  1. May 19, 2025 at 7:15 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I have Fox on mine, 2.5 with reservoirs, and I’m not impressed.
    The rears I have are actually for a 2nd gen tundra that were tuned by AccuTune. Those ride and handle the best.
    The fronts did not come adjusted like they said. The hoses to the resis are too long and you can’t mount them where the instructions suggest because your tire will rub them. They don’t come with a spanner wrench, you can’t adjust them on the truck. The fittings for the hoses are not in a good location. I adjusted my coilovers for 3 inches of lift and the rebound is too hard/fast so the DSC doesn’t matter there. They need a longer or stiffer spring.
    Voss, oscardog86, khooiii and 5 others like this.
  2. May 19, 2025 at 7:25 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've got Kings on front and 5160 in rear. The rear is pretty smooth. The front is a little harsh because I have 700lb shocks. But I figure once I get a winch, that might even em out a little. But as far as the type of off roading I do, it's a great set up. Not meant to go fast off-road.
    oscardog86[QUOTED] and Nicklovin like this.
  3. May 19, 2025 at 7:27 PM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    Clearly, zero Fox given.
  4. May 19, 2025 at 7:35 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    At the very least you'd need some of these to convert the eyelet to stud
    oscardog86 and Nicklovin[QUOTED] like this.
  5. May 19, 2025 at 7:35 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Is there a good DIY thread on this in sticky?
  6. May 19, 2025 at 7:36 PM
    DIY for what process?
  7. May 19, 2025 at 7:37 PM
    BluegrapeVr6
    J
    Ac condensor/flush. May have quoted wront post.
  8. May 19, 2025 at 7:39 PM
    I cleaned the blower vent.
    I will probably pull the blower motor resistor out soon, vacuum out the housing, and hit the coil with FrigiClean in the near future though. I’ve got a process on here for that.
  9. May 19, 2025 at 7:58 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Are you going to sacrifice a little airflow for the cabin air filter mod?
    FrenchToasty likes this.
  10. May 19, 2025 at 8:24 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I won’t. I wouldn’t mind pulling the evap and giving it a legit foam cleanse and a recharge. I need every cfm I can get.
  11. May 19, 2025 at 8:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I think I want to do that too, but then maybe add an e-fan and the filter.
  12. May 19, 2025 at 8:57 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Out of curiosity are those his kings?
  13. May 19, 2025 at 9:15 PM
    FrenchToasty
    Mo
    Bone stock
    They are
  14. May 19, 2025 at 9:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    With Eibach coils, right?
    Or maybe Wheelers?
  15. May 20, 2025 at 12:50 AM
    daveeasa
    David
    Got some wires staged. Gentex harness to kick panel. Temp sensor to kick panel. Brake controller output connected.
    To Do after oil change series this week:
    1. connect temp sensor harness to Gentex harness (2 purple 22 gauge)
    2. Connect battery, ground and ignition (have a T harness for the radio ready to deploy but might go a cleaner way
    3. Connect circuit breaker and feed brake controller 30A of power.
    4. connect circuit breaker and ignition switched relay in engine bay for trailer power.
    Then it’ll be on to more fun stuff like switch-pros.
  16. May 20, 2025 at 1:23 AM
    Dblock500
    DMV
    A fan over the condenser?
  17. May 20, 2025 at 3:12 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't get me lying...whatever the heck that AC radiator thing in front is called :rofl:
  18. May 20, 2025 at 4:13 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I know the stock sequoia fan wont fit without a little fabrication (on an AC).
    455h0le_dachshund likes this.
  19. May 20, 2025 at 4:49 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    I was ordering parts for my timing belt replacement and decided to check what the pricing is on a new steering rack with the memorial day sale going on. My rack has been weeping a bit for the better part of a decade so it's been on my list to do before toyota discontinues the parts.
    Due to NYS rust, I'm in the habit of planning on replacing all the parts adjacent to the thing I actually want to replace, so I also ordered tie rod ends, bushing, and the intermediate shaft assembly. I looked up the pricing for the power steering lines and they're over $500! I took a look at my lines and by some miracle they actually look new!?! They have paint and everything! Maybe they were replaced as part of the frame replacement? They'll probably break anyway when I try to remove them just to spite me.
    oscardog86 and The Black Mamba like this.
  20. May 20, 2025 at 5:16 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    The little ass lines for the rack?! I'd suspect the one going into the rack on 2nd photo might bust.
    The rack is usually around 700 give or take iirc.
  21. May 20, 2025 at 5:18 AM
    Hell no. Not worth it.
    Not knocking on folks who opt to run a filter, I’d reconsider if I were in a dusty area, but with humidity here, I’d be worried about organic building up and causing other growths.
    Kalannar97 likes this.
  22. May 20, 2025 at 5:19 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    The line in the second photo is part of the rack for comparison to the lines in the first photo which are the ones I'll have to remove.
  23. May 20, 2025 at 5:21 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    If you do need new lines, I recommend the Suosong lines from RA. I have them on mine and they work great. 3 years long now.
  24. May 20, 2025 at 7:03 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    so how much was a dealershit steering rack?
  25. May 20, 2025 at 7:15 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Just the rack:
    oscardog86 and txagg like this.
  26. May 20, 2025 at 7:19 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    nope. My shit can drip. One of these days i’ll have to get a steering box for a SAS.
    txagg, bmf4069 and FrenchToasty like this.
  27. May 20, 2025 at 7:22 AM
    I mean, I wouldn't be mad at that as long as it's the exact same OEM quality. That factory rack lasted 25 years and it's barely leaking today. I guarantee you, you're not getting more than 8-10 years out of any aftermarket rack, and they run $275-375 for decent brands last I checked. Hell, I'd be surprised if you got 4-6 years out of most of today's aftermarket brands. Say you got the better part of that 6 years out of each and they ran $325/pc. That's three rack installs and $975 in the same timeframe the $726 OEM rack lasted.
    Man, it's a hell of a shock to the wallet, but when you look at the bigger picture of "buy once, cry once", with OEM longevity ... it's a no-brainer to me.
  28. May 20, 2025 at 7:27 AM
    If my rack takes a full on shit, I’m thinking of rebuilding it with the OEM seals. I’ve already accidentally got one of the internal cylinder bits with O ring seal.
  29. May 20, 2025 at 7:28 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I’ll have to break my steering wheel and wollar out or crack mounts to trade about a bottlecap worth of leak every oil change.
    gonna order stuff for VC gaskets. All my leaks are starting to stink on hot days. Anyone got a hotlink to ‘02 gaskets & the o-rings & fipg p/n’s?
    KNABORES likes this.
  30. May 20, 2025 at 7:33 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    The Car Care Nut has converted me from aftermarket parts. Last year I had to do a rear axle seal/bearing and replaced the after drums/shoes with OEM ($$$). Stopping power is much better, and no the old brakes weren't out of adjustment.
    shifty`[QUOTED] likes this.
