  1. Jul 23, 2025 at 11:34 AM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    New parts inbound: OEM mirror, grip assist screw cap, and those skid plate screws. :)
  2. Jul 23, 2025 at 11:46 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    IMG_3858.jpg Another tow picture.
  3. Jul 23, 2025 at 11:51 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    How much total weight are you pulling? Trailer and load?
    Also, where did you get your heavy duty front bumper?
  4. Jul 23, 2025 at 12:07 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Lift is 3500 lbs. trailer is another 1900lbs. Tools another 200 lbs. about 5600 lbs total :notsure:
  5. Jul 23, 2025 at 1:31 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    What? You don't have a scale at your house? :rofl:
    I was just curious. I thought that was a scissor lift you had there. I'm not sure how much my single axle trailer weighs but I could figure it out. We go to the landfill at couple times a month and have to go over the scale there in and out and the weights are on the receipt. My single axle is 1/8" tubular steel throughout so I'm sure it's heavier than most single axles. My two axle is 1/8"x2"x2" angle and I think it's around 2,000 pounds.
    How does your truck do pulling that total?
    Do you have trailer brakes and a brake controller on that set up?
  6. Jul 23, 2025 at 1:33 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    For UBJs seemed like advance had the most comprehensive kit but haven't used it yet.
    https://shop.advanceautoparts.com/p...u-joint-service-set-23-piece-648617/9150043-P
    Looks like this is their puller set....
    Powerbuilt Tools Loaner Tool: Front End Service Kit
    Part # 648626
    https://shop.advanceautoparts.com/w...tools&storeId=10151&catalogId=10051&langId=-1
    But haven't used it either bc already have a bunch of pullers.
    oscardog86 and des2mtn like this.
  7. Jul 23, 2025 at 1:33 PM
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra New Member
    Eric
    Looking for my future 1st Gen Tundra
    I love this pic
  8. Jul 23, 2025 at 1:39 PM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    Yeah I had a combo of different kits from AutoZone and Oreilly. The UBJs were effin tight on my truck. We had to cut off the threads so basically just the ball was left. Otherwise it would just pivot around when we started pressing.
    *EDIT* yeah we had to stack a bunch of the rings on each other to get it all to work.
    Bought2Pull likes this.
  9. Jul 23, 2025 at 1:52 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Wish I had thought about this earlier....ordered the hub cap I've been missing since I bought the thing.
  10. Jul 23, 2025 at 1:59 PM
    EyeSpyA1stGenTundra
    Eric
    and another cool pic! rock on
  11. Jul 23, 2025 at 2:20 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Drivers side popped right out. Only needed the big wrench for the LBJ. Tie rod came apart with a standard ½” socket wrench.
    These were recall LBJs from Toyota. There’s some grease leaking around the opening of the rubber seal, but that could have been from me pulling them off. Both of them feel fine when moving them around and the truck drove fine. I’ll look up how many miles they’ve done and post up later. I know it’s over 100K. :anonymous:
  12. Jul 23, 2025 at 2:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I had to pull my dad's mower out of the ditch twice now. You'd think he'd learned his lesson the first time when he almost tipped it over.
  13. Jul 23, 2025 at 2:38 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    A friend of mine who is a lawn professional called me when she drove her ExMark zero turn into a pond. I pulled it right out with my AC. Fortunately the intake and exhaust were above water level and it fired right up after we pulled the plugs and checked the oil to be sure it wasn’t hydro locked.
  14. Jul 23, 2025 at 2:53 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Truck pulls it fine on flat ground. Hills would be stressful as I would be scared for my old transmission.
    trailer has surge brake system.
    Bought2Pull[QUOTED] likes this.
  15. Jul 23, 2025 at 2:53 PM
    Nimitz_
    Nimitz_ LA face with an Oakland booty
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    I just read this yesterday because I picked up a pioneer avhx5800BFHWTF or something. It needs to be FAT32 NOT exFAT.
  16. Jul 23, 2025 at 2:59 PM
    EyeSpyA1stGenTundra
    Eric
    what is stock suspension in a 06 SR5 ? Are trims of that year all the same suspension setup stock?
  17. Jul 23, 2025 at 3:03 PM
    Nimitz_
    Sam
    Seattle-ish
    If I remember correctly, the TRD has bilstein 4600s on it.
    455h0le_dachshund likes this.
  18. Jul 23, 2025 at 3:26 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Another water retrieval.
    I had to orchestrate equipment and get in and hook up this swimmer back in 2015. Only about 3ft deep there. Not with my Tundra though o_O
  19. Jul 23, 2025 at 3:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Thanks
  20. Jul 23, 2025 at 3:42 PM
    EyeSpyA1stGenTundra
    Eric
    Are bilsteins stock on all of them? Hard to find a true answer online - figured I’d throw it out. If a seller is selling a truck and I ask and they say I have no idea I’m hoping they can take pics of said suspension for me but often they just don’t know. Now I don’t know.
  21. Jul 23, 2025 at 3:42 PM
    EyeSpyA1stGenTundra
    Eric
    Whoa Nelly - sketch! Good recovery!
  22. Jul 23, 2025 at 3:46 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    So what’s your tire size and gear ratio?
  23. Jul 23, 2025 at 3:46 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    :thumbsup: 1st year kid/go fast-mow a lot, no railing... easy prediction lol. Kid was fine though, just a cut or something.
  24. Jul 23, 2025 at 4:19 PM
    Nimitz_
    Sam
    Seattle-ish
    I **think** the non-TRDs have KYD shocks on them
  25. Jul 23, 2025 at 4:45 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I wondered if you had hills to deal with. So far, mine has pulled about a 4,000 pound load up a long 5% grade on the interstate without issue. Honestly, I don't intend to pull much more with it.
  26. Jul 23, 2025 at 5:06 PM
    Upshot Knothole
    Thatchery
    PDX OR
    My TRD has KYBs on it, but no idea if they were stock or not.
  27. Jul 23, 2025 at 5:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Or maybe your non-TRD has a TRD sticker? J/k. Yeah it’s more likely the shocks were replaced.
  28. Jul 23, 2025 at 5:14 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I thought it was a lawnmower but I realized it's not. What is it? We've had people in my area drown while mowing. Accidentally driving into a lake or pond and getting pinned by the mower.
  29. Jul 23, 2025 at 5:35 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    TRD sport and I believe the SR5 came with Tokico shocks. Not sure about limited. TRD off-road had Toyota branded Bilstein 4600's.
  30. Jul 23, 2025 at 5:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Kinda looks like a tiller or an edger.
