  1. Jul 15, 2025 at 9:50 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Yeah decided against it. The card fabric is in great shape so no need really. Reason it crossed my mind was having the card disconnected because was working on the door check and broke the interior handle bezel removing the card. Figured it was unobtanium but turns out $10.50 gets a pair of FR and FL handles with trim. Good color match on the one needed, but the other handle appears to be a misship and looks like oak. Rainforest refund didnt require a return and hence no need to wait for replacement to ship. Only needed the bezel anyway. So unobtanium obtained ... for free.
    @The Black Mamba did motivate cleaning of the center console however ... albeit with the usual dishsoap and water via toothbrush and rag regimen.
  2. Jul 15, 2025 at 10:08 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My vote is still the Chinese tires. I wouldn't touch anything else until you rule those out.
    bmf4069 likes this.
  3. Jul 15, 2025 at 10:10 AM
    Ahem, they are made on the beautiful island of Taiwan. They are smooth in most other scenarios. Gets a little rumbly around 40mph, changes a little with acceleration vs deceleration, and then can occasionally feel it up around 70mph.
    BroHon, des2mtn and bmf4069 like this.
  4. Jul 15, 2025 at 10:12 AM
    Did you have to double up on the brass bushing for the negative? I did. Used the one from the positive terminal since it didn't need it.
    G_unit3000 likes this.
  5. Jul 15, 2025 at 10:59 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yes
    G_unit3000 and KNABORES[QUOTED] like this.
  6. Jul 15, 2025 at 1:38 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Most of my Suzukis are over 30 years old now and I plan on starting to switch them to SP plates as their registrations expire. I know a few people that run the special interest plates on their dailies and have never had a problem here.
    whodatschrome[QUOTED] likes this.
  7. Jul 15, 2025 at 1:58 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    What is that :monocle:
    How much it cost?
    What is setup time?
  8. Jul 15, 2025 at 2:10 PM
    Upshot Knothole
    Thatchery
    PDX OR
    Truck bed tent. I've seen other makes of the same style at local sporting goods stores.
    Got it for free off a buddy. They gave it to him when he bought his Ram, had it left over after totaling his Ram.
    First time I've used it so was double checking instructions. With two people I'd guess probably around 15 minutes. Easiest way to set it up is to put all but the door pole in first, then lift the tent into the bed and strap it down and secure the last pole over the door.
    Folds up to the size of a normal largish dome tent and weighs about the same.
  9. Jul 15, 2025 at 2:13 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
  10. Jul 15, 2025 at 2:25 PM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    In the seat, at your feet, or in the wheel?
  11. Jul 15, 2025 at 2:28 PM
    In the seat. Feels very driveline-y. Not the typical 60mph tire vibrations.
  12. Jul 15, 2025 at 2:34 PM
    That and the variation makes it sound driveline, but ...
  13. Jul 15, 2025 at 2:42 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I didn't know about the double cardan. we yanked it apart at the shop and I wound up getting a driveshaft off of rockauto. It's been good for a while now. I've heard about swapping the double cardan out for a gm style one, but I didn't have the time to wait for it.
    KNABORES[QUOTED] likes this.
  14. Jul 15, 2025 at 2:48 PM
    badass03taco
    If its in the seat, one way to check is
    jack the back end up, block it up good and put on jack stands and chock the front wheels.
    have someone sit in the seat and put it in gear and run it up to the 40-50mph range
    visually watch the tires and see if they have run-out meaning out of round. This makes the rear shake like crazy and there is no way to balance out anything more than a small amount of run-out. I have some walmark tires on my aluminum trailer and when its empty, at about 40-45 it will bounce up and down so bad you think its going to bounce off the road. The tires are egged and around that 40-50mph range its causing the fender to raise and lower about 3" but when you are 70+ its smoothed out.
    You can visually see if the tire has run-out, if you dont trust the chocked wheels and jack stands you can pull the two rear wheels and have them run on a standard balance machine and visually watch them and see if they have run-out.
  15. Jul 15, 2025 at 6:30 PM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    Picked up two set of wheelers offroad bump stops today from marketplace.
  16. Jul 15, 2025 at 6:38 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Installed a led whip mount that works with my camper shell. Just need to wire it up. Got it hooked up rn to a Milwaukee 12 V battery. It has a quick disconnect so removing it is very easy IMG_3039.jpg
  17. Jul 15, 2025 at 6:45 PM
    Damn, how much that set you back, if you don’t mind the Q?
    455h0le_dachshund likes this.
  18. Jul 15, 2025 at 6:49 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Nice! I been running those on the front for like 5 years. Had em on the rear too for a few years, but ended up doing a u-bolt flip that came with bumpstops, when I bought my Alcan leaf packs. @Sirfive has my rear superbumps now, but hasn't used em yet.
    Iirc I had to order the superbumps for a Tacoma. Is that what you did as well?
  19. Jul 15, 2025 at 6:58 PM
    AmericanKing06
    New Mexico
    Im actually going to be installing them on my 1st gen Sequoia. Did you just install one on each side? Front rear bumpstops? How much lift do you have in the front? Most likely going to install the 2nd set in the GX.
  20. Jul 15, 2025 at 7:14 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yes just one per side. I put em in the front front spot and left the front rears OEM.
    I've got about 3" lift in front.
    So does Wheelers make them for first gen Tundras and Sequoias now, or did you have to order em for a different Toyota, like I did?
  21. Jul 15, 2025 at 7:14 PM
    AmericanKing06
    New Mexico
    Only $150
  22. Jul 15, 2025 at 8:04 PM
    AmericanKing06
    New Mexico
    No there not made for 1st gens. This is the set I have.
  23. Jul 15, 2025 at 8:06 PM
    AmericanKing06
    New Mexico
    Do you think it makes a different if there installed in the front or the rear. I only ask cause most I've seen are installed in the rear keeping the front oem.
  24. Jul 15, 2025 at 8:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I don't know.
  25. Jul 16, 2025 at 9:29 AM
    Anyway, I'm that asshole that keeps any leftover metal brackets and stuff from various installs. I have a gaggle from technology/electronics and crap I've installed over the years, some found, etc. Came in handy a lot doing LS swaps. I had these two L-shaped brackets that slide right into those slots with only 1mm of play in any direction, and could easily be manipulated with a punch to click into place. I'd prefer 3d-printed ABS to click into place, but whatever. Brackets in either position.
  26. Jul 16, 2025 at 9:31 AM
    Forgot to add a shot with the fuse block. Eh. This is the general position I'm thinking
    bmf4069, oscardog86 and jerryallday like this.
  27. Jul 16, 2025 at 9:35 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    The hoard provides.
    side quest:
    Anyone know what kinda quick connectors i can use to mount these lights without em flopping about? One of those bolts with a cam lever like those razor scooters use for their handlebars?
    i want the brightest truck nuts this side of a flat brim hat.
  28. Jul 16, 2025 at 9:37 AM
    I'm a selective hoarder. I hoarde very specific things, and I'm good with organizing. Sort of. It's controlled chaos.
  29. Jul 16, 2025 at 9:42 AM
    I have a hard time parting with anything that looks useful. I'm handy, thrifty, and like having the thing I need already on hand. Most of the stuff I've been hoarding will never be used and I should just throw it all out and get what I need when I need it. But every once in a while, I need one of these widgets or wood scraps I haven't parted with yet and it reinforces my diseased thinking further. It all stays.
  30. Jul 16, 2025 at 9:45 AM
    Reminds me of this, our oldest kid sent this to me and said, "Dad, this is you..."
    bfunke, Redoak, BroHon and 6 others like this.
