  1. Sep 9, 2025 at 1:18 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Someone’s hand reaching for 3 pieces of bacon in the microwave is what I see. :burp:
    Bought2Pull, Kimosabe, BroHon and 6 others like this.
  2. Sep 9, 2025 at 1:30 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yours is a 2000. In 2003 the electric rear slider was an option and the fog light switch was move from the dash to the left stalk on the steering column.
  3. Sep 9, 2025 at 2:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I finished insulating the bed today. I didn't take any pics, but I used some 1/8" 'hardboard' to cover the reflectix on the tail gate and bed floor, gorilla taped the reflectix to the bedsides and front, then covered with the bedrug. It came out pretty good. Hopefully it'll help keep me from freezing, like I did at both of the T2S's that I attended, while sleeping back there. :D
    I also got the correct wire harness in the mail today for my A.R.E. topper, to power the dome light and brake light. Will be easy enough to tap into the driver side brake for power and to ground to chassis. I'm not sure where I should tap for dome light power, or if I should just run it to the battery.
  4. Sep 9, 2025 at 2:31 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    No!
    Mine are tapped into the cargo switch.
  5. Sep 9, 2025 at 2:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So do they only get power when that switch is hit and/or the door open?
    Do you just leave the dome light set to "on" at the cap?
    Mine has a push button on the caps dome light.
  6. Sep 9, 2025 at 2:46 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Good points. Mine are only on when the cargo light circuit is powered so yes, that wouldn’t work for you. Maybe tap a fuse that is constant on? If you do go straight to the battery, you need to install an in-line fuse
  7. Sep 9, 2025 at 2:49 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Luckily the harness has an inline fuse for each power wire.
    I might use an add-a-circuit to a fuse that has constant power then. I need to do that to power my compass mirror still anyways, but with a fuse that comes on with accessory.
  8. Sep 9, 2025 at 2:51 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Just make sure the fuse is as close to the battery as possible.
  9. Sep 9, 2025 at 3:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Why is that?
  10. Sep 9, 2025 at 4:33 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Well today, since I had my truck on a lift to do an oil change, I thought I'd finally chase the threads in the skid plate and side wings. After the tap treatment and new bolts, with a little anti-sieze they spin in like new. 25 years ago the free dealer oil change distorted the threads and overfilled the engine by 1 quart. First and last change at the dealership. Every 5 k by me since, but the bolts were getting worse every time, so today was the day to finally address the problem. IMG_20250909_105745917.jpg IMG_20250909_105740268.jpg IMG_20250909_105727768.jpg
    BroHon, Filthyphil and Jack McCarthy like this.
  11. Sep 9, 2025 at 4:35 PM
    Jack McCarthy
    Bill
    North of Boston
    You have an outside lift? Nice!
    BroHon and Filthyphil like this.
  12. Sep 9, 2025 at 4:37 PM
    chunk
    chunk New Member
    My friend of 50 years does, almost as good.
  13. Sep 9, 2025 at 9:26 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Today, towed the single axle trailer with a single axle trailer loaded on it!
    Doing another odd job, this time trimming some low branches and cutting up three fallen trees for a neighbor. It's my old house so I needed to tow the equipment over there.
    Single axle hauled the riding mower and a small, single axle cart my father welded up from scratch about 30 years ago.
    Every tool I bought was used. Mower towed the cart that carried the chainsaw, pole saw, slate bar, wood blocks, hammer, cap wedges, reciprocating saw, tow chain with hooks, just the whole kit and kaboodle. Three times, the cart hauled the cut up logs to the burn pile.
    Things went well....although I got a bit of tunnel vision and carried on my shoulder a log a bit heavier than I should have. What's worse, I tossed it over a small creek onto the burn pile......not a good idea! Calling massage therapist and maybe a chiropractor tomorrow! :oops:
    Finished, loaded up, and headed home just as darkness fell. I didn't want to risk backing up into my old driveway at night so I went down the road to my favorite turn around spot. Managed to back through a 90 degree turn without the benefit of seeing anything out my side mirrors! (No streetlights there you see). I guess I've done this enough every week mowing down there I really can do it "blind." :cool:
    I've decided though, had I had the diesel tractor to use, things would have gone a lot faster and safer without me torquing my old back injury. The Tundra could have pulled it and the 2-axle would have hauled it. I've decided to get the tractor serviced and buy the attachments it needs to make jobs like this a breeze. :amen:
    Sirfive likes this.
  14. Sep 9, 2025 at 9:29 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    run a switch to the light when you add a 12v adapter to the bed so you can charge your phone or run a fan while you sleep.
  15. Sep 9, 2025 at 9:30 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    After some advice here, I bought a thread chase kit to do this same thing. My truck has non-OEM bolts holding the skid plate on, those threads may be in the same shape yours were in. Congrats.
    I doubt I could take my Tundra to a shop for an oil change since I put the Valvomax Oil Drain System in. I doubt they could figure that thing out.
