  1. May 29, 2019 at 1:29 PM
    #7321
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Check out my post over on Tacoma World when i had my Tacoma I found a red camper shell and painted it. Turned out pretty good.
    I used Tan Plasti dip.
    <a href="https://www.tacomaworld.com/threads/painting-a-camper-shell.512275/#post-16329079">Painting a camper shell</a>
  2. May 29, 2019 at 1:47 PM
    #7322
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    Do you still have it? I wonder how well plastidip has help up. The only issue is I'd like to match the color - I got the shell for free so if I spend $400 to color match it, it won't be crazy expensive.
    NUDRAT likes this.
  3. May 29, 2019 at 1:52 PM
    #7323
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    No I sold the truck to get my Tundra. 200K HARD supercharged miles on it. it was time for it to go.
    I do have Black Plasti dip on my Mirrors and it still looks good after a year.
    I went the Plasti dip route because I did want to pay someone to paint the shell, and I like to do everything myself.
  4. May 29, 2019 at 1:59 PM
    #7324
    Musashi66
    If I could get OEM toyota color plastidip for $45, I might consider doing it!
  5. May 29, 2019 at 2:05 PM
    #7325
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Old paint will be hard to match.
    I'd paint it black.
  6. May 29, 2019 at 2:25 PM
    #7326
    Musashi66
    Nope, zero interest in that.
    Jerry311SD[QUOTED] likes this.
  7. May 29, 2019 at 2:28 PM
    #7327
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Ok Maybe Macco can get close match to your trucks color.
  8. May 29, 2019 at 2:28 PM
    #7328
    Professional Hand Model
    Hand Protectors
    Try this site for a very good color match. I ordered 1D6 custom color for my side doink. It turned out pretty well. Looks good from most angles. Certain angles you can tell its ‘blended/feathered’.
    Order your color match along with a can of clear coat. Both are lacquer finish. Dries fast. Will look good as the camper top is separate from the truck. Could do it for less than $50 in materials.
    https://www.automotivetouchup.com/spray_paint.aspx
    NUDRAT likes this.
  9. May 29, 2019 at 2:29 PM
    #7329
    Musashi66
    They’ll use the oem color as it was when it was new. I know it won’t be the same, but it will be better than another color.
  10. May 29, 2019 at 2:30 PM
    #7330
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I hear ya, hopefully it wont look to different
    Musashi66[QUOTED] likes this.
  11. May 29, 2019 at 2:31 PM
    #7331
    Musashi66
    You think it can be done that cheaply? I have that website saved, and was toying with the idea of buying paint and using my compressor and spray gun to attempt painting it. I guess for $50 I’d give it a shot.
  12. May 29, 2019 at 2:37 PM
    #7332
    Hand Protectors
    They come color matched in rattle cans. Plug in your color code. Gloss finish (2 cans?). 1 can of lacquer.
    You probably do not need primer as your cap top is close match. If so go to big box.
    Definitely do your due diligence on prep.
  13. May 29, 2019 at 2:45 PM
    #7333
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    My canopy is for the light grey tundras and I have thunder grey. I’ve really been thinking about doing this with color matched spray cans, I just need to do more research.
  14. May 29, 2019 at 2:49 PM
    #7334
    Musashi66
    If I do it before you, I’ll post here.
    Filthyphil[QUOTED] likes this.
  15. May 29, 2019 at 2:51 PM
    #7335
    Hand Protectors
    Give that site a go. Follow directions. In my case, I blended in a side doink on my rear pass side bed panel. Its not perfect due to blending metallic. I’m sure if I was doing a top it would look very nice as its disconnected to the eye.
  16. May 29, 2019 at 3:04 PM
    #7336
    Hand Protectors
  17. May 29, 2019 at 3:48 PM
    #7337
    Hand Protectors
    Painted my front grille frame and side mirror caps with the 1D6 matched paint. No primer. 3 coats color and 2 lacquer clear coat.
  18. May 29, 2019 at 3:52 PM
    #7338
    Hand Protectors
    Wally Wurl delivery of Mobil1 High Mileage Synthetic 5w-30 4 jugs arrived today.
    $22 a 5 quart jug.
    $10 off with rebate.
    $12 a jug after rebate!
    TX-TRD1stGEN and Musashi66 like this.
  19. May 29, 2019 at 4:05 PM
    #7339
    Musashi66
    So, you bought the base coat in the color of your truck, applied it, and when it dried, you used this clear coat?
    https://www.automotivetouchup.com/spray_paint_clearcoat.aspx
    Or, did you have to wear a mask and you used the urethane coat?
    https://www.automotivetouchup.com/spray-paint/spraymax-2k-clearcoat.aspx
    Thanks!
  20. May 29, 2019 at 4:15 PM
    #7340
    Hand Protectors
    The top link clear coat (its lacquer). Yes. Bought and sprayed the base coat. Then applied the clear coat. Dries quick. Follow directions.
    Not the urethane clear coat where you need to buy a respirator to make the purchase, even though you should at least wear a dust mask.
  21. May 29, 2019 at 4:17 PM
    #7341
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm pretty sure hes got more hours in that truck than any Toyota mechanic! :rofl:
  22. May 29, 2019 at 4:25 PM
    #7342
    Musashi66
    Got you! Well, their coverage chart says you need 3 spray cans of base color to cover the roof of a small car. Then another 4 cans of clear as well. My topper probably has double the surface area of a small cars roof. That means 6 cans of base and 8 cans of clear. That is $200 in cans before any prep material. Does that sound right?? I could buy a pint of ready to spray and see how good of a compressor and sprayer I have...
  23. May 29, 2019 at 4:59 PM
    #7343
    Hand Protectors
    Your call. I think the coverage per can is more than what they quote, but don’t believe me. I ordered way more than needed due to their quote. I’d say 3 rattle cans color max, plus 1-2 lacquer clear coat. cans.
    Stuff goes far.
  24. May 29, 2019 at 5:12 PM
    #7344
    Hand Protectors
    Yes I do. Now she is sitting in top shape again. Amazing how much work it takes to get things right most of which are items a mechanic wouldn’t mess with. Or, a specialty shop would $$$!
    Now I’m into basic fluids/tune up maintenance hopefully for 2-3 years or longer of which I have a full oil stock up to last that long.
    Only thing on the ‘look out radar’ is the steering rack leak and thats being a non issue drip for a few years. Res levels remain good.
    I didn’t do anything to her for the first 12 years besides tires and fluids (done by a shop). Unbelievable this truck is almost 20 years old.
    speedtre, NUDRAT and bmf4069[QUOTED] like this.
  25. May 29, 2019 at 5:21 PM
    #7345
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Let me know how it turns out.
    I’m just really worried about actually getting it bolted up. I’ve tried aftermarket bumpers on my corolla only to find out they don’t event fit
  26. May 29, 2019 at 6:21 PM
    #7346
    Filthyphil
    Phil
    So if I did like a whole hood it wouldn’t look blended and would match the truck pretty close?
  27. May 29, 2019 at 6:26 PM
    #7347
    Hand Protectors
    It would look blended. Its not a perfect match. Your entire truck would need painting for perfection.
    If you are ok with close and a different gloss level then its good.
    I’m happy with my repair although at certain angles you can see the shading is different. Some angles look spot on, but thats color/sheen matching for you.
    because_wumbo-truck likes this.
  28. May 29, 2019 at 6:42 PM
    #7348
    Filthyphil
    Phil
    Anything would look better then the peeling clear coat it’s got going on now haha
  29. May 29, 2019 at 6:48 PM
    #7349
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Tire rotation,cleaned up wheels and found a coolant hose that needs attention.
    Gave the Benz a bath also for some (for sale pics).
  30. May 29, 2019 at 8:10 PM
    #7350
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Coach Builders shins are .25” resulting in .5” of lift per shim. No problems with fitment. Shim was very easy to install
