  1. Jul 28, 2025 at 8:33 PM
    Nimitz_
    Nimitz_ LA face with an Oakland booty
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    I mean shit, it’s $20 a gallon. It’s just barely more expensive than gas up here.
    BroHon[QUOTED] likes this.
  2. Jul 28, 2025 at 10:24 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    May find it helpful to swap the brackets from the original radiator to the new one so the bolt holes in the front apron line up with the bracket...like this person.
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-2313#post-3887336
    You'll also find a link in that thread to mods for when the slots in the old bracket didn't match the plastic retainers on the tank.
    Depends what rad so YMMV.
    bfunke, Nimitz_[QUOTED] and shifty` like this.
  3. Jul 29, 2025 at 2:18 AM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    I'm a fan of the Rupes dual action polisher, used it a lot more when I was sorta a detailer, although it's a bit pricey. I've heard great things about Griots for a lower budget option
    Filthyphil and BroHon[QUOTED] like this.
  4. Jul 29, 2025 at 5:18 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Got home from a 10 day vacation on Sunday. Went to start the truck Monday to load up the trailer and lawnmower, and upon trying to start just got a click, didn't try to crank at all. Jumped it off and good to go, started back on its own again later.
    Hoping my battery hasn't bit the dust yet, really just interested in seeing how long a 8 year old basic Walmart battery can last.
    shifty` and oscardog86 like this.
  5. Jul 29, 2025 at 6:43 AM
    Just make sure you drain it into a clean container, and run it thru a basic screen to filter out any sediment/garbage.
    Nimitz_[QUOTED] likes this.
  6. Jul 29, 2025 at 6:46 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Bigfoot or Mini Bigfoot model type or both?
    The Mini one is kind of interesting.
  7. Jul 29, 2025 at 6:47 AM
    I mean, anything over 3-5 years and I'm feeling like I got my money's worth. I'm at year 5 or 6 on my NAPA gold battery, it's going strong. I had to buy it in a pinch when my alternator died on the way to work not long after I initially got the truck.
    My last click-click situation was due to a tight-but-not-tight-enough-I-couldn't-force-movement-by-hand positive terminal. I have a professional tester, which showed the battery was toast once, but also showed it was good. That should've been my first sign.
    That said, if you don't have a tester that will test for volts/CA/CCA, stop by the auto parts store and have them test for free. Only takes a sec.
  8. Jul 29, 2025 at 6:51 AM
    I bought this one on biggirrrl. Easy to use, needs no batteries (other than the one your testing)
    https://www.amazon.com/dp/B08MPXGSGN
    shifty`[QUOTED] likes this.
  9. Jul 29, 2025 at 7:05 AM
    This is the one I scored on Goodwill's site for ~$30, with carrying case, instructions and misc goodies. Sadly it didn't come with the handheld printer.
  10. Jul 29, 2025 at 7:08 AM
    Jack McCarthy
    Bill
    North of Boston
    shifty` likes this.
  11. Jul 29, 2025 at 7:09 AM
    Nah. If the one I got wasn't $30, I would've never bought it. But I'll tell you, it's come in handy a couple of times so far. Sadly, more for friends/neighbors than myself.
  12. Jul 29, 2025 at 7:28 AM
    Same. I've used it quite a bit when battery trouble arises. The CCA test is invaluable at home. Saves me the trip to the LAPS where some chucklehead will try to tell me what's wrong. Or not, because he doesn't even understand the equipment he's operating. Or what a battery does.
    bmf4069, des2mtn and Jack McCarthy like this.
  13. Jul 29, 2025 at 8:53 AM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Porter Cable 7424, I've had mine going on 25 years and I made a lot of money with it. Good overall, versatile and a decent price. I moved onto a Rupes Bigfoot 21 a few years ago, huge upgrade but also a pretty big price tag.
  14. Jul 29, 2025 at 8:59 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I need to get a proper battery tester, mine doesn't do CCAs and is more for smaller batteries, but it gets me by. I do have a Foxwell scan tool that I got awhile back and it does pretty much all the diagnostics on the truck I need it to otherwise. It does even more on our newer vehicles than it does on the Tundra/ Corolla.
  15. Jul 29, 2025 at 10:26 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Like this?
    Voss, RealTruck, G_unit3000 and 6 others like this.
  16. Jul 29, 2025 at 11:53 AM
    NickB_01TRD
    Nick
    KY
    Oh I agree that I've gotten my money out of it (considering the PO bought it) but I just figure I'll run it till it doesn't run anymore. I have a small jumper and jumper cables and whatnot that will get me out of a pinch.
    I do have a battery tester but I don't think I've ever put it on the Tundra. Should probably do that soon now that I've had the issue. I'll probably remove the terminals to do the test just to verify that it isn't a terminal issue causing bad readings.
  17. Jul 29, 2025 at 12:04 PM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd tow package
    Whatever the expensive battery is usually lasts 5-7 years in my truck. My experience has been that upon the first symptom of a slower than normal crank, replace immediately. Back in the day it seemed that a car battery would limp along for quite a while, even months, before totally giving up. Modern batteries seem to die a quick death.
    G_unit3000 and oscardog86 like this.
  18. Jul 29, 2025 at 12:28 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  19. Jul 29, 2025 at 12:35 PM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Exactly, fancy man.... :rofl:;)
  20. Jul 29, 2025 at 1:20 PM
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra New Member
    Eric
    Looking for my future 1st Gen Tundra
    sweet shop and truck pic!
  21. Jul 29, 2025 at 2:25 PM
    manofsteele2003
    Wow, in ground post lifts. I haven't seen one of those since I worked at Midas 26 years ago.
    G_unit3000 likes this.
  22. Jul 29, 2025 at 2:27 PM
    Hey, look! It's one of those Obnoxious Shit Head Assholes!
    bmf4069[QUOTED] likes this.
  23. Jul 29, 2025 at 2:49 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Putting more trust in that parking brake than I. No chocks.
  24. Jul 29, 2025 at 3:18 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's not relying on the parking brake alone. I imagine it's also in park.
  25. Jul 29, 2025 at 3:38 PM
    He also got out and slapped the hood and said “that ain’t goin’ nowhere”. Solid.
    oscardog86, bmf4069, shifty` and 7 others like this.
  26. Jul 29, 2025 at 4:10 PM
    Neo
    Neo New Member
    Alabama
    (See Signature for Trucks Info)
    I just bought my first DA polisher ( ) last year. I have no idea how it stacks up against others, but it worked great on my niece's Accord.
  27. Jul 29, 2025 at 4:23 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    My rears are dialed in :woot:and yes, it's also in park.
    Voss, Kalannar97, BroHon and 4 others like this.
  28. Jul 29, 2025 at 5:53 PM
    Neo
    Neo New Member
    Alabama
    Thanks for the replies, @shifty` and others! Yesterday, I got my wife to stand outside while I pulled the truck out of the garage. Yep, it was the front brakes that were squealing after all. The 02 AC LTD is too tall for my Craftsman 2-1/4 ton floor jack, so I ended up using the OEM jack. Took me like 45 minutes to get the OEM jack to fully extend. It was stuck or something. Anyway, I pulled the pads and the backs of them were dry and gritty. That's really odd because I recall having to stop work and make a special trip to Autozone for some fresh brake grease when I installed them last September. I put a coat of brake grease on (shims were pre-installed) and re-installed. This definitely reduced the squeal, but it didn't completely go away.
    I take pictures when I'm working on things like this so I can (hopefully) put them back together exactly the way I found them. Only now am I noticing that the anti-rattle spring is on the bottom when it actually appears on the top in the FSM. I'm going to pull the wheels again in a few days to try the additional squeal fix that shifty mentioned in the quoted post. During that process, I'll also swap the anti-rattle springs to the correct position. I'm starting to feel like I need to join the "We do it right because we do it thrice" club. :mad:
    Voss, G_unit3000, Kalannar97 and 2 others like this.
  29. Jul 29, 2025 at 5:59 PM
    Neo
    Neo New Member
    Alabama
    Plexus!? I love that product. After a multi-year hiatus, I'm finally starting to see it back on the open market. The best price I've found so far is sold by / shipped by Amazon. I used to pick it up in person at my local Cycle Gear, but they're not yet back to selling it in store.
    M14 EBR[QUOTED] and Filthyphil like this.
  30. Jul 29, 2025 at 8:15 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Today? Got out my safety glasses and put those back.
    Yesterday: delivered the now-repaired riding mower to the client. Since I like driving the Tundra so much I went on a drive, even though I was pulling an empty trailer. :) Just a 5 mile loop, the long way back home.
