  1. Sep 16, 2025 at 6:56 AM
    Sadly, no cap holder in the later years like mine :(
    Believe me, I've bitched about it several times on here.
    oscardog86[QUOTED] likes this.
  2. Sep 16, 2025 at 7:03 AM
    It really boils down to the bulb. If the bulbs are supposedly "CANBUS compliant", they should have adequate resistance built into the bulb and/or its driver to avoid issues.
    LEDs draw less than a standard halogen, in some cases, exorbitantly less. You're using resistors to effectively emulate the effect on the circuit, to mimic what a normal halogen would do. But it's only necessary in cases where the manufacturer doesn't bother, and in 2025, failure to manuf'er your product such that it's CANBUS compliant is a sign your product is inferior.
    I'm fairly certain hyperflash is rooted in the same issue: Using LEDs in place of a standard light, such that the relay doesn't have enough load on the circuit to function correctly, so it triggers like ham.
    Hi06silver likes this.
  3. Sep 16, 2025 at 7:08 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Mine settled quite a bit. I ended up raising the front not too long ago.
    When we finished.
    2 days later.
    A while later. (Bonus pic of Donut)
  4. Sep 16, 2025 at 7:18 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Good to know, ill keep an eye on the lift and see if its settling over the next few days then!
    KNABORES likes this.
  5. Sep 16, 2025 at 7:59 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You can always buy an earlier door version and paint it white.
  6. Sep 16, 2025 at 8:04 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    It's been done, but they are not a direct swap. there is a post or 2 on here about it. I remember some guy using rivets.
  7. Sep 16, 2025 at 8:13 AM
    Jack McCarthy
    Bill
    North of Boston
    I wonder if it coincides with removal of the lock on the gas door? A feature most people don’t mind having.
  8. Sep 16, 2025 at 8:18 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    correct
    EDIT: Here's a thread where a guy did a good job, but doesn't detail what is involved. Fuel door interchange | Toyota Tundra Forum
  9. Sep 16, 2025 at 8:32 AM
    Jack McCarthy
    Bill
    North of Boston
    Looks like just the plastic fuel filler surround was just replaced with an integrated latch/opener mechanism and the door itself. No real permanent modifications necessary.
  10. Sep 16, 2025 at 9:33 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I figured CANBUS compliant bulbs would keep errors from popping up on CANBUS vehicles. Guess it could also have a positive/noticeable effect on non CANBUS vehicles too.
    It always drives me crazy that so many people will go through the effort of doing LED turn signal bulb swaps in their vehicles but then just not care about having hyperflash.
    The Black Mamba likes this.
  11. Sep 16, 2025 at 9:37 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    That and the constant flickering DRLs.
  12. Sep 16, 2025 at 9:46 AM
    I hate that, almost like a rapid strobing, if you look off-center of the headlights you can see them sparkling. And I don't think the drivers are aware their lights are doing it. Drives me nuts.
