  1. May 31, 2025 at 3:59 PM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    How full was the overflow before?
    Looks like maybe something is leaking in the area of the throttle body, but maybe only when the truck is hot and the system is under pressure?
    CodyP[QUOTED] and oscardog86 like this.
  2. May 31, 2025 at 5:51 PM
    Dude. Your fucking fan isn’t moving. Stop running your engine at temp!
    What the shit. Does it spin at all? Is there any resistance? Does it wobble by hand? So many questions, either clutch is bad or fan bracket/its bearing is bad.
  3. May 31, 2025 at 5:55 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Should have said in the notes but I took the serp belt off to get a better listen at the noise. Clutch fan is new. Works fine. No wobble. Pressure tested the coolant system and I didn’t see any leaks or issues.
  4. May 31, 2025 at 5:59 PM
    Whew. Holy crap. Yeah, I missed the lack of belt.
    Whatever it is, it’s pulsing in rhythm with the engine. I would expect intake gasket would be more of a hissing but possibly sucking. Else it’s something spinning with the timing belt, which makes me think pulley.
  5. May 31, 2025 at 6:27 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    It looked like UPS put something heavy on top of the box and bent it up. But I called them this morning and they said they can send a new one (currently on backorder of course smh) and i can throw away the damaged one. Was pretty much hassle free
    bmf4069, oscardog86 and Kimosabe like this.
  6. May 31, 2025 at 9:55 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I read somewhere some 20 years ago that "....any speed above 60 mph has to overcome so much drag that one is simply wasting fuel."
    From 2003 until 2009 I had the sweetest little car, a Honda Civic 4 banger, auto tranny. I did a lot of trips between southern WV and Charlotte, NC. She'd get an average of 38 mpg at 75 mph cruising speed. In 2006 I had some free time, not in a hurry, and on that same trip I decided I'd try cruising at 55 mph. HO LEE FUK. She got 50 mpg! I had scheduled an EX model rear wing (OEM) to be put on and the next trip she got 48 mpg. I kept doing this. I kept seeing great gas mileage averages.
    I run 50 to 55 and sometimes 60 mph in the Tundra, on the brief times I hit the interstate to and fro the little "city" we mow a lot in. Drawing from memory, I'm averaging, calculated at fill up, 13 ish when towing a trailer and I think I got 17 mpg once without towing that week. I generally try to "hypermile" red lights, timing my braking to still be rolling when the light changes back to "green." Truck is the 4.7 liter V8, 4wd. Probably original spark plugs. I could afford to change those sometime I guess.
    Yesterday (it's nearly 1 AM Sunday now) I used the truck as a closet since I keep my weed eating clothing in there. Did our yard and the neighbor.
    oscardog86 and FirstGenVol like this.
  7. Jun 1, 2025 at 12:16 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    looks like it’s shooting out of a bunch of places but check out by the over flow tank. You can see the sharp line on the battery and nothing above it. Could be a bad radiator cap
    oscardog86, CodyP[QUOTED] and Voss like this.
  8. Jun 1, 2025 at 1:39 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    is she hot?
  9. Jun 1, 2025 at 6:48 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I'd call this the poor man's form-a-funnel, but I've been using M1 filters so I don't think I can claim that.
    Credit to one of you beautiful bastards that I got the idea from.
    bmf4069, oscardog86, BroHon and 7 others like this.
  10. Jun 1, 2025 at 6:49 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    The whirled peas method.
    bmf4069, BroHon, CodyP and 3 others like this.
  11. Jun 1, 2025 at 6:57 AM
    M1s are my jam
    JakeJake[QUOTED] likes this.
  12. Jun 1, 2025 at 8:14 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Hey man that's supposed to be free rust prevention
  13. Jun 1, 2025 at 8:20 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Curious what you guys think about this ignition coil. I noticed it's turning brown near the top I was changing my spark plugs last summer, but it's not throwing any codes so I've just been carrying two spare denso coils (from rock auto). The rest of the coils were all black. Idle is just a hair rough, like it misses every once in a while, but not so bad that you'd notice if you weren't paying attention. Not sure if that's completely normal, I do have headers and an aftermarket intake tube (factory filter box though) which perhaps could affect things.
    I suppose since I already have spares I can just try swapping them, but I figured I'd ask here since I just did the timing belt and as a result am over-analyzing every little thing as a potential sign of imminent 2uz-self-destruction.
    oscardog86, Filthyphil and Voss like this.
  14. Jun 1, 2025 at 9:51 AM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Do we have a "What did you do to your plumbing at the shop while dialing in your new bowsight like an idiot" thread...? Happy Sunday gentlemen....
  15. Jun 1, 2025 at 10:12 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Looks fine to me, if you think you can feel it slightly missing you can toss your spare in and see if it helps. But every time I’ve had a small miss I get a check engine immediately.
    oscardog86 and Voss like this.
  16. Jun 1, 2025 at 10:13 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  17. Jun 1, 2025 at 11:22 AM
    If I rolled 60’on the interstates here, I’d get shot at.
    And do her momma look good?
    BINGO! That’s why my front crossmember and surrounding suspension look good. I always use the same terry cloth, it’s saturated, and the frame gets a wipe down with at at every oil change.
    Denso sells a re-boot kit with new spring and boot.
    Beat me to it. That’s one hell of a centered shot!
  18. Jun 1, 2025 at 11:24 AM
    Dblock500
    DMV
    Because I'm a nerd
    CodyP, Voss, bmf4069 and 2 others like this.
  19. Jun 1, 2025 at 11:42 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
    Oye! A friend of mine did something similar while shooting darts one night. Of course the hole was a lot smaller but it still required turning off the water. :rain:
  20. Jun 1, 2025 at 11:50 AM
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    Today I cleaned the mass air flow sensor and inspected the air filter, it's clean so I'll check the filter again this fall. I also checked fluid levels... all is well. Leaving the hood up so the sun can sanitize the engine bay... I'll drive the '07 while that's happening.
  21. Jun 1, 2025 at 12:02 PM
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    New 5100s today, the rears are pretty interesting. Went with ome2885 springs, we’ll see how they feel soon.
  22. Jun 1, 2025 at 12:03 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    shifty` likes this.
  23. Jun 1, 2025 at 12:12 PM
    Filthyphil
    Phil
    How much lift did the 885’s give you with a double cab?
    Stock63[QUOTED] likes this.
  24. Jun 1, 2025 at 12:13 PM
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    I was told about 2 inchs but well see after it settles over the next couple months
    Filthyphil[QUOTED] likes this.
  25. Jun 1, 2025 at 12:37 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Took a quick shot on the upper valve cover bolts and they appear to come off with little force after spraying them off/on for weeks now with Mopar rust penetrant. I figured they must’ve been loosening up since more oil soot reside was appearing at all entry points to the valve cover. It’ll be interesting to work the bottom ones on multiple extensions to see how easily they budge.
    Also got a P01350?? on the driver’s upstream O2 sensor. Not sure if the code is right but it was telling me it was the heater element going bad.
    More crap to do. Gotta love old vehicles.
  26. Jun 1, 2025 at 12:52 PM
    No pics of the truck before/after?!
    bmf4069 likes this.
  27. Jun 1, 2025 at 12:57 PM
    P0135 yup, no trailing zero.. I think that may be the most difficult sensor to break free, in the grand scheme of things?
    I didn't know which zero was bogus in your code, P1350 is cam position sensor related, but I don't know that the pre-VVTi trucks will throw it. Or maybe just the 1st gens in general won't throw it? I dunno.
  28. Jun 1, 2025 at 1:31 PM
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    My drive way isn’t flat at all so pictures don’t really show much.
    shifty`[QUOTED] likes this.
  29. Jun 1, 2025 at 1:32 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    If you actually mean P0135, upside it’s easy resistance test, downside it’s a bitch to get to and sometimes hard to remove :facepalm:
  30. Jun 1, 2025 at 1:41 PM
    Jack McCarthy
    Bill
    North of Boston
    Plan is to hit it with rust penetrant along with the passenger side. What I don’t know is whether that could cause it to fail prematurely by creeping down the wires before it’s loose enough to try and break free.
    At least the penetrant is easy to control where it oozes out of the straw.
    oscardog86 and BubbaW[QUOTED] like this.
