7580
    because_wumbo-truck
    Jon
    Houston, Texas
    Florida?
  21. Jun 9, 2019 at 2:07 PM
    #7581
    Hand Protectors
    Maybe. Maybe not. I hail from St. Barts, but live on ‘Fantasy Island’ where your dreams can become reality thought rarely work out the way you desire.
    Acatlin96, TX-TRD1stGEN and Darkness like this.
  22. Jun 9, 2019 at 2:12 PM
    #7582
    Hand Protectors
  23. Jun 9, 2019 at 2:13 PM
    #7583
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    He's not gonna tell us. It shall forever be a mystery. :)
  24. Jun 9, 2019 at 2:38 PM
    #7584
    because_wumbo-truck
    Jon
    Houston, Texas
    Is that how that show worked? I'm too young to remember, although I did grow up in the 90s and remember watching reruns of all those 60s and 70s and 80s shows. I was really into CHiPs and A-Team and Night Rider.
  25. Jun 9, 2019 at 2:40 PM
    #7585
    because_wumbo-truck
    Jon
    Houston, Texas
    Looks like the 3rd coast based.on the water.
  26. Jun 9, 2019 at 2:46 PM
    #7586
    NMTundra
    NMTundra New Member
    Definitely.
  27. Jun 9, 2019 at 3:02 PM
    #7587
    Casper421
    In the woods
    06 DC
    Installed a 3rd brake light that’ll be visible when the tent is on the truck:
  28. Jun 9, 2019 at 4:12 PM
    #7588
    Hand Protectors
    I learned how the show worked by watching youtube. Basically, be careful what you wish for is the main theme along with a secondary theme of always listen to Ricardos advice. Tatto is the snitch, but never gets stitches.
    I like those other shows, as well. I pity the fool!
  29. Jun 9, 2019 at 6:57 PM
    #7589
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I did a magnaflow knockoff from a company on Amazon. I had one on my Titan and I liked it and it sounds even better on my 06 tundra. I just did a turndown after the muffler about 3'. I did a helmholtz resinator when I installed the muffler but it actually gave the exhaust a whistle at higher rpm so I removed it. Still sounds great in my opinion, even if it has just a hair more resonance than I'd ideally want
    fs007[QUOTED] likes this.
  30. Jun 9, 2019 at 8:20 PM
    #7590
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    A cheery bomb into a 2nd cherry bomb sounds pretty good on my turbo SAAB. ;-)
    When I extended the 3" exhaust past the rear apron all the resonance went away.
