  1. Jul 23, 2025 at 5:42 PM
    Yeah that’s what I told him, one or the other. It’s always one or the other.
    455h0le_dachshund likes this.
  2. Jul 23, 2025 at 5:46 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    It is a mower, and IIRC it had the little platform on wheels you stand on so you don't have to walk it. :thumbsup: And that's why the operator/kid went in with it :eek:
  3. Jul 23, 2025 at 5:47 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm either going to have to look for another USB (I know I've got some somewhere) or figure out a different way to reformat, because that particular format unfortunately wasn't an option when I followed your instructions
  4. Jul 23, 2025 at 5:50 PM
    Weird. FAT32 is a very common option. It’s classic, like dating back to MSDOS days. FAT16 also.
    BroHon likes this.
  5. Jul 23, 2025 at 6:00 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Are you on Windows? That is weird
  6. Jul 23, 2025 at 6:06 PM
    I pull this up long grades and hills. 5000#
  7. Jul 23, 2025 at 6:21 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :notsure: I was using one for the laptops from your old gig.
    Like I mentioned before, that USB wouldn't even work at all on my previous laptop. I've probably had that USB well over 5 years and never successfully used it til I plugged it into my phone to download some Toyota splash screen images yesterday
  8. Jul 23, 2025 at 6:35 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Stock gears. Big heavy tires!
  9. Jul 23, 2025 at 6:42 PM
    Oh wait, was the USB stick you were using larger than 32GB?
    Windows, up to Windows 10 at least, won't format to FAT32 on anything 32GB+
    Microsoft lifted that limitation in Windows 11, so ... maybe that's the issue, because the laptop(s?) I shot your way definitely had W10 installed.
  10. Jul 23, 2025 at 7:25 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    We need to go off-roading soon.
    Lots of stuff coming up.
    Jeep vs Toyota at Barnwell Mountain (Gilmer, TX) Aug 29-31
    Merus (Amarillo, TX) with the other TX best gens Oct 17-19
    Hidden Falls (Marble Falls, TX) Thanksgiving Run with my Toyota crew Nov 28-30.
    Also, I can't recommend enough how much nicer it is to have a proper re-gear, with 33"+ tires. Just whatever you do, don't let 'TEQ Auto Solutions & Off-Road' in Houston (or any off-road shop) install them! Have em installed by a shop that specializes in differentials. I had to re-re-gear my 06, because TEQ fucked both diffs up. They even "fixed" the front diff after I noticed it was leaking. Eventually the rear diff started leaking too. Both diffs had the backlash set incorrectly, then the leaky (supposed fixed) diffs let in mud and water at Hidden Falls and both started to self destruct, just outside of the warranty time frame.
    I took both trucks for their recent regears to Toy Lex in Kemah. Juan pulled the diffs and sent them off to East Coast Gear Supply for the regearing, then he reinstalled em for me. I highly recommend Toy Lex and ECGS.
  11. Jul 23, 2025 at 7:30 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Could be.
  12. Jul 23, 2025 at 10:27 PM
    sportbike37
    sportbike37 New Member
    FL
  13. Jul 23, 2025 at 10:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  14. Jul 24, 2025 at 4:58 AM
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra New Member
    Eric
    Looking for my future 1st Gen Tundra
    Bauhaus approved
  15. Jul 24, 2025 at 5:24 AM
    DARK ENTRIES! DARK ENTRIES! DARK ENTRIES!
  16. Jul 24, 2025 at 9:22 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  17. Jul 24, 2025 at 10:20 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  18. Jul 24, 2025 at 10:44 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    not mine, but…
    bmf4069 and 455h0le_dachshund like this.
  19. Jul 24, 2025 at 12:06 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Had the alignment done this morning after replacing the LBJs. Toe was slightly off and was adjusted. Castor is also positive and they couldn't adjust it, but I seem to recall these trucks prefer extra castor. Our roads are so shitty in town that I honestly can't even tell if the truck tracks straight or not. Have to get out of town to where the nicer roads are to really see how it drives now.
    Dakillacore, bmf4069, BroHon and 2 others like this.
  20. Jul 24, 2025 at 1:38 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    man…stock gears, oversized tires, and towing. Your truck would so benefit from a set of 4:88 gears. You’d get better fuel economy, the transmission would survive longer, and you’d gain back a ton of lost horsepower. Though it’s not preached here nearly enough, but anytime oversized tires are installed, a lower set of ring and pinion gears should be installed. Heck, even the trucks with the stock 3.90 gearing and original stock sized 245/70-16 tires benefit big time by dropping to a 4.10.
  21. Jul 24, 2025 at 4:51 PM
    Dwalk51
    Dwalk51 New Member
    Dylan
    2005 4WD Tundra Limited Access Cab
    Been chasing intermittent AC. I saw people recommend seeing if the grounding bolt on top of the compressor is tight, and mine was not. Unfortunately it didn’t want to tighten anymore
    Now I’m chasing a broken bolt and broken AC!
  22. Jul 24, 2025 at 6:40 PM
    I mean, there’s no rule about where it has to be grounded. You can run a temporary jumper to offer ground and have A/C while you perform extraction on the stub.
  23. Jul 24, 2025 at 6:48 PM
    Dwalk51
    Dwalk51 New Member
    Dylan
    Good point! I may do that to confirm if the ac issue is caused by the ground or something else while I’m soaking the broken off bolt. I’m hoping pb blaster and heat will let it go with an extractor
    oscardog86 likes this.
  24. Jul 24, 2025 at 8:08 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    One of the biggest yards the wife and I mow we got because the previous mow man was killed when he got a bit zealous on a hill, zero turn flipped over, and he was crushed under it.
    We went trailerless again. Two yards like that, home for the single axle, then four more yards. One yard is way down in the boondocks, near the bottom of a hill so steep and so curvy, I dropped it down into "2" getting there and getting out. Really I should have put her into "Shift L" for the up and down. Next time, I will! When we leave that yard, the woods are so thick on either side of the driveway, plus those hairpin curves either side, we roll down the windows and listen for oncoming traffic!
    Getting better still at backing up a trailer. Oh I can back up fine (side mirrors) but backing into a 90 degree turn, from a single lane road, into a narrow driveway, with cool things to back into like the house, their cars.....fun times. Really do need a backup camera on each of our trailers. :)
    At it again tomorrow!
    whodatschrome and BroHon[QUOTED] like this.
  25. Jul 25, 2025 at 5:32 AM
    To that point, if you're not super-familiar with extractions, or you've never tried it, if you can cleanly center-punch (would be easiest with a springloaded punch, which can be had for under $10 on scAmazon) the stub, you may buy some left-hand drill bits, chuck one up that's half the diamter of the shank, and drill it down the center. Remember to run your drill in reverse. Sometimes that alone, the reverse-motion (i.e. lefty-loosey spinning) of the left-hand bit along with the head it generates will spin the snapped shank out. And if not, keep drilling until you're 1mm(ish) from the threads, and throw an extractor on it.
    All this mower talk reminds me, I'm going to need to find a mower in the next couple of years for an acre of gently sloping land.
    des2mtn and Dakillacore like this.
  26. Jul 25, 2025 at 5:48 AM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Lupe, bmf4069, whodatschrome and 4 others like this.
  27. Jul 25, 2025 at 5:50 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
    I hang two 50lb weights off the back to deal with the slopes.
    Dakillacore and shifty`[QUOTED] like this.
  28. Jul 25, 2025 at 6:16 AM
    How big a grade are you talking about to need that?
    Looking at the topo for the lot we're likely buying, it's a 35-40ft slope over a length of ~425ft (lot is roughly 125x425), so that would be, looking at the numbes it's shy of 10% grade, somewhere in the high 8% - low 9%?
  29. Jul 25, 2025 at 6:31 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    I didn't realize that you had the ATL skyline in your PFP. Looks good
  30. Jul 25, 2025 at 6:33 AM
    EyeSpyA1stGenTundra
    Eric
    Love a good mower chat. I bought an oldie in spring - a John Deere GT235 on marketplace from a guy a few miles down the road from me. 52" deck badass green machine. Loving it and has been great on the handful of slopes I have around our new property.
