  1. May 29, 2019 at 6:55 AM
    #7291
    Casper421
    In the woods
    06 DC
    Bought a new steering rack.
    abcinv, bmf4069, TX-TRD1stGEN and 2 others like this.
  2. May 29, 2019 at 7:01 AM
    #7292
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    Did you install your own camera? I watched a video, and tapping into the reverse seemed like something I would not do on my own. My local cartoys charges $150-185 for a camera+install.
  3. May 29, 2019 at 7:08 AM
    #7293
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Rack doctor or ebay? Are you going to replace the tie rods or leave them for now?
  4. May 29, 2019 at 7:19 AM
    #7294
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If you have the 7 pin trailer connector it's pretty easy to do, cut the wire, use a crimp splice, and use a piece of adhesive heat shrink and you're done.
    Musashi66[QUOTED] likes this.
  5. May 29, 2019 at 7:33 AM
    #7295
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    Anyone see an issue combining a small spacer/shim with the Icon 2.5s? I would like to achieve 3.5" in the front. Thanks.
    Rheywood456 likes this.
  6. May 29, 2019 at 7:35 AM
    #7296
    Casper421
    In the woods
    06 DC
    Rack Doctor. I have a feeling I’ll be using their lifetime warranty.
    I replaced the outers a year ago so I’ll just swap them over.
    FirstGenVol[QUOTED] likes this.
  7. May 29, 2019 at 10:27 AM
    #7297
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I think I do. I’ll check my spare parts bag cause I know I bought a few last time mine broke. If I’m remembering correctly it is the same little plastic clip the Chevys use too... I’ll get back to ya!
    NUDRAT and MDobb79[QUOTED] like this.
  8. May 29, 2019 at 10:29 AM
    #7298
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I’m running a Coach Builder Shim on top of my Icon 2.5s. I’m at about 2.75”. 3.5” might be pushing it for height wise on Coilovers unless you extend your bump stops.... Are you 4x4?
  9. May 29, 2019 at 10:30 AM
    #7299
    andrew8404
    andrew8404 New Member
    Andrew
    Ya I did. Luckily the previous owner had an aftermarket pioneer unit and back up camera but neither worked. So when I replaced the radio and tapped into the existing camera I was able to get everything to work thankfully.
  10. May 29, 2019 at 10:32 AM
    #7300
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Bought one of their racks for my old 4runner. Seemed to be good quality, but sold it before I ran into any issues.
    Casper421[QUOTED] likes this.
  11. May 29, 2019 at 10:32 AM
    #7301
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I didn’t have any sort of lean. My truck was level with the same amount of preload on the Coilovers. It’s very easy to adjust once they’re on the truck so my advice is to keep preload the same then adjust after ride height / springs settle
    Casper421 likes this.
  12. May 29, 2019 at 11:00 AM
    #7302
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Will you make a new thread when you do this? I'm pretty sure it's in my future. I'm losing PS fluid to where it starts making angry noises a month after I fill it. And I thought if you bought a new rack it came with outers as well?
  13. May 29, 2019 at 11:07 AM
    #7303
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    What size shim? Have any issues with fitment? I went with the 700# spring so I won't need to pre-load as much as the 650# spring that comes with the Icon 2.5s. I am 4x4 and new bump stops are the next thing I was going to start looking into.
    Rheywood456[QUOTED] likes this.
  14. May 29, 2019 at 11:16 AM
    #7304
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just a heads up, eBay has a USA made rack with lifetime warranty. You have to return your original to activate your warranty and then they will give you $25 back. They also give you a prepaid shipping label for the old one. Not trying to take away from Rack Doctor just listing another option I saw. I think this is the one @Rheywood456 ordered off eBay.
    https://www.ebay.com/itm/Complete-Power-Steering-Rack-and-Pinion-Assembly-Fits-2001-2006-Toyota-Tundra/153283894390?fits=Year%3A2002%7CModel%3ATundra&epid=20007009752
  15. May 29, 2019 at 11:26 AM
    #7305
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Detroit Axle Is a respectable brand as well. My dad has bought lots of stuff through them.
    NUDRAT likes this.
  16. May 29, 2019 at 11:51 AM
    #7306
    Musashi66
    I drove over to Suburban Toppers for a quote to get my topper 3rd brake light working. Scheduled for next Wednesday for $50.
    Also, drove over to Maaco to ask about painting the topper. The topper I have works perfectly, expect it is the wrong color and all the clear coat has peeled off. They want $400 for Urethane+integrated clear coat with a 4 year warranty or $500 for base coat + clear coat and 5 year warranty. Does anyone have experience with painting toppers? Is this a decent deal, and more importantly, can I trust Maaco? I am not looking for fancy car show ready finish - after all, the truck has been parked outside for last 19 years anyway - but I want something that will last, say another 10 years.
    Any thoughts?
    NUDRAT and Rheywood456 like this.
  17. May 29, 2019 at 11:57 AM
    #7307
    speedtre
    speedtre New Member
    Inland Northwest
    You could also get it Line-Xd in a color that matches your truck...that's what I plan to do if I can't find a matching color topper...
    https://linex.com/bedliners/xtra
  18. May 29, 2019 at 12:01 PM
    #7308
    Alltimehigh
    Alltimehigh New Member
    Our toppers are 6.5 ft correct?
  19. May 29, 2019 at 12:05 PM
    #7309
    Musashi66
    I believe so, I didn't measure it to be honest. I know it's longer than my dad's 5.5 foot bed on his 2018, and I know a sheet of drywall sticks out so it's shorter than 84".
  20. May 29, 2019 at 12:06 PM
    #7310
    Musashi66
    My dad paid quite a bit for just the 5.5' truck bed in plain black finish. Can't even imagine the cost for the topper in color matched finish.
  21. May 29, 2019 at 12:13 PM
    #7311
    Casper421
    In the woods
    06 DC
    I will do my best but I’m no @Professional Hand Model.
    Rack Doctor includes inners, not outers. Other companies might include outers but mine are a year old so good to go.
    bmf4069[QUOTED] likes this.
  22. May 29, 2019 at 12:20 PM
    #7312
    Casper421
    In the woods
    06 DC
    Just a heads up, Icon doesn’t recommend cranking the 700’s more than 1-3/8” of thread.
  23. May 29, 2019 at 12:37 PM
    #7313
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    $400-$500 is probably about right. I haven't heard anything bad about Maaco. It usually comes down to the prep work. Might be able to save money if you sand it down yourself. You'll also get a better paint job if you remove the windows rather than paint around them.
    NUDRAT likes this.
  24. May 29, 2019 at 12:37 PM
    #7314
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You can also stick a topper made for a DC on an AC. It's not ideal but it fits. Or at least my ARE V series does.
  25. May 29, 2019 at 12:39 PM
    #7315
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    Thanks, I read that early today. The instructions for these things are not the greatest.
  26. May 29, 2019 at 12:39 PM
    #7316
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't know anything about Maaco but I probably would't pay that much to paint an old topper. Have you considered just doing it yourself? @Rheywood456 painted his. It won't look as good as a professional job but I think it would look good enough.
  27. May 29, 2019 at 12:42 PM
    #7317
    Musashi66
    $400 versus me dicking around for a day or two, without capability to cure it, plus I'd still need to spend decent chunk of change on paint... It seems worth it to me, and I still get a warranty.
    SoCalPaul likes this.
  28. May 29, 2019 at 12:45 PM
    #7318
    Musashi66
    I guess it all comes down to how much time am I willing to spend on this. I'll have to sleep over it. Thanks!
    SoCalPaul[QUOTED] likes this.
  29. May 29, 2019 at 12:57 PM
    #7319
    tvpierce
    tvpierce Formerly New Member
    Maine
    I just ordered a rear bumper from Rock Auto. I have all the parts/hardware, so just needed metal bumper. It was $83 for the bumper, and just under $40 to ship it. I don't expect the quality to be great, but I don't care. It comes primed, I'll cover it with roll-on bed liner and it should be fine.
  30. May 29, 2019 at 1:27 PM
    #7320
    andrew8404
    Andrew
    They do awesome work. Sounds about what I paid and it was a perfect match. Can’t speak for long term reliability since I sold it but it looked great.
